If it's cheap enough is take it.  Just my opinion.  I'm almost at 44k miles on my 2020 and it only has 1400 hours on it.  Auto start/stop doesn't engage when the truck is in Park.  Whenever you come to stop, the auto start/stop turns off the engine, and you then shift into Park the engine comes back on.  Mid to higher trim levels do differentiate between run time and idle time.  Iirc, even with 44k miles, my truck only has a few hundred idle hours on it.  The truck you're considering was definitely sitting and idling for long periods of time.  Was it a border patrol truck where an agent sat in it and let it idle so they could have AC?
Or some guy on his way home from dinner whose wife told him she was going to run into the store for just one thing and 5 songs later comes out with bags of stuff!  LOL
  • Haha 2
Most outdoor workers truck’s start in the morning and shut off again at home. I know of one crew and truck supplier with about 20 crews. His average trade in is 300K miles. They usually run 10 day rotations out of town. Once at the job area they may travel 10-15 miles to the job. I imagine the engine hours at dark to dark running are very high. I’ve never seen adverse effects of it. Just another thing for the worried to worry about.
Or some guy slept in his truck because the wife kept throwing him out of the house alot so he had the AC or heat running in the truck.
  • Haha 2
Fun with math:
Truck has 40,000 miles on it and 3,400 engine hours. newdude says GM uses a 33 mile to an hour wear estimation on warranty. I would imagine that is the 'wear' equivalent based on their testing. The average driver drives 14K a year (The Zebra.com from 2022).
So this 2019 truck is about on the money miles per year. Check
40K / 33 = 1212 engine hours would be 'normal'
3400 - 1212 = 2188 idle hours or it idled 6 hours a day, day and day out for exactly 365 days, 1 year.
Idle speed of 550 rpm is 33,000 rpm per hour
198,000 rpm per 6 hour day.
73.27 MILLION revolutions idling.
144.54 MILLION trips up and down the cylinder
That's 43.602 MILLION feet or 8,258 miles the rings were drug over the cylinder face.
I know nothing about this truck but I do know that if I leave Pepper idle prolonged periods the oil temperature tends to bounce off the cooling fan limit with puts oil temp over 220 F and at 550 rpm the velocity component of the Stribeck Curve is pretty darn low. Even though the load is low the piston stops twice per rev so much of the stroke length is in boundary layer lubrication. Meaning that for the most part this power cylinder is at the mercy of the add pack an as the oil change interval is sketchy perhaps even depleted for some portion of those 8K miles they were drug across iron. Forget the idea it takes about 180 C or 356 F to activate the wear package.
So, imagine a piece of steel drug 8 THOUSAND miles over steel that had been but dampened with 3 in 1 oil at a speed of roughly 3.8 mph. That's the mean piston speed of a 3.62" stroke at 550 rpm.
Do you think that this would not result in wear equal to GM's study that would put this motor hours wise at 112K miles?
In the average of circumstances only 0.3% of all vehicles make it to 200K. Ya got something less than 88K miles left. How much do you want to pay? It's a rhetorical question. 😉
Edited by Grumpy Bear
gramar and spelling
  • Thanks 1
I used to do this with my '96 F150 with a 302 V8.  Fired it up at 0530 and didn't shut it off until I got home around 5.  Drove about 50-100 miles between job sites and left it running so it was nice and cold when I hopped back inside AND one less thing to fail by starting and stopping the motor all the time in remote areas.  She averaged 12 mpg still.  Never had a problem with the engine or its accessories after ten years.
The few issues these motors can have also directly link to improper oil service intervals once the miles start to add up.    Also, I thought GM Certified Pre-Owned came with an automatic 100K mile extended warranty?  If it only has 40k miles and they aren't willing to put an extended warranty on it, that should tell you everything you need to know.  It would be a hard pass for me.
Edited by Gangly
They usually do not certify preowned vehicles with more than 10k miles unless in the current year and not ones 4 model years old either.
40k miles is just preowned (used) and usually just a 30 day warranty.
Edited by repairman54
I just traded my 22 LTD High Country 6.2 with 22,000 miles for a 23 High Country 6.2.
They won't  sell it as certified because I did my own oil changes and they have no record of it.
I gave them my maintenance records ( oil changes only) and they didn't want it.
The truck is still for sale a month later for 60g.
46 minutes ago, dieselfan1 said:
They won't sell it as certified because I did my own oil changes, and they have no record of it.
I gave them my maintenance records (oil changes only) and they didn't want it.
Ya can't fix stupid even with Duct Tape and WD40. It's a nice truck that needs a nice home.
  • Thanks 1
This is the latest scam I learned about a couple months ago. I had an oil light message come on and stupid me reset it to see if it would come back. I was near the dealer I bought it from so I stopped in to ask about it. They asked about oil changes and I said I did them myself and I had a record of when I changed it and with what. They suggested having it changed at the dealer so they have a record of it in their computer. They just want to get more money from service or screw you on trade value. The service guy said I should keep all my receipts for the oil and filters I buy as proof. I don't specifically buy stuff at the same time for an oil change. If I find a deal on filters, I'll stock up. If I find a deal on oil, or I don't have enough left in my stash in the barn, I'll buy more, but not the 8 quarts at once the truck requires.
Most vehicles have change oil lights. All manufacturers want maintenance records. I can change oil, engines, transmission, etc. and rebuild them. My under warranty vehicles get dealer service. Most still do after properly vetting them. Most of my vehicles are purchased at the same dealers. They’ll match other offers. It’s good to build relationships. They’ll send coupons. I just got one online for my wife’s car. Full synthetic with a rotation for 60$. I’ve been using them for 30 years.
  • Thanks 1
I've never give a warranty two seconds of my consideration. I give the dealer my guarantee instead.
If you won't stand behind what you sell, I guarantee it's the last thing I buy from you.
I take care of it better than any manufactures suggested maintenance interval. I do it on shorter intervals, better products and drive and maintain with the care only an invested in himself owner/operator will give it. If that doesn't mean something to them, it will to someone else. For decades guys line up to buy what I'm willing to sell and I'm not willing to sell much. I always get my price or it goes in the ground. That's been tested 😉 My good stuff I keep. My lemons I don't dump on anyone. If they really want it, I explain in painful detail its faults and if they still want it..... Sometimes I just give it to them.
Dad made an impression on me as a child about property. "When you borrow always take it back in better shape than you receive it. If you do that, people will lend you anything and as often as you require." He was dead right. "They will also give you top dollar for whatever you are selling". Obviously this does not include dealers. Dealers are not people. They just look like one. :crackup:
List the work on the myChevrolet app. My dealer accepts that for warranty.
GM can see it.
That’s fine if every product or person lasts exactly the same. No warranty or life insurance is necessary. No dealer is going to back a vehicle repair without it being backed by the manufacturer. I wouldn’t ever buy a new vehicle without a warranty, most people wouldn’t. I wouldn’t dream of having 3 children without putting a warranty on myself. It’s called life insurance, same difference. Every product has a warranty. Warranties are free and good business. I had one V-10 blow up. We had 3 all used exactly the same way. One was bad. Fixed for free under warranty. If I was to buy a new vehicle especially a GM I’d buy an extended warranty.
    RyGuy43
    RyGuy43
  • Who's Online   1 Member, 0 Anonymous, 428 Guests (See full list)
    • consider doing electrical testing?  I would guess some power or ground wire/connection has a problem.   alldata.com has wiring diagrams, connector pinouts and diagnostic procedures you can use to find where the problem is.
    • Any joy with this truck seems to be short-lived.   The CEL for P0172 ("bank 1" too rich) is now "intermittent".   I'm not sure where to check, or re-check, and my energy to keep chasing problems with junk is wearing thin. The P0172 seems to set as I'm coming to a stop, completely off the throttle, when fully warm. At least, that's what it's done the 3? times it's set.   Everything appears normal on the scanner EXCEPT long term fuel trim. There's only one bank on this vehicle because it's an OBD 1.5 with only one upstream O2 sensor. At idle, it's around -16.4% and will dip to -18% occasionally at idle or off-throttle. LTFT approaches 0 when throttle is held at 2500rpm. Short term appears normal, much closer to zero all the time. The LTFT tells me the engine is running rich at idle but compensating at higher load. But, why?   The EVAP purge valve doesn't appear to be leaking/sucking fuel vapor continuously. Is it sticking just as I come to a stop and the engine is choking on fuel vapor and sets the P0172? But that doesn't explain the persistently negative LTFT. Disconnecting the purge valve doesn't seem to make any difference.   I suppose that leaves another dang issue with the fuel injector. A leaking fuel pressure regulator, a new leak in the spider, or a leaking fuel injector/poppet valve I didn't see, or a small crack in one of the spider legs.   The vacuum line leading to the fuel pressure regulator doesn't have raw fuel in it. It doesn't even smell like fuel when it's pulled off, not until you suck air through it, then you can tell it leads to a fuel component. I'd consider that normal? Nothing is signaling this is a FPR issue from the outside, at least.   The oil smells like fuel but it's not building volume. I've noticed most oil in most engines smells like fuel to some degree so it's hard to say if the smell is an issue or not. Or if the engine just still smells like fuel because the crankcase was full of it a few hundred miles ago. But it's been changed twice since that original issue of the leaking fuel line dumping fuel into the intake.   Patience is running very thin. Every win seems to be accompanied by two steps backwards, or another issue that leads to removing at least the top half of the intake manifold. Enough! LOL
    • First off you mentioned "Toyo Says" and then gave the pressures 45/50, was this some person at the tire shop that pulled those numbers out of his head ?   Now of course I can't know your exact axle weights front and rear, however I have much the same pickup as yourself other than not knowing your starting weight as per the pounds the truck rolled out of the factory at due to the options yours did or didn't come with or what you have added beyond the extra tire weight. The correct way to know 100% where a person is at is by weighing each axle with the typical weight the vehicle is driven with and that means taking into account passengers and making sure you figure in a full tank of fuel and a little grace for whatever you may put in the bed "groceries" !    I am looking at and not that it really matters as all the tire companies use the same charts anyway, but I am looking at the comprehensive Toyo tire chart in the section that your tire falls under and I know it sounds confusing but your tire is not an LT metric tire like your factory tire but instead because its a standard inch measured tire its under a different category called an LT floatation series tire. That makes a difference as LT metric tires they don't want to see run below 35 psi at highway speed where as with the LT floatation series it can be run down to 25 psi on the highway as long as the weight on the said size of tire is agreeable with or less than that minimum 25 psi. It blows many people away that how is this physically possible, an empty truck for one thing and larger tires with the same size wheel diameter have a lot more air volume so they can carry the same weight as the smaller tire with less air pressure.    So my truck, I have the stock 275/65R20 wheels and tires and I have a bit of weight in the box with a bak flip cover and a rubber bed mat and some tools and spare gas. The front of my gas truck weighs a bit more than some trucks of the similar spec due to double batteries and alternators. However with full fuel and just me in the truck I am weighted such that I can run 40 front and 35 rear and so that is what I have done since day one.    If I base your truck at or slightly below the weight of my truck, in theory with your tires going by the tire chart you might be right around a minimum of 30 pounds front and 25 pounds rear. Of course that would hit pretty much minimum cold inflation pressure one could run with that tire size and a near empty truck. If you have access to an accurate weigh scale to do individual front and rear axle weights I would suggest you do that and make sure your topped up with fuel and whatever else in the truck before you weigh it and then you will have a great starting point to work off of and figure out what your bare minimum pressures are you can safely run. If you do much in the way of hot weather high speed driving, bumping up a bit for a safety margin is never a bad idea but just depends on what type of driving you do. I will include the Toyo chart and the floatation series sizes start on page 31. Without a doubt at these pressures I am speculating at minimum wise for your truck, it would most certainly ride very different then it did when you were using 55 lb front and rear.     https://www.toyotires.com/media/pxcjubjs/application_of_load_inflation_tables_20200723.pdf
    • Take an automotive stethoscope to the vacuum pump. Iirc those tick as well.
