  • Ztp1990 changed the title to Diff drop for 2020 trail boss
This is the only kit I'm aware of. There's a few different sellers but it's basically the same kit, spacers and longer bolts. I bought the Supreme kit myself, but haven't installed it yet. I have a 2" lift waiting to go on my Trail Boss.
I haven't even lifted my truck yet! Was unemployed for a year and a half and took a nearly 50% pay cut so I haven't had funds to buy the finishing components I wanted.
  • 3 months later...
How is your truck, since you installed the RL kit?  Did you ever get the differential dropped? Do you have pictures of the CV angles? I just got this out on my truck and I'm now worried about it too.
    • when it's greyed out that is it's way of telling you that it's downloading the patch in the background. Eventually it will be fully downloaded and then it will prompt you at ignition shut down to run the update. I highly recommend doing the update once you get home and can run it a few times. I've had several issues with updates not going the first time around and I had to retry the update multiple times in my driveway before it was successful.   Some updates are huge and take awhile to download. You can help it by connecting to your home WiFi and keep the truck on service mode for the ignition and keep it alive for awhile on a battery charger too. There are specs it needs to be in for updating such as a full enough battery charge, no running ignition, etc.
    • I am not techy at all but wondered if you have the truck running but sitting still in park as some functions gray out as soon as the truck is moving. I believe in the settings for updates you can choose for it NOT to update and I wonder by chance if maybe that was chosen before and now it won't allow you to chose to press update, I think that is back in the settings menu where it has all the items one wants on or off etc. Also I assume you have a wifi connection and checked that it has some signal strength, not that it would have anything to do with the grayed out updates choice in that case. What I am thinking out loud of here may be be of no value but thought I would suggest it, sometimes it can be the simplest thing that resolves an issue.
