Greetings,
My 2020 Silverado LT 1500 Trail Boss has a whining sound that just started coming from the engine bay which is audible from inside the cabin and from the outside.  It follows engine RPM.  My truck has about 31500 miles.  I went to the Chevy dealer for an oil change not too long ago and a couple of days after the oil change/tire rotation, the whining sound started.  I don't think going to get an oil change and this issue are correlated, but I could be wrong.  Any insight onto what this issue may be would be greatly appreciated.
Below are some videos of the sounds:
i had the same noise . dealer replace sepertine belt and water pump , my a 2019 with 59000 on it
Welcome to the forum. Sounds like a bad bearing, water pump, idler pulley, A/C compressor, alternator? Take it into the Dealer.
Mine was the idler pulley. 2020 Silverado 5.3 with 49,500 miles. Sounded like an old power steering pump low on fluid and going bad.
Dealer replaced the idler pulley and belt under warranty.
Noise gone !
Agreed, it sounds like a power steering pump on an older vehicle.  I would check the idler pulley, water pump, alternator, etc.
On 6/19/2023 at 1:37 PM, Varkan said:
Greetings,
This is certainly not what we like to hear, Varkan.  Please know, customer satisfaction is extremely important to us. Our team would be more than happy to take a closer look into the concerns with a noise in the engine bay on your 2020 Chevrolet Silverado. To do so, please send an email to [email protected] with ATTN: Varkan/GM Trucks in the subject line.
Please include your contact information, VIN, a brief description of your concern, and the name of your preferred dealership. We look forward to hearing from you. To learn more about GM’s Privacy Policy, please visit https://www.gm.com/privacy-statement.html. The information you provide may be monitored and recorded and is subject to the GM Privacy Statement.
Privacy Statement | General Motors
Your privacy is important to General Motors. This Privacy Statement addresses the personal information GM collects and how GM handles that personal information.
www.gm.com
On 6/19/2023 at 10:37 AM, Varkan said:
Greetings,
My 2020 Silverado 1500 LT had the idler pulley replaced, along with the serpentine belt, at 32,500 miles on the 29th of June in Madras, OR for the same reason/noise.  The issue was the idler pulley, but the stretch-to-fit serpeitine belt had to be replaced because of the idler pulley replacement.
Edited by Anacortes Army Guy
Just took the truck to a dealer and the idler pulley along with the serpentine belt was replaced.  However, the issue was not fixed and the noise still exists.  Will have to take it back to the dealer to see what it could be.  The problem is that my bumper to bumper warranty expired back in March due to it being past 36 months, but I’m only at 32k miles.  Hoping this would qualify under the powertrain warranty if it happens to be an AC compressor or Power Steering pump.
I have a whining noise in my 2023 Sierra SLT 5.3L. The truck has only 2000 miles on it. The whining noise is very annoying at low speed below 30mph or so. The truck is only 3 months old, I took to the selling dealer 2 weeks after buying it but they said noise is normal. I think my noise is from 10 speed transmission, but I am not 100% sure.
I see a lot of discussion regarding whining noise from the transmission here an also on Ford forums, considering it is developed by Ford. I plan on having the dealer look at again with my first oil change. That will be a different dealer and it's the one I am planning on using for service.
You have your previous RO number that shows this is the same issue . It is still covered. Contact GM
  • 6 months later...
Was your issue resolved? I have same exact sound and what's described on my truck.
I am lucky and do not have any noise like this but plenty of videos i've watched on the tube point the problem at being the idler gear that runs the oil pump in the transmission which is just behind the torque converter.
Greetings,
After idler pulley replacement, mine came back with a vengeance and ended up being the torque converter. At 50k. This is the second one.
    • Although there is a "recommended" weight by those who sell trailers, my experience has been that they are way too aggressive in their information, for me at least. My '22 with 6.6 Gas, has a payload of about 3400 lbs and depending on your specs (I don't have 4WD so it has a bit higher Payload than others) yours will likely be different. Payload is one of the most important numbers for towing. Although you "could" tow the max trailer weight for your truck, I, personally, would not go close to that number. Having said that, a lot depends on how/where you will be towing. I live in the LMD of BC and often tow to Denver, Co, along interstates (flat and mountains) and I find I need to keep it in 5th (6spd) for the trip and travel at around 65mph. This is for a trailer dry weight of just under 3500lbs. If you are only doing local, short trips, it would not be that big an issue if you had a heavier unit. You will be surprised how much stuff you load the trailer with, so I would only recognize the trailers "full" GVWR weight rating, then decide on the appropriate trailer from that number. If you are worrying about how much stuff you should be putting in a trailer, you might have too large a rig from the get-go. Once again, depending on what terrain/distance in which you will be pulling. Marv
    • davester, Thanks for the response, how ever, I think I am now a bit more confused than I was before I posted - - After I posted, I actually found a YT video of a guy who replaced his Module (above tire) and he only disconnected the ground cable of the battery, but you describe rubbing the two cables together after disconnecting. I presume that is to do as you describe and eliminate any residual energy? - When I picked up the Module (between my posting and reading your response) from the dealer, I specifically asked about any re-programming and he stated it was not necessary as it was simply plug and play. Don't know how knowledgeable he is, though. - The video I watched also showed the Module plug to be difficult to "unlock" and remove, but there was no mention of silicone, although the video did show a bunch of dust/dirt in and around the plug (old truck) during removal. Are you talking about silicone that was applied by the factory, or silicone that you applied prior to plugging in? Thanks again, Marv
    • Looking for a clean, factory-style lighting upgrade for your 2022+ GMC Hummer EV? M&R Automotive's 40" Bumper Light Bar PRO features a vehicle-specific, bolt-on design with no drilling or cutting required. Choose a bright white or yellow main beam, both paired with an amber DRL backlight for a sleek OEM-inspired look. The kit includes a curved LED light bar, powder-coated brackets, and all necessary mounting hardware.    Learn more or order yours See how it installs and looks on the vehicle:
    • Looking for a clean way to add serious lighting to your 2019+ GMC Sierra 1500? Our M&R Automotive 40" SLIM Light Bar Kit was engineered to deliver maximum performance while maintaining a factory-inspired appearance.   Features: • Designed specifically for 2019+ GMC Sierra 1500 models • High-output 40" SLIM LED light bar • Clean, integrated grille-mounted design • No cutting or drilling required • Bolt-on installation using vehicle-specific brackets • OEM-style fit and finish   Whether you're hitting the trails, exploring backroads, or need additional visibility off-road, this kit provides powerful illumination without compromising the look of your truck.   For product videos, light output demonstrations, and installation content, check out our YouTube channel:   https://www.youtube.com/channel/UC3lutWP54fkXBl3iFLDJR-A Have questions about fitment or installation? We'd be happy to help.
    • $3.63 today. Inching down. Plenty still over $4.20
