I have a 24 since August. If I don't have the radio on lightly accelerating I can barely hear a whine/whir in what seems like 5th and 6th gear. Radio on even low volume can't hear it. Accelerating a little harder doesn't seem to be there. Hopefully normal.
  • 10 months later...
I have a 2024 2500HD 6.6 gas and I am getting the same whining noise, but mine has gotten louder over time, used to only hear at slower speeds just starting out, now it is louder and here it almost all the time, going into the dealer next Monday, see what they say.
Edited by Graves
Almost 50,000 on my 2024. No motor noises at all, just smooth.
Same no worse no better transmission sound/s it made from new.
Aside from a slight wine from the transmission (that's remained constant since new, so I don't worry about it) and to be honest, it could be the power steering pump too. I haven't cared to dig into it.
Engine makes some general bottom end "running engine" noise. I pay no attention to it.
24 w/ ~16k miles. Daily driven since the day I bought it.
Edited by OS RR
My 2026 Silverado 2500 Hd 6.6 Gasser has the same noise.  It is especially prominent at 2,000 RPM's.  Everyone I had ride with me asks, "Wow, that turbo sounds mean!"  It's embarrassing to say, "Sorry, that's not a turbo, because it doesn't have one.  Unfortunately, GM says it's normal transmission noise."  They usually respond with,  "Wow, I'm not buying a GM truck!!"  It's so sad that GM has this attitude on my brand new truck with only 3,000 miles on it, and it made that noise on my test drive and remains today.  I'm at the dealership right now to get it checked again.  I'm also going to drive another new 2500 HD to see if it makes the same noise.
PLEASE NOTE:  GM, I am truly disappointed with this type of quality control and customer service.
Mine has made the same noise since new. There is a TSB about it. My dealership said the same thing, it's normal. Its generally around 3rd to 4th gear and its gone around 38mph.
Planetary gear sets are particularly noisy because of the sympathetic vibration of multiple gear sets of identical design generating reinforcing noise energy. It’s a common, known issue with helicopter main rotor drive transmissions. However, the designer/builder should be taking comlonly known design measures to minimize the noise. For GM to simply say “normal noise” for a particularly noisy gear set is to ignore the engineering/builder challenge to minimize noise for such gear sets, and indicates laziness and lack of care.
Unfortunately as a consumer all we typically can do is vote with our dollars. As a professional aviation systems analyst with vibration and noise expertise, I have become so disgusted with current automotive manufacturers that the rule I follow is not to buy any product that doesn’t have at least a ten-year track record. We cannot rely on the integrity of manufacturer’s engineering organizations to put out good products, and can only rely on demonstrated reliability. It’s sad, but they asked for it.
  • Like 4
Do you have the TSB or a link to it?
Another JR, So true, and thanks for sharing your wisdom!  The whine sounds like an old-school radio whine from an aftermarket radio that was installed with a poor ground.  Not something that we should expect from an $80,000+ truck.  I believe that GM monitors these forums, maybe I will receive a call...  Time will tell.
https://static.nhtsa.gov/odi/tsbs/2024/MC-11012007-0001.pdf
It has a few items on this list but about youre looking for the below portion.
Reaction Gearset Whine (Gearset One)
With variation in gear tooth finish and positional control, some customers may experience whine from the reaction
planetary gearset during light to moderate driving conditions.
Most common conditions to hear whine from the reaction gearset is in 4th and 5th gear (20-35 MPH) (32-56 KPH).
Reaction gearset is active in gears 3-6 and 8-10 so depending on severity it may be possible to hear in gears other
than 4/5.
Frequency of whine will change as transmission shifts gears due to component rotation speeds being changed.
Utilizing manual tap to shift through gears is a good way to verify what gears whine in present in.
Note: Whine from the reaction gearset should not be present in 7th gear due to the 1:1 ratio and gears being locked.
If whine is present in 7th gear, issue likely lives with some other component.
than 4/5.
Mine has what I think is general pump whine. But also does this, not sure what gear. Sounds like a power steering pump groaning when it shifts. Pretty random as to when it happens. Usually coming down hill and it up shifts.
than 4/5.
Thanks so much for the information, Byrds8.  I have the noise in Park or while driving, especially loud at 2,000-2,500 RPM.  According to the TSB, the most applicable condition is this one:
Park Transmission Oil Pump Gear Mesh Whine Unlike previous generation HD transmissions (6 speed), the 10 speed Allison model transmission utilizes a (3) spur gear design (driven off of the torque converter) to drive the transmission oil pump. Due to the 3–spur gear design, some transmissions may exhibit a whine noise while in park or driving and may get louder as engine speed or transmission temperature increases. Isolating the whine to the oil pump gears can often be done by replicating the complaint in park and sweeping engine speed slowly from base idle to 2500 RPM. If whine can be reproduced in park, replacement of the transmission front support and/or transmission oil pump often corrects the whine complaint.
Did you have your noise repaired or just living with it?
Since I’ve seen a lot of posts mentioning this noise and GM seems to elude to its normal, I am just leaving it be. If it gets worse with time etc I’ll make them do something. I didn’t want them to swap the transmission out if the next one was going to do the same thing.
Oh man I remember that sound from back in my car audio days. That would drive me up a wall. I don’t think this sound has to do with the 6spd. I’ve never heard it.  Must be 10spd only?
    • Lake Speed is drumming up business for his company just by being in the spot-light so he has a vested interest in stoking the 0W-20 fire.  IMO
    • I knew when I bought my truck that it had off road hill decent or craw control or whatever they call it and rolled my eyes at that but it gets throw on with other options my truck has, I just never had a heads up if the highway speed regular cruise setting had anything to do with the brakes and that took me by surprise. If you've ever been to the top of Pikes Peak and watched those ahead of you on the way down with their brake lights on constantly, one can guess they are probably not gearing down or not enough anyway if their vehicle will allow and a good reason their is a brake check spot part way down where they use an infra red heat gun to check how hot ones brakes are front and rear.    Your right that once one gets out of the front range by Denver and I've not been on that stretch of 285 between Denver and Fairplay myself but I know its high and Fairplay at 10000 feet, Buena Vista at 8000, it drops a bit from there but then your going back up and over the 11000 pass and Durango is at 6500 . So yes your definitely right that 6500 and a lot higher is the theme of going anywhere out in that direction from Denver but hey, the down hill sections give fantastic fuel mileage !.    I don't even look at the fuel pumps for what premium costs here, since I live on a farm and up to this point get fuel delivered I am rarely in front of a fuel pump and when I am, I am often using card lock bulk fuel stations so it tells me what the price is AFTER I buy the fuel. Looking up on gas buddy and converting to US gallons but in Canadian dollars, regular on average of the prices listed was around 5.95 and premium is around 7.00 . That was one reason I did not go for the 6.2 half ton aside from its lack of carrying/towing if one was going by the rule of using premium fuel and until recently one could only buy regular farm gas if playing the few cents off game for farm dyed fuel for a "farm licensed pickup". But yes I hear you on the fuel price difference and like the diesel theme with it often being more expensive then gas it doesn't have quite the charm to it either as it once did although right now here for some reason the price of diesel has come down more so its now inline with the price of regular gas.
    • I agree with this assessment. As you know I’m testing longevity with vehicles for the first time. I have a few vehicles I passed to kids and grandkids. We’re all past 100K miles some approaching 170K. I’m the only one doing 5k oil changes. The rest whatever the minder says. I’m the only one doing frequent transmission service. My odyssey the trip vehicle at 200K will be finished as a trip vehicle. I recently changed to high mileage oil, Valvoline. I can’t get past the fact that all manufacturers want to claim long service life. I just don’t make sense that they would go with low weight oil for mileage. While sacrificing longevity.
    • There's absolutely a mountain of profit in catering to the "I do my own research" crowd, people who are certain they know better. And I don't mean there isn't data to support that 0w40 produces less wear product than 0w20 in an engine like the 3.0 Duramax, that only feeds them the assurance they need. Again, my whole thing with oil selection is, sure, 0w40 or 0w30 produces less wear product. Are we talking the difference between the engine lasting only 100k versus 200k? Or are we talking more like, if the engine will already go 350k on a good 0w20 regimen recommended by the OE, is using 0w40 going to get us to 355k, assuming we can even get the rest of the truck to last that long, meanwhile sacrificing the first 5y, 100k in powertrain warranty. The answer isn't easy, there are tradeoffs.   I willfully use 0w20 Dexos D for this reason, knowing that a 0w40 will produce slightly less wear. I don't believe the delta in wear product is meaningful over the lifetime of the engine, and I place much more importance on driving style and overall feeding and care of the engine as a whole. It's the mentality that someone can abstain from alcohol their whole life which is an amazing boost to health by itself, theoretically. But if they're sedentary, that lifestyle choice will most likely kill them young despite their other, concerted efforts. Maybe someone doesn't drink AND they are the perfect picture of health and activity AND they use 0w40 AND they treat their engine perfectly. If living until 130 years is the goal, sure, do that. But it's going to be a really old truck falling apart around a good engine for that last 30 years, without a doubt.   I watched Demonworks' other video on the 100k+ 3.0 Duramax that had dealer 0w20 changes on what appears to be OLM-prescribed intervals (8-10k).   The QR codes are still present and readable on the main bearings. That's how little wear it has.   That's not proof that anyone else should stick to 0w20, but it's confirmation, for me, that 0w20 is perfectly acceptable to use in these engines.
    • 1Based on independent testing of OE 0W-20 in the Peugeot TU3M Wear Test as required by the dexos1 Gen 2 specification.
