My 6.2 gets 20 mpg easily and consistently. Old '11 Tahoe 5.3 at its best barely made 19 on identical roads and trips, usually only 18 mpg.
Not loaded up figures also. And no comparison to the power on tap with the 6.2.
Look at the window stickers, same mpg ratings for the 5.3 or the 6.2.
My 02 5.3  avalanche with the 373 gear got 17 mpg at 72 mph on the interstate. My 14 gmc  with the 342 gear got 22 mph at 72 mph. I posted it at the time on an old gas mileage thread on this forum. With several hundred miles driven on that tank. I saw as much as much as 24 mpg at 60mph. Those were normal for that truck.
Edited by KARNUT
In June I bought an LT with the 2.7. I liked the grunt it put out. But at 700 miles the oil pan started leaking, and it gave me a chance to rectify my "mistake" of not getting the 5.3 to begin with. I also was just not satisfied with the sound of the motor. So I traded it back in to the same dealer. Cost me a little more to get into the 5.3 that way, but I'm completely happy with my truck now.
I've had five brand new Chevy trucks in my life, along with a few used ones and I have to say that I like this one the best. So long as it treats me well for as long as the others did I will have no regrets. I put a Magnaflow 14" on it and it now sounds as it should, imo. I drive around in L9 all the time to keep it running all 8, and it has as much grunt as I need. A bit less than the 2.7 but that's due to the turbo on the latter. And I like the 10sp better than the 8, even though I'm only using 9 of the gears. I've had a couple of 350's in my trucks, and a 400 small block. None of them put out 355hp or close to 400lbs ft of torque. Technology has made for some great vehicles in the last 25 years or so. I average close to 18mpg every tank. The 5.3 is a hoot.
Edited by TrueBlue
Ive had my 2.7 HO for about 5K miles. For the first 4000 it was stock. The motor has 100% surpassed every expectation I had on it. Pulling hills with the turbo you fly past other trucks while getting 20+mpg. The power is there and the torque is there. The very top end it gets sluggish, but you rarely drive there. Its quiet if thats what you like, and the light overall weight rides nice and helps with wear and tear.
The last 1K miles ive since added a 3" lift and 35's with a black widow muffler and have a CAI and hot/cold pipes in the garage to still get put on. Yes the MPG has gone down as expected but i'm still about 17mpg city with all that low end pep and it can still break the 35's loose. It doesn't sound like a honda with the black widow (they love turbo's) Just a muffle delete it likely would though.
If I had to do it all over again, I would stay with the 2.7L
I have 115k+ miles on my 2020 5.3 and there is no lag whatsoever.  It gets after it whenever I need it to.
On 10/29/2023 at 2:23 PM, Silverado4x4 said:
I don't know what year your Ram was but all new vehicles come with torque management to protect the drivetrain. When my 5.3 was new it learns your driving style with the tranny but after I put about 1000 miles on or give our take it really woke up power and shifting wise, I love my 5.3 power and more than enough for what I need. Iam with you on the 4 cylinder motor as I don't want a 4 cylinder in a truck I don't care if it had 500hp but its always revving rpms and can't get past the sound of it. I could hear it now from people " Hey man nice truck what motor you have ummm its a 4cylinder" WHAT? But iam not downing it but it's not for me. Thats why there are choices.
The 2.7turbo is a great motor, however I buy the 5.3. I love it. The more I drive it the more responsive it gets. A lot of the lag is due to fuel management and driveline protection ,But it learns as you drive it. You will always have a little bit of lag in the new trucks. Doing a dfm delete helps a lot. I notice when I drive mine more aggressively that the next time I get in to go somewhere it is very responsive and aggressive for a little bit while I’m driving normal. Can’t go wrong with either engine though. The 2.7 turbo is a beast , well built engine in my opinion.
On 10/30/2023 at 6:19 AM, dieselfan1 said:
10 mpg from a 6.2????
C'mon man this is 2023 not 1983
My 2023 High Country 6.2 has averaged 18-19 mpg since day one.
My best was a 100 mile run averaging 24 mpg.
I also have a 2022 with the 5.3
and it doesn't get as good mpg
Average of 16-17 mpg since it was new.
Work and back is 80+ miles for me and I’m getting 22-23 consistently with my 5.3 and I’m a crew cab z71 5.3 L84 all interstate though.
Iam getting the same mileage as you on the interstate but I did see 27mpg on a 50 mile average on the dash.
I'm surprised no one has mentioned "Sport Mode".  I use it all the time.  I feel no lag with my 5.3👍
Lou
Edited by lowrider
Lou
I’ve noticed that too. In sport mode it’s a lot more responsive. Thanks for bringing that up
Granted, I've barely made it past 500 miles on the new truck and I do know that the various control modules will take some time to adjust, but I notice NOTHING different from Sport Mode on my truck. :(
On 10/29/2023 at 11:29 PM, newdude said:
Do you drive with your foot stuck to the floor?  Or idle a lot?  Stop and go?  Because a 6.2 will get way more than 10 mpg any day of the week otherwise.  We have a 2020 Tahoe with a 6.2/10 speed in our loaner fleet and in 7,000mi its averaged 19.5mpg.
5.3 with the 10 speed is a great drive.  5.3 is cheap to operate too because it just needs 87 octane.  10 speed fires off shifts and allows that 5.3 to work its power better than the 6 and 8 speeds it had before.
2.7 Turbomax is a great driver as well, especially over the 19-22 non HO/Turbomax ones.  And it too just needs 87 octane.  I have a 2.7 HO and absolutely love it.  More than both 5.3/6 speed trucks I had, a 2018 and a 2012.
6.2 is a blast but 91 octane or higher is a must and that can add up if you are on a budget.
I thought it was recommended to use at least 91 octane in the 2.7 turbos, using 87 will affect mpg's and engine wear and tear long term.
87 is all that's needed.  GM engineered and tuned it for 87.
Nope. This is from the 2024 manual, but same Turbomax engine.
    • Hey thanks yall for the info. It apparently was the key fob - the "reserve" key fob works just fine. Yall were all over it. Great input! JRD
    • I just bought one of these.   https://www.topdon.us/collections/diagnostic-tools/products/artidiag-pro   Yeah, it`s got a cable. $250/year after 2 years. Do I want more? Yep. But, I`m not working any more and can`t afford a whirlpool in my tool box.
    • Why don't I have a good scanner? I've always wanted one when I've needed one.   My latest reading says I don't need to do a relearn on the ckp sensor on a 1995 with OBD 1.5. The relearn is prescribed for the later-model 1995's which shipped with actual OBD II when GM completed the transition in prep for the 1996 MY. I need to confirm that. Did you know forums are disappearing? Knuckleheads on Facebook... it's not the same. It's just not.   So, scanners. Again, shooting myself in the foot for having eBayed my Snap On MT2500 "brick" with all the adapters. Not that I couldn't buy another but those are getting quite old, and mine wasn't new enough to work on 2000's vehicles.   Damn it (as I'm scanning my email between paragraphs here). Did you know there's a 2000 Jimmy 2-door on BaT that's ending this morning? It's local. I want it. 14k miles. Absolutely beautiful.   Back to scanners. MT2500's are old. Solus, now that could be a contender. There's a ~2008 Verus with a system error that's basically new in box for cheap. Hmm...I'm not sure about a scanner that runs an archaic version of windows (95 or CE, I can't tell).   I want the ability to reset and rotate TPMS, test individual modules, bleed ABS, electronic parking brake controls for servicing brakes, relearn procedures and other bidirectional controls.   Snap On does an MT2600. It's a new model as of last year, marketed as their "entry" scanner. Entry? Only where $1900 gets you through the doorway plus, I'm guessing, $1000/year if you wish to keep it current. So goes scan tools actually designed for production environments. Want decent products with excellent support, you pay for it.   Everyone is raving about Autels and TopDons and Foxconns and all these newer brands that are selling the $500 "prosumer" scanners for backyard hacks like me. They're tempting...honestly. Updates are cheaper, base prices are remarkably cheaper... And you get to deal with bugs and translation whoopsies and, well, just don't use it on anything expensive, OK? Having a dealer replace an ECU because it needs to be re-imaged after an adventure in scanning is no joke. But I think most people are getting by OK with these units.   eBay on a scratch-and-sniff pro-model oldie, a shiny new TopDon, or???   God dang it, I can't stop looking at this Jimmy. I'm ready! I'll Bring The TRailer! It's beautiful.
    • I removed the OE running boards.  It looked so much better.  I wish I took them off a long time ago.     I had to put something back on for my wife.  I wanted Westin Sure Grip Running Boards but they are very pricey, like $600 plus.  I was going to go with the Ionic 41's like I had on the 2019 Silverado but went with Westin Outlaw Drop Steps instead, about $200 cheaper.  They are sturdy and functional but not super crazy about the look, but it works.
    • It's all a crock of 💩
