Any ideas on how to clean this black stuff (dirt and dead skin, presumably) off of my leather steering wheel?
I tried meguires leather cleaner and then I tried Bick leather cleaner and didn't really get anywhere.
It's actually not visible under usual lighting. This picture has a bright flashlight shining on the steering wheel.
What color is it supposed to be, brown?  Or black?
Do you use hand lotions or have oiled or greasy or fuel covered hands?  Lots of death gripping the steering wheel?
It’s a 2019. It’s supposed to be brown.
my hands are usually clean with dry skin, but yeah, I do hold it with one hand at the top a lot, apparently.
On my steering wheels this has been the actual leather breaking down from use.
I have bought leather steering wheel covers and hand stitched them on.  They are a pain in the butt ... but look nice.
I didn't use the same stitch pattern that they used from the factory but sewing this on by hand gave me a new appreciation for an OEM leather wrapped steering wheel.
Edited by forest
Ditto what Forest said. Looks like the leather is breaking down. Some of my older motorcycle jackets look like this. I don't think there is any way to restore this. Maybe replace the steering wheel? Be careful if considering Balistol (it smells like sh*t).
The only thing I put on my steering wheel is water on a towel. You don’t want to use an abrasive it wears it quicker. The other stuff makes it slippery. It’s just wearing.
A new OEM steering wheel is surprisingly cheap on rock auto. Depending on trim between $100-200. My 2020 was starting to wear off as well at 100k but I ended up trading it in before swapping wheel. The refresh trucks use a different leather than the earlier trucks.
Stay away from the garbage "leather care/cleaners" they sell at Autozone, etc.  Find stuff called Leatherique.  It has a rejuvenator oil that's applied first, this works into the leather loosening up the dirt, grime, salt, etc.  Then apply the cleaner to remove the grime thus leaving clean, soft leather.
IIRC, it's available online at either autopia.com or autogeek.com
    • Some clarification may help with some of these issues.   - Rev Industries is/was the division of BAK (now Realtruck) that makes covers under the OEM names.  So if you see one with a Ford logo on it, or if you are buying the GM Accessories cover, you are essentially buying a BAK G2 cover with different branding.   - Rev Industries now markets under RealTruck "Advantage."   - As of May 1, 2025, the Advantage covers now have a 5 year warranty.  Anything before that was a 36/36K warranty.   - Parts for the covers are available from Realtruck or BAK.  The email address to reach them is [email protected] or you can call them at 818-365-9000   - If the entire cover has to be replaced, you have to go through your local GM dealer.  Service dept opens an RO, notes the damage and submits it as a warranty claim.  Keep your paperwork handy so they can confirm when you purchased it and it's within the warranty timeframe.  Once the warranty claim is approved, Parts orders the replacement cover.  When it arrives at the dealership, service will remove and install the new one for free as labor is included under warranty.   - The Advantage covers are not the latest and greatest Gen 3 covers.  They still use the old school clamps, elevator bolts, etc...If you want the newer technology, consider buying your cover in the aftermarket world.  That way, if you have an issue you can deal directly with the manufacturer.   - Finally, RealTruck has a program with many of their authorized dealers that doubles the warranty to 10 years if the authorized dealer does the install.     Hope this helps.
    • Welcome to the group!  My '22 just crossed 150K miles.  Runs perfectly.  Oil pump belt will be done in the next 30 days or so and onward hopefully for another 150K.  Love the truck.
