Anyone remember the heated windshield washer fluid on the late 90s trucks?  Wonder why that didnt continue?  There should be a true winter package offered.  Heated oil pans, block heater, heated wipers.  Oh, and dual batteries.  Why cant we get dual batteries?
Too many fires, failures and too many lawsuits.
Bankrupted the supplier, IIRC.
Everyone was recalled and deactivated.
GM Recalls 1.5 Million Cars - GM Recall WindShield Washer Heaters (popularmechanics.com)
If you need/want dual batteries you can get them on the HD trucks.
(std on 6.6 dmax and available on the 6.6 gas.)
2024 2500:
Block heaters are standard on the 3.0 and 6.6 dmax trucks
There are snowplow packages on the HD's
There is a snowplow package for the 1500, but only on some trims
Heated washer fluid was cool but it will burn up your truck. I live in Minnesota where it gets really f**king cold. Heated oil pan and block heaters are a good idea but really not needed in the cold. I would love to have heated seats though.
I would give up heated seats for a heated steering wheel.... FYI I lived in MN until my job sent me to Colorado in late 2014 and I got out of that messed up state when I retired in 2022 (traffic between Colorado Springs and Fort Collins is worse that the Twin Cities metro area).
4 hours ago, MaverickZ71 said:
IF it works. The "-40F" blue crap sold at Walmart freezes at 30 above.
Are you adding the -40F stuff to some sort of summer washer fluid or using only the -40F stuff all year?
Are you mixing it with water or something?  I've used the Prestone winter (gold/yellow color) which is rated to -34F and I've never had it freeze.
  • Thanks 1
Not the Prestone or RainX yellow stuff. The Walmart generic brand-of-the-month blue crap from China. It says up to -40 on the label, but routinely freezes at around +30.  The blue stuff at O'Reilly's says -40 and doesn't freeze until about 15 below. The yellow stuff is better but can be harder on paint.
Beautiful country in Casper. Love to ride in that area.
Frozen in the tank or freezes on the windshield?
Are you SURE it's rated for -40F? A friend had bought some thinking it was winter rated and then looked at the bottle he had and it was only rated for 32F and above. They swap things out depending on time of year, or possibly mix in whatever is on the shelf with whatever they get in.
The first "clue"..... Walmart...... It would have to be a life and death emergency for me to set foot in one of those stores. It's been years since I've gone to Walmart.
I always had my washer fluid (really just water) freeze when visiting Michigan at Christmas. Living in Florida, the dealers just add water to top off the tanks during oil changes. I would try to add real stuff fut it would be too diluted. I had to be careful when using the wipers and carried a squirt bottle of the washer fluid as a backup. Traveling back home it would take me getting into Kentucky for it to thaw.
I just use the orange Rain X -20F year around with zero issues in Chicago.  Works great.  I think the coating alone helps with removing ice.  That said, I have heard of some enterprising folks lengthening the washer pump hose to wrap it around the radiator hose a number of times to achieve some degree of heating and claimed it worked great. I have never tried it.
    • I have a 2000 Silverado 1500 LS, whenever I put it into reverse and also in drive it clunks, the truck also feels sluggish when driving. Any advice/ideas ?
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
