2007 Sierra 1500 Classic 160kmiles
This topic seems to be somewhat covered but I’m at my wits end and reaching out to internet strangers
I screwed up and accidentally topped off my master cylinder with the wrong fluid. Ruined everything and the front calipers would begin to drag after just a few miles.
flushed 32oz of fluid through the system then replaced the master cylinder and booster. I bench bled the master cylinder. Fronts continued to drag. Then replaced the brake hoses and calipers, bled, and the dragging brakes continued. Then replaced the ABS module, had the brakes power bled and the problem continues.
Is there anything left to change, or something I’m not thinking of, or could it be that I didn’t clear all the bad fluid? Every bleeder seemed to be pumping clear fluid.
interesting to note, I cannot recreate the calipers dragging in the driveway. I can pump the brakes, drive in reverse and brake, pull forward and brake and the dragging will not occur, I only happens when I’m out driving for a cpl miles at 45-50mph
the problem presents itself much quicker the warmer it is outside.
Are you sure it's not the brake pads hanging up in the caliper bracket? Rust tends to build up between the anti-rattle clips and the bracket binding the movement of the pads. Another possibility is the caliper slide pins are frozen. Why would you replace the booster for brake fluid contamination?
What fluid did you use?
Could have deteriorated the rubber flex lines or rubber seals in the master cylinder/booster.
On 2/6/2024 at 4:18 PM, Biznessthyme said:
flushed 32oz of fluid through the system .
I went through six quarts to get clear fluid at each corner.
I reckon that the wrong fluid is still in the system and it destroyed everything it came in contact with.
You should have pulled the master cylinder off before flushing the contaminated fluid through the whole system. In a normally functioning system the brake fluid doesn't travel very far into the system when you step on the brakes unless you have a leak or are way out of adjustment. What did you put in that wasn't brake fluid? James is correct , a quart of fluid  didn't flush it completely. Are all the brakes dragging or a single wheel or axle? you should be able to tell by the temperature of the wheels.
Edited by richard wysong
I used (much to my wife’s displeasure) the marinating syringe to get the fluid out of the master cylinder then top it back off with fresh.
the front calipers are both dragging.  Wheels are definitely hot.
The rear drums are warm but the wheels aren’t.
Hmm, Sounds like the master is not returning all the way. Try cracking a bleeder on the fronts while they are dragging and see if they release, if they do then work your way back to the master by cracking the lines before and after the ABS module then at the master and that should tell you where the problem is. If they don't release cracking the bleeders the problem is with the calipers
    • Late reply, but yes—it works on the SLT trim. Compatibility comes down to the plastic shroud shape behind your mirror, not the trim badge itself. On the SLT with auto-dimming, it uses a plug-and-play Y-harness off the mirror/rain sensor power, so no need to run wires down to the OBD port. If anyone's ever unsure about fitment, just drop a photo of your mirror housing and we can double-check it.   Appreciate the detailed feedback on the install! On the windshield glare—we actually took feedback like yours and developed a dedicated CPL (polarizer) filter to cut down dash reflections on sunny days. If you're still running the cam, shoot me a DM. I'd be happy to send a CPL filter over for you to test out—no charge.
    • There are no stickers in your glovebox?
    • Look at the numbers on the stickers in the door jam...
    • Yes, every time the developer updates his code, you must recompile. I will private message you with the latest because it changes pretty much with every version.
    • After I wrote that reply I went for a ride. 85 F out. So trans started at 85 F and it shifted the same as it did an hour latter at 168 F. I've never actually recorded the to cold to shift point but it is under 32 F before they start hanging on to a lower gear or leaving the converter unlocked. Both intended to heat fluid.    Yes, brake or bake. Absolutely.      Your welcome. True research ended decades ago. Field trials are still in play.    There is a thing called oxidation onset temperature. This is the heat related oxidation not the O2 exposure kind. For mineral oil that starts at 140 F. So what happens after 140 F? Each 20 F cuts fluid life in half! Does using a Full Synthetic improve that? Yes! By how much? Depends on the base oil type and a few other factors. But enough to notice. Some esters are even higher. There are even synergies between types the will raise it higher than any one component is alone.    Then there is "Hindered" oils. Antioxidant additives. Hindered Polyol Esters can sit at 500 F for years in a turbine.   When a blender brags his oil will 'take 500 F" in service he doesn't specify for how long. Water will dance on a 500 F hot plate for several seconds. @newdude put up a chart showing the relationship between fluid temperature and it's life in an automatic transmission. Here's a version of that chart for Group III based oils. These temperatures are those in the pan as observed as 'normal'. that is you drive as you do for as long as you do under what load you ask of it and whatever that temperature is this graph applies to. Flash temperatures of a few minutes isn't what his means.    Note that fluids held at a constant 240 F have a service life of only 20K miles. 220 F explains the factory exchange limit, eh? My equipment I keep under 180 F and I'm good if the cooler will hold it as low as 140 F. But that's me.
