On 10/29/2024 at 4:22 PM, Grumpy Bear said:
You might as well ask a magician how the trick is done as to ask a blender what’s in the bottle.
OK, but what's in the box!?
The pendulum is starting to swing back from these low viscosity oils, I think. Maybe CAFE softening up a bit or the amount of warranty claims is becoming unsustainable. Early 5.0 Fords called for 5w20. They quietly bumped it to 5w30 for 2021. And if you add the factory supported Whipple supercharger? The spec becomes 5w50.
Waiting to see if GM will follow suit. Even their non-defective “healthy” 6.2s have no business running 0w20. Not at the oil temperatures I saw on my stock 2019 and not at these OCIs either. In fact, studies have shown increased piston ring and bearing wear when the HTHS viscosity is at or below a typical hot SAE20. And the handful of 0w20s that actually are stout enough in HTHS are niche, expensive and carry no approvals. So for practical purposes they don’t exist.
CAFE is no more.  CARB has been neutered.  Waiting on the passage of HR4117 to cement these changes.
You’ll be waiting a long time. The bill isn’t out of introduction phase in the house.
It was included in other legislation that was to be voted on this month but was removed for reasons forgotten by me.
  • Confused 1
It’s from Facebook so probably a big “if”…but “if” this guy is telling the truth about the oil change interval, that leaves the quality of the oil used, and the viscosity of said oil as two big question marks here. Even the non-wiped lobes on the cam look terrible.
Not saying every truck is eating a cam at 67k miles but I’ve seen enough low mileage failure cases to be highly skeptical of generic 0w20 being run in any full size trucks.
  • Sad 2
This is what you were seeing in Your analysis when I saw it earlier. How’s the reports now?
Instead of politics let’s discuss policy and what car makers DO. NOT WHAT YOU WANT IT to be.
  • Sad 1
2 hours ago, OnTheReel said:
Improvement with miles just as one would expect. Oxidation and Nitration look stellar for this oil which has nearly a 10 nitration background. Oxidation, ditto, near VOA values. Good VI retention. TBN is happy on E85 and begging for some breathing room. Oil is not being stressed. Fuels is what I would expect for the fuel used vs the fuel that was. Identical to my results.
  • Haha 1
Boys we aren’t making meth or spraying nitrogen on fields. No engine oil
has 10 abs units of nitration reading. You are nuts.
Once again catch you “skinning the cat of truth”. Firmly call you on your online BS. THAT ain’t  10 abs. So you are an order of magnitude off. Geebus
I've supplied numerous STLE and SAE articles and equipment vendors instructions on this topic. You can't wish a thing to be true. I'm not suppling more TRUTH from YOUR PEOPLE for you to ignore and confuse people with.
Nitration levels are all over the map. 2 minutes googling others VOA samples. Background matters. It matters to the STLE and the SAE and to the people that make the instruments that measure it. You call me a liar and a fool and whatever else come to mind but it still won't make you right. Make you opposed to your own craft.
Produce ONE single credible source that agrees with this fiction and I'll give it a second look. But until then...fiction it is.
Edited by Grumpy Bear
    • Conditions for Meeting a Cold Start   The ignition voltage is between 10 and 15 V. The barometric pressure (BARO) is more than 75 kPa. The engine coolant temperature (ECT) at start-up is less than 42°C (108°F). The intake air temperature (IAT) is between 2–32°C (36–90°F). The engine is OFF for greater than 6 hours or the following conditions must be met: The start-up IAT minus start-up ECT are within 12°C (22°F). The start-up ECT minus start-up IAT are within 50°C (90°F). Fuel level is between 25 and 75 %.   Circuit/System Verification Verify that all I/M System Status indicators report YES, and that no I/M Test DTCs are present.If any I/M Test DTCs are set Refer to Diagnostic Trouble Code (DTC) List - Vehicle. If no I/M Test DTCs are set All OK. Inspection/Maintenance (I/M) System Set Procedure   Warning: Refer to Road Test Warning. Note: Do NOT touch the accelerator pedal until told to do so. A change in TP Sensor angle or an increase in engine speed may invalidate this portion of the test.   Note: An I/M Test DTC will not be stored or erased from the ECU except at the end of trip processing, which occurs 5 s after ignition OFF.   Ensure that the vehicle meets the conditions for a cold start listed above. If the EVAP I/M System Status indicator displays NO, perform the EVAP Service bay test if applicable. Turn OFF all of the accessories; HVAC system, other electrical loads, including aftermarket/add-on equipment, etc., and open the hood.   Set the vehicle parking brake and ensure the vehicle is in park for automatic transmission or neutral for manual transmission.   Start and idle the engine for 2 min.   Close the hood, release the parking brake and Accelerate at part throttle to 72–80 km/h (45–50 mph) with this speed maintained until the engine reaches operating temperature, 8–10 min.   Continue operation under these conditions for an additional 6 min.   Accelerate at part throttle to 90 km/h (55 mph) with this speed maintained for 2 min.   Release the accelerator pedal for at least 10 s. This will allow the vehicle to enter the decel fuel cut off.   Safely stop the vehicle, with the engine in drive for automatic or neutral with the clutch pedal depressed and parking brake applied for manual. Allow the vehicle to idle for 2 min.   Shift the vehicle to park for automatic and neutral for manual. Turn OFF the ignition and exit the vehicle. Do NOT disturb the vehicle for 45 min.   Observe the Inspection/Maintenance (I/M) System Status with a scan tool. All of the I/M System Status indicators should display YES.   If the EVAP I/M System Status indicator displays NO, turn OFF the ignition, ensure that the vehicle meets the conditions for a cold start, and repeat steps 6-11 three more times, or until the EVAP I/M System Status indicator transitions to YES. If the indicator continues to display NO, refer to the Inspection/Maintenance (I/M) System DTC Table to identify the DTCs that did not run.   If any of the I/M System Status indicators display NO, refer to the Inspection/Maintenance (I/M) System DTC Table for the indicator which did not display YES. The I/M System DTC Table identifies the DTCs associated with each I/M System Status Indicator.   Observe the I/M Test DTC information with a scan tool. Verify there are no I/M Test DTCs present. If an I/M Test DTC is set, diagnose the DTC using the Diagnostic Trouble Code (DTC) List - Vehicle and refer to Inspection/Maintenance System Check.   Observe the engine DTC information with a scan tool. Verify no DTCs are present. If a DTC is set, diagnose using the Diagnostic Trouble Code (DTC) List - Vehicle. After repairs, perform the Inspection/Maintenance Complete System Set Procedure to verify no further DTCs are set.       Looks like one procedure to me.  Repeated as necessary.
    • My 2020 AT4 6.2 has had the valve spring issue addressed at ~200 miles, front cover/pump replaced at 18k, water pump at 34k and idler pully at 65k.  I would agree with ditching by 100k unless you elect to go with upgraded hardware...say built 10l80 and an lt4 or l8p swap.
    • I also need one of your modules for my 1993 chevy c2500 7.4 Thanks! My email is [email protected]
    • Chevy needs to do a black regular cab short box SS model with the new 6.6L.  400SS.
    • You might find the drive cycle you need somewhere on charm.li (website), otherwise I suggest a subscription to alldata.com to get them for your truck.
