On 8/2/2025 at 5:58 PM, customboss said:
it’s apropos  to L87 issues.
key takeaway :
FRICTION ≠ WEAR
use great oil analysis from @Black02Silverado
Lake Speeds SPEEDDIAGNOSTIX is not giving enough FTIR data for the cost.
the methodology rotating disc method RDE at speed diagnostix is superior to ICP method.  you get what you pay for.
  • Confused 1
So here is a question on the effects or the failure of the bearings and how one might tell if they are getting close to the failure point.. As of the last few thousand miles I had noticed my truck was getting slow to start, So I replaced the battery thinking 4 years old sits for a few weeks at a time change battery. No Change in issue.
I went on a trip last week 1400 miles starter always spins fast first start up on a cold start.  Thru the trip on hot starts was like the started was dragging but it always started Ran fine good oil pressure. Could this be an indicator of trouble to come?
The difference of rotrode vs ICP is particle size capability not accuracy. No FTIR no way to see combustion dynamic. You DO get what you pay for. What are you paying ?
At least you get some inside look.
2 hours ago, WeGone said:
I went on a trip last week 1400 miles...
I would guess "no". If a bearing had been starting to go prior to your trip, 1400 miles would have almost certainly done it in.
That is odd. Sounds like something is getting too hot. A mechanical engineer I know said the reason they are switching to thicker oil is because they are afraid of heat. Not trying to scare anyone, but the failures haven't been sudden. They take time to develop. That's why many have had thousands of miles on them before giving up the ghost.
Good news, in your case, is that it seems to run fine once started. If it were bearings starting to seize, it would continue to "drag", to say the least, once it's running. If it hasn't seized and it the bearings have spun, you would certainly know it. Maybe the starter is getting too hot and binding? How many miles on your truck?
Edited by MrLeadFoot
Good news, in your case, is that it seems to run fine once started. Maybe the starter is getting too hot and binding? How many miles on your truck?
Only 17K miles have changed to 40w oil about 2k ago. have not received the recall part 2 yet.
Wow, you don't even drive that thing! I wouldn't think a starter is already worn out to the point it's binding up, but then again, stranger things have happened. But, sure sounds like battery or starter, to me. I would first double check that that new battery is indeed the right amperage and that it is not old, or something.
At least you'll know if it's recall related once you get inspected. I would think they would detect somethimg with the pico test with your symptoms, if it is recall-related.
FWIW, I just got my notice to get inspected, so maybe yours will come soon.
I wouldn't think so. To me it's a starter issue if you replace the battery with  an equivalent CCA one as you took out.  Starters seem to last anymore but there are times that you could have gotten one that is subpar and is going bad and possibly not liking getting heat soaked. Which could cause the slow start.  Make sure to check all your grounds as well. One or so could be loose.
 Issue never changed same with old and new battery. One other thing I noticed was my volt gauge for the last 4 years was always at 14v, The last few months after starting it is a 14v then drops down to 13.8..13.5v.  Even at night running lights...
Edited by WeGone
The alternator is computer controlled and charging goes on and off based on needs and battery voltage. It's not always putting out a constant voltage. It's in the owners manual. If you use the auto-stop-start deal that has always been a concern that that will wear out the starter faster over time constantly restarting the engine vs just leaving it running.
Sorry to get this thread side tracked...My concern was hard start when hot..
Understandable why you posted your initial question on this thread. That said, maybe you should start a new thread. That way your issue doesn't get lost like it might on this recall thread. A new thread might also attract the attention of someone who had a similar situation as you and has a sound resolution.
In the meantime, @Black02Silverado has a good suggestion about checking grounds, as that would indeed cause the same symptoms. He's also correct about today's starters, espcially those designed with auto-stop functionality in mind. Those are specifically designed for super-long duty cycles, with auto-stop frequency factored in. But, starters don't like heat. I remember long ago, an exhaust manifold pipe on one of my cars got so hot I would get the same symptom you're getting. A thermal wrap solved it. I doubt that's your problem, just offering a point of reference.
I've also had vehicles where the nut on the power post on the starter was not as snug as it should be, and the weak power connection got the same symptom. Kind of like when your battery terminal isn't completely snug, and it causes the starter to struggle on its initial turn.
Finally, I've also has starters do what you describe, but they were all super old, and eventually locked up after some time. Since yours is so new, I would check ground and other electrical connections before going after the sarter. It's always a party when you find something as simple as a loose nut.
One more data point....I got my inspection yesterday, it said the engine is OK.  This is a 2023 Silverado 1500, manufactured in Dec. 2023.  28,000 miles, 12,000 towing a 7K pound travel trailer.
    Randy Ginoza
    Randy Ginoza
  • Who's Online   4 Members, 0 Anonymous, 1,993 Guests (See full list)
    • I thought I would use your thread and add to it as I just did my first longer drive with my truck in the last couple of days. I drove from the Grande Prairie area of Alberta down to Edmonton and most of where I drove in the city was the ring road so fairly free flowing but a bit of stop and go as well in the city. Stayed the night and returned home and not too many stops along the way each way but every restart and certainly every cold start sets it back for fuel mileage. Why I say that is I see some people will cherry pick a fuel mileage leg after the vehicle had been warmed up driveline wise before hand and its a forgiving ( easy rolling drive leg for example ) and call that their fuel mileage which can give a false perception of reality. I was not heavily loaded at all but never the less the flip bak cover, rubber bed mat, various tools etc and extra jerry cans of fuel all way up to a few hundred pounds of dead weight so its not an empty truck. The cold inflation tire pressures are set more near the freezing point so once they are warmed up driving I was showing 45 front and over 40 rear and realize high inflation pressures would help a little in fuel mileage but certainly not the ride on our crap sections of highway. The weather was good so was not raining as that can really drag mileage down, in fact I had a bit of a tail wind on average driving home. Most people on here would never have driven on that freeway to visualize it but its got a fair bit of rolling type of landscape with numerous river valleys. For the most part I had it on cruise set to 62 although kicking it off if I caught it in time before it started down shifting and self braking going down the grades. Most of the more substantial grades its shifting into 7th I believe as 8th just doesn't have it. Total distance round trip was 643 miles and my overall average and I did refuel three times in all, figured out to 17.65 miles per US gallon. My best fuel mileage section refuel within all of this figured out to 18.46 and these are all hand calculated figures. I find if anything that the trucks computer can be over optimistic, sometimes its pretty close but other times its stretching it. On paper persay in theory the truck would have just about made it on fumes for that whole drive without refueling once.    Which made me think of the topic thread of the wonder if these trucks could do 20 mpg and that is a good question, certainly would have to be on an easy going flat highway, no head wind, the right temperature, not packing around a bunch of dead weight and puttering along even slower than I was I would suspect and going steady and not stopping to smell the flowers or take a piss !. It probably is possible but not without effort to attain that with the wind resistance and weight of these trucks. Of course on my drive most people are passing me if they have the power as per loaded highway tractors, never mind a lot of speedy vehicles but the speed limit is 68 and most are at or well over that.
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
