On 9/20/2025 at 11:33 AM, bruincounselor said:
Dealer called and the truck failed. He didn't know anything about something to drive for the 1+ months vehicle is not available to me. I called GM customer service and someone will be calling in 1-2 business days with an update.
Wish me luck. This isn't OK.
Any news?
19 hours ago, revrnd said:
She was all fire & brimstone after the Cobalt ignition switch fiasco...
Her goal has been clear, maximum profits for the board. She does not care about GM as a company and it's perception among its customers, and this will come back to bite this company well after she has either retired, quit or been replaced. The damage she is doing right now will never be undone and will be permanent imo!
I just dropped mine off for the test.
Takes all day?
They said they only had one fail so far.
Large Chevy dealer N.W. of Minneapolis.
I'm waiting for the call 📞
Passed.
2023 HC 6.2 56,600 miles.
Then I turned around and talked about trading in for a 26 3500.
They only wanted to give me 42K. Sad. 79,000 sticker new.
They can FO
Not to mention her compensation....
15 hours ago, dieselfan1 said:
Passed.
They can FO
These truck and suv sticker prices are due to them attaching EV losses to them, you all who have bought trucks the last few years are literally subsidizing those who buy EV's. That and the government for many models, and now that the government is out, hopefully for good, I wonder what they are going to do because as you see up above the term FO is becoming more and more prevalent! We are now at 6 figures for upper trim 1500 models which is insanity imo.
I have a '21 Sierra AT4 w/6.2L.  At approx. 55k miles and 5k past previous oil change, low oil light came on.  Took 2 quarts of oil for any to show on dipstick.  After next oil change, low oil light came on after 3,300 miles.  Had it in shop cuz squirrel ate some essential wires.  Complained about low oil issue.  They offered to 'open recall' and perform pico-scope test for L87 propulsion issue.  Test passed.  They changed oil and filter, used 0w40.
Should I expect this to clear the open L87 engine loss of propulsion recall?  If it doesn't clear off my GM account, I'll check with dealer early next week.
They also completed a recall for ECM software update.  Wasn't aware of that recall.
You should get the 10 year 150k mile warranty.
Even if he gets that warranty, I'm pretty sure GM will consider the oil consumption a completely separate issue so they don't have to warranty it under that rod bearings/crankshaft warranty.
Yes, that will clear the loss of propulsion recall.
Not worried about oil burn long-term other than being annoying.  Seems a common problem.  Was helpful in getting pico-scope test performed.  Hoping now it frees the recall so easier to sell.  I'm ready to move on to something else.
They way I see it if it passes how long before it does fail... I sold my 21, did not want to worry when and were I would be when it did fail as I used it for long distance trips pulling a car trailer to shows. Worst part was the loss in value!
What are you going to do now?
 May wait a few years and look into a 2500 until than....Drive my 2000 GMC Sierra, it has never let me down,
Now I wish I hadn't given away my 2000 Suburban after buying my truck.
    • Still $3.01 with even more places at this price
    • There are probably a few threads talking about fuel mileage but this one seemed to fit the stats I have seen based on my typical local driven route but with different outcomes based on different seasons/temperatures. I have a few hundred pounds of items that consistently ride on the truck at all times such as a bak flip cover, rubber bed mat, tools and extra fuel so I would be something over 8100 lb without me in the truck. All these examples are based on a 100 mile round trip to a town plus running around town so maybe 110 to 120 miles in total for a trip. Using regular fuel and I assume it always has some ethanol in it but don't know the percentage they blend in. Also speed wise I am going at 62 mph and non aggressive driving although less speed yet if its crappy winter condition roads. I am going by an initial reset of the computer generated fuel use numbers averaged over a couple of thousand miles or so for each weather/season so they may be more optimistic then actual hand calculated numbers. Basically this is painting a picture of doing the same drive but seasonal conditions and temperature being the major variable to the end result. Oh and although I am in Alberta Canada, I am converting it to miles per US gallon so there is no confusion.    So winter time it gets cold here, no real surprise there and the roads can be clear at times but also often have packed rough snow or are are driving through loose snow ( they do a poor job of plowing the highways ) and yes this includes the extra idle engine time due to trying not to freeze ones butt off. 12.7 mpg is what I was getting during the winter months on average.    Then during the spring when it was around the freezing point and the highways are clear of snow, I was getting around 14.25 mpg.   Summer time, I have been getting around 15.15 on average but certainly some of the trips showed quite a bit better fuel mileage, so much depended on how much or little I had driven around town and number of engine restarts after sitting for a while at each location. But stating a best fuel mileage trip to town pretending that is what the truck gets on average is fooling ones self for sure !.      As I said in a different post, I had driven a 645 mile trip over a couple of days stint to a different destination then these other daily to town examples above, and was done during the summer with nice weather and not bucking a head wind, also keeping at 62 mph and its a rolling landscape type highway drive ( this isn't southern Alberta or Saskatchewan flat lands ) Hand calculated fuel mileage in this case though and it came out to 17.65
