On 10/8/2025 at 7:45 PM, MrLeadFoot said:
What do they give you for a warranty?
GM says 150,000 miles or 10 years from initial service date; whichever comes first. This means I have until 2/2032 - This would be on the bottom end of the new engine. Otherwise I just get the remainder of the regular factory drivetrain warranty (I have under 2 years left).
  • Sad 1
OK, so not different than people like me who didn't get a new motor.
Just curious, how is everything else now that the new motor is i? Anything related get upended? Like, do you have rattles or creaking or anything like that since the repair? Hood, doors and bumper all lining up, and front bumper sensors and all working like they were before the engine swap?
Everything is exactly as it should be. Any less and it would need to be addressed.
That's great news. I am happy for you. One thing I would be afraid of is all the incidental issues that might go along with an engine swap, given all that they have to dismantle to swap motors in these trucks. I know with the Fords the cab is lifted off the chassis, but I think on GMs the front has to come off. So, congratulations!
A few more data points
  • Took my 22 in for the L87 recall to one of the larger GMC groups here in Atlanta - Service advisor said they had several come in broken but they did not have any fail the Pico test
  • He also said that they are going to maintain oil change pricing (@$89 for 6 qts / @$129 for 8 qts) even though the switch to the new super car oil - not sure if same across GM or just this auto group
I have a '22 6.2 ZR2 and I have had a handful of issues with this truck.  I had loss of propulsion issues about a year ago while I was on the highway and ended up thankfully coasting to the side of the road. Took about ten minutes to finally get the engine restarted. Happened one other time after getting it serviced at the dealership and they made some sort of fix and I haven't had that issue since.
My vehicle was part of this recall and I took it to the dealer a little over a week ago and I got the call last week that my truck needed the engine replacement.
The service representative said that they had an engine in stock that they'd be replacing it with so I should get it back sometime next week.
Has about 21k miles.
We have changed 4 engines that failed the recall so far. Another one is waiting to come in and countless other failures before this recall came out. It is tying up 3/4 of the shop with all this engine work. The other guys are busy doing valve bodies or pulling transmissions out to be overhauled. A Terrain engine that locked up is in the works and timing chains on an Acadia are being finished up now. General Motors will have no more customers to screw if they don't start building a better product and start taking care of the customers  that  are suffering threw another failure that GM passes off as Professional Grade. What a joke. The 3.0 liter diesels are also coming in alot with coolant usage with no external loss. We have changed two engines already and both had porous cylinder heads allowing coolant into the cylinders. That is a disaster to work on. Good job GM.
  • Sad 1
I love how they put it "For vehicles not yet displaying failure symptoms, the fix includes changing to a higher-viscosity oil, installing a new oil filter, and adding an updated oil cap to reflect the newly recommended viscosity."
"Not YET"
  • Haha 1
3 hours ago, PunchT37 said:
For your viewing pleasure?
Not sure if I should thank you or not because, based on what they found in this video on both engines, this has me thinking ALL these engines are going to blow at some point, some just sooner than others. In other words, it looks like the journals and bearings are going to wear at an accelerated rate, and we will all experience the issue at some point, and GM is hoping that MOST of them will die AFTER the 150k mile obligation they settled on with the NHTSA. Your thoughts?
Edited by MrLeadFoot
I believe you are correct. Those cranks suck. The chamfers are way too big. Roughness is bad but, how many cranks are worse than that on the many rebuilds that many bring to everyday machine shops? Stock rebuilds, hot rods, etc. Most to all seem to last anyway.
Add 0w20 oil, heat, oil breakdown, general truck duty, etc., and most will have a shorter than normal life.
    Bert 22
    Bert 22
  • Who's Online   2 Members, 0 Anonymous, 775 Guests (See full list)
    • Do you remember that Harley Davidson was more successful (solvent) when it produced about 60% of the market demand (by design) and forced wait times of up to three years? Even when your turn came around it was, "Take what we are giving you or move to the back of the line and start over". HUGE markup's were 'normalized' and dealer killed. 40% markup and no floor plan? What's not to love? Greed will kill them yet. They have surplus production and customer base is tanking. And still they think nosebleed pricing will work.
    • The engine was done as part of the 6.2 recall?   You'd have to see if your VIN also has the 6.2 engine special coverage on it.  Coverage number is N252494003.  If you have this, your engine is covered under this and NOT the GM replacement part engine warranty which is 3yr/100k from the date of install.  The 3yr/100k mi warranty is in effect for non warranty purchases.     This is not any different if it was replaced under warranty without a recall or special coverage.  So if you had a 5.3 and it popped at 3 years in at 50,000mi during the 5yr/60k powertrain, the replacement engine would not get the 3yr/100k, and instead gets the remainder of the 5yr/60k as coverage.     So N252494003 gives 10 years or 150,000mi of coverage, which ever comes first, starting at the vehicle in service date.  So if your in service date is 01/01/2022, N252494003 gives you special coverage of the engine until 01/01/2032 or 150,000mi, whichever comes first.  So if your start date was 01/01/2022, you'd have left 5 years and 4 months (lets round to august 1st), or 62,000mi left of coverage.   So you need to know your in service date to know how much coverage is left.
    • Okiee dokie there bud, way to take things to the extreme.   I guess you missed the whole point and take things way to serious. I installed different EV6 style injectors that just so happen to be larger in my car running the same LQ4 engine and with a better spray pattern than the stock style injectors and I noticed no difference in the idle quality. Kinda was my round about way of saying that even if you put the same size but better style injectors in your truck, you will likely see the same thing.    I'm sure you're great to have conversations with in person if that's how you act through a keyboard. One little things sets you off and now I guess my dick is all up in your face.
    • I can't believe that could possibly be the case. It should be 36mo/100k miles from installation. Then again, it also seems like since a dealership installed it, it'd all be in the system and you wouldn't need to worry about registering, either. Shows you what I know. 😄 Hope this one outlives the warranty!
