1 hour ago, bruincounselor said:
Things seem to be just fine. I'll post here if I have any problems.
Mine failed the pico test at just over 40,000 miles.
Darn, maybe I should have waited will mine hit 40k. Maybe they would have found something at higher mileage. I guess I just continue to sweat. 😉
On 11/13/2025 at 8:42 PM, GETGONE said:
Dealer called this afternoon and had my truck ready to pick up. Passed the test and didn't need to keep it overnight. My appointment was at 11am today and had dropped it off yesterday afternoon. They called at 3pm today that it was ready to go. They changed the oil and flashed the ECM. I had read something about a new ECM program to better detect the issue and set the P016 code. I talked to the service advisor while waiting for them to bring my truck around. He said most of the ones that failed were in the 10-15K miles. Only a few had failed the test. He said most failed while driving. He did say there was one truck that had failed at almost 100K miles.
Well, at least we know the PICO test does SOMETHING. Thank you for the update and details.
Edited by MrLeadFoot
I had the impression the ECM recall was to put in a failsafe for when the 10-speed transmission goes?
TCM controls the transmission, not the ECM.
The invoice lists this:
B N252510321 ECM Software Update Cause:Recall 9107810 Engine Control Module Reprogramming With SPS
That's an entirely different recall.  Reprogramming the TCM (transmission control module) to detect the feed limit low failure before transmission lockup.
This thread is about the 6.2 engine failures.  Those get an ECM flash (engine control module) to detect the P0016 code more accurately and try and detect engine failure before it locks up running.
UPDATE
I was at my Chevy dealer picking up a chrome exhaust tip for my 2026 3500HD today.
I looked in the shop area and saw my 23 High Country 6.2,
( I recognized it because of the aftermarket chrome wheels), that I just dumped end of Sept.
It was in pieces with a new motor sitting next to it. I asked and they said it threw a rod a week after the new owner bought it. 57,000 miles. I knew this was going to be a problem so I got rid of it.
Tell me I'm not smart.
Meanwhile my new 6.6 gasser purrs like a kitten.
  • Sad 3
Dang, bad luck for that guy. I can't believe it passed the pico test then blew up right after. Hope mine doesn't do that! I'm just about to roll 36K
For those that have had the test done, and are "not yet" (according to the recall) exhibiting failure symptoms:
Where do you buy the appripriate 0w-40 for doing your own oil changes, or simply adding oil? Walmart carries Mobil 1  - 0w-40 Euopean Car formula, but I don't think it's the same as the new spec for our trucks. Or, is it?
I keep this in my Amazon cart, but it was too high priced a few months back when I changed the oil in my truck and the Camaro ZL1, so I ended up getting the Amsoil Signature series gallon jugs for less. They offer a standard version for about 30% less for those wanting to save some $.
Edited by SierraStorm21
  • Thanks 1
Thanks for the Amazon link. That's actually cheaper than the Amsoil stuff, and the Amsoil doesn't meet the Dexos R designation, either. The only problem with the Mobil 1 on Amazon is that they sell 6 qts. at a time, when we need 8 qts.
Actually Walmart has it even cheaper and you're able to get the case plus singles there. Regarding Amsoil, it does meet Dexos R according to their website. So I'm not sure where you got that. There's quite a few guys that use it on the Camaro and Vette forums as well so I have zero hesitation in using it in my truck.
  • Sad 1
Rockauto 7.26 a quart
a few other oils now meet the dexos R standard so there is more choices don't have to get the supercar oil.
Yeah it exceeds it. @Black02Silverado can address that. Since it’s defective engine I doubt Amsoil will warranty it. Sad GM.
    tararebecca
    tararebecca
  • Who's Online   3 Members, 0 Anonymous, 538 Guests (See full list)
    • I agree, simplicity and reliability matter more as vehicles get more complicated. A V8 work truck option with fewer electronic features and a stronger warranty would definitely appeal to a lot of buyers who use their trucks for real work. Customizing it with trusted outfitters is often the best way to get exactly what you need.webcrimsNY
    • I’ve heard similar complaints from newer vehicles where the factory “premium” systems don’t always live up to expectations. A good installer should be able to improve the sound without turning it into a bass-heavy setup. I’d look into upgrading the front speakers, adding a quality DSP amplifier, and possibly improving sound deadening first—those changes usually make a much bigger difference than just adding a subwoofer. Hopefully someone local can recommend a reputable installer in the Las Vegas/St. George area.
    • Do you remember that Harley Davidson was more successful (solvent) when it produced about 60% of the market demand (by design) and forced wait times of up to three years? Even when your turn came around it was, "Take what we are giving you or move to the back of the line and start over". HUGE markup's were 'normalized' and dealer killed. 40% markup and no floor plan? What's not to love? Greed will kill them yet. They have surplus production and customer base is tanking. And still they think nosebleed pricing will work.
    • The engine was done as part of the 6.2 recall?   You'd have to see if your VIN also has the 6.2 engine special coverage on it.  Coverage number is N252494003.  If you have this, your engine is covered under this and NOT the GM replacement part engine warranty which is 3yr/100k from the date of install.  The 3yr/100k mi warranty is in effect for non warranty purchases.     This is not any different if it was replaced under warranty without a recall or special coverage.  So if you had a 5.3 and it popped at 3 years in at 50,000mi during the 5yr/60k powertrain, the replacement engine would not get the 3yr/100k, and instead gets the remainder of the 5yr/60k as coverage.     So N252494003 gives 10 years or 150,000mi of coverage, which ever comes first, starting at the vehicle in service date.  So if your in service date is 01/01/2022, N252494003 gives you special coverage of the engine until 01/01/2032 or 150,000mi, whichever comes first.  So if your start date was 01/01/2022, you'd have left 5 years and 4 months (lets round to august 1st), or 62,000mi left of coverage.   So you need to know your in service date to know how much coverage is left.
    • Okiee dokie there bud, way to take things to the extreme.   I guess you missed the whole point and take things way to serious. I installed different EV6 style injectors that just so happen to be larger in my car running the same LQ4 engine and with a better spray pattern than the stock style injectors and I noticed no difference in the idle quality. Kinda was my round about way of saying that even if you put the same size but better style injectors in your truck, you will likely see the same thing.    I'm sure you're great to have conversations with in person if that's how you act through a keyboard. One little things sets you off and now I guess my dick is all up in your face.
