Gmt900 4wd Gauge Light Adapter
I really hated, like a lot of others, that there was no 4wd light in the dash so I was going to just wire up another led and diode isolate it like what was done here:
http://www.gm-trucks.com/forums/index.php?...5545&hl=4x4 light&st=30
But when I took apart the selector knob I discovered the 900's wiring was fairly complicated and adding additional current draw would most likely destroy the control module and the lights were dimmed when dark using a pvm signal so I developed a circuit to drive additional LEDs without damaging the OEM modules. I figured while I was at it I might as well put 2 colors in there so I chose yellow for Auto and red for 4H and 4L
http://www.youtube.com/watch?v=M9zzPDK6sT4
http://www.youtube.com/watch?v=9VCy-4vm-BM
I'm probably going to make this system available through my business with a step by step install DVD. Its about as hard as replacing the gauge faces or a stepper motor. Once it's ready I'll become a forum sponsor to sell them.
What do you guys think about the color choices (yellow vs red, not the color hue, that'll be fixed with the LEDs I have on order).
Also, is there someone in the SF bay area that would want a free one that I could film the install dvd on? I want a virgin truck, mine has reminants of my various prototype iterations.
  • Replies 127
I agree, very cool. I didn't even realize until now that there was a vacant dummy light in the gauge cluster for 4wd....go figure that it'd only be used in the trucks with the manual transfer cases.
Nice work taking the initiative on something that could be quite useful
Ditto on the nice work, red would be fine with me for all :D
I think you're going to have quite a few buyers, I would definately want that functionality if I had 4wd. Looks good. Doesn't make sense that GM wouldn't make that light work with an electronic transfer case, don't they do testing with real people that go "hey, I like this, but that sucks", bean counters strike again.
Very nice... I would definitely be interested as well... With my seating position, and the trans selector in "D", the trans selector acts as a PERFECT obstacle so I can't see the selector what-so-ever.
I think this is a GREAT idea for an add-on product, FWIW. :D
So, how'd ya do it?
Its a sensing circuit that taps into the wiring behind the switch then has additional components to drive the LEDs. For the LEDs it uses the gm lamp circuit which dims all the lights when its dark (everything that doesn't adjust with the interior brighness knob, like the lights the non-green lights in the gauge cluster). The LEDs are mounted in molded plug that fits the cavity inside the gauge cluster.
Price will probably be $90. This is based on low volume but if I get more orders then the price could come down as I order larger quantities of parts. I also chose higher quality connectors because I worked my way through college as a car electronics installer and have seen the problems caused by cheap stuff.
That really is a great idea. When I installed my gauge faces I was stuppfied as to why I had a vacant dummy light. The LEDs on the knob are a PIA to see in the day or the night. Great Job! :shakehead:
    • Thrust bearing is a very small window.  But nice try.   Turbo oil filter?  Haven't seen any failures.  Change your oil more frequently.  Use a better oil than the factory oil.
    • There is a p/n called out in the one PI that GM has.  Curt 57003 inline load adapter that is used for LED trailers that are having trouble with these newer trucks.  No cutting, no splicing, etc.  GM did update the lighting module around 2023 to better pick up trailers with LED lighting, but it still can happen.     Here's the link to the Curt site for it - 7-Way RV Blade LED Electrical Adapter (Not a Wiring Extension) SKU #57003 by CURT   The PI I am referencing - MC-10208985-9999.pdf   Its not just a GM deal either.  Newer Fords and Rams have this same problem.       In another PI, they recommend that the trailer has a Pollock brand 7 way on it as that is who makes the truck sides for the OEMs.  GM is also big on making sure the trailer is trouble free.  So no wiring issues, all lights are functional, better quality 7 way plug, etc.     The other PI I am referencing - MC-10178359-9999.pdf   The model year range is older but it is the current PI for 2014-2026.  It calls out the Pollock RV HD 7 way they recommend.
    • That's part of the problem...the EGR has already been replaced, and I've already had the complete intake assembly removed, and the EGR passages were clear at that time. That leaves wiring, PCM, or another variable that I wasn't expecting. Best I can tell, it's not wiring or the PCM, so I'm grasping for straws.   The PCM uses the MAP reading to confirm the requisite loss of vacuum in the manifold when the EGR activates. Since that's vacuum related, it involves a lot of other systems which could play a role.   The overall diagnosis has to be considered too. The fuel lines in the intake had rubbed through and were dumping fuel into the intake, drowning the cylinders in fuel, and putting raw fuel into the sump and cat converter. The fuel system has been fixed but the complete path of damage may not be. If the cat was damaged and melted the internals, it could be partially obstructed and also playing into the EGR issue.   I'm retracing my steps; trying to go back to thinking thinking Horses not Zebras based on the clues I've been given. These engines aren't *that* complex.   Could it be, now that the truck is running well, that carbon and crud from being run with the fuel system in disarray is now dislodging and clogged my clean EGR passages where I can't see?  That's what the code is actually saying. The flow is restricted, dummy. Retrace step 1.   I may just need to remove the lower intake again. Before I do that I'm going to try removing the EGR and running the engine for a few seconds to see if it will blow anything lodged in the egr passages out through the open ports.     That's been helpful in the past. For the spider injector, there's no guarantee I'll get a working one. The spider I have seems fine now that the high pressure fuel line isn't making an early delivery via large hole. SO at least I'm not marooned and looking for one of those.   Row52 (dot com) is also a good one for watching for vehicles at local yards.
    • Disassembly may be Required!   Every blender makes claims but do  you ponder those claims? What was really said? Was it true?  Motive for saying it? What does in infer?  Is that inference true?    Let's do one.    Claim: Made from shear stable base oils.    What was said: Base Oils are shear proof.   Was it true: Yes.  ALL base oils are Newtonian.    Motive / Inference: To imply the fully formulated product is Shear Proof.    Is the Inference true?: Most fully formulated multigrade oils contain Viscosity Modifiers or VM's, sometimes called VII or Viscosity Index Improvers. There are four types. One is in fact shear proof but it also has a bad effect on extreme cold flow and is restricted to use in specialty oils. A second has limited shear called a 0-5 SSI polymer. Meaning its shear is limited to a range of zero to five percent as reported by the ASTM D6278 Shear Stability Index test. A few high end oils, like Torco SR-5, use them and brag about it profusely. Actually all that use it point it out. The last two shear dramatically and are often marketed as a 'feature' of the product aiding the oil to meet fuel standard requirements of ever stricter rules. One shears more than 5% and the other up to 20%. As you make guess, cost is directly linked to shear down and as such the majority of oils use the cheapest organic polymers sold to make grade and pass stringent tests.    PPD's or Pour Point Depressants also shear a bit, only a few percent and hide inside the 0-5 SSI capabilities.    The blender knows he can not out engineer Stribeck. Physics is not a suggestion. But he can wordcraft the unsuspecting toward believing a false claims INFERENCE. This is LEGAL. It is COMMON, and it is EFFECTIVE.
    • I don't recall ever dealing with one on an '06 and back. It may not even exist on that. I can't remember for sure.   Any kind of ice in or after the evaporator is normally due to low charge with both a clutch-cycling orifice tube system, and a TXV system.
