Lots of good pics in this thread. Guess I'll add mine. This is the heaviest thing I tow on a regular basis. It's a heavy little son of a gun.
Don't have any of the GMC...... yet. But her's my avy LTZ with nova in tow.
My old truck before my parents moved. They weren't going to have room for my baby in storage anymore so I had to bring it up here to my house.
3 weeks ago I had to Tow a 2009 3500HD DD that was stuck in the snow (high elevation in the mountains).
Edited by sc4808
my hitch height was just a little too short lol
This is a 28' Gulfstream Cavalier, AKA a FEMA trailer.
The truck really isn't overloaded, the bed has a decent amount of weight (concrete blocks, generator, etc.), it just looks bad b/c the hitch height is off so the nose of the trailer is pointing down. I pulled it that one time and parked it at the hunting lease, probably never pull it again.
