I made an earleir post with a photoshop concept of this build. Both are factory colors, Iridium (aka Tungston Metallic) on Victory Red. The lower 1/3 is entirely bed liner (Scorpion) color matched and metallic flake added .
Added the GMC Z71 fender badge and auto-fold tow mirrors and leveled it so far. Still to come (back-ordered) are DeeZee full length over the wheel well tool boxes, DeeZee black aluminium, louvered headache rack and I have just recieved the leather upholstery and am about to put in.
In the sun it looks black.
I’m already considering selling and starting over with my first instinctive color combination White on Red. If I keep it, rims and tires will be added.
There is something about the whole design of the Silverado HD that is just...retro ya know? And your two tone just really makes that more so. The wheels, the one big chrome bar, the Z71 grille. And its a reg.cab long box. You sir...11/10. Love it.
1996, 5 speed z71.
first post, I just joined the forum.
gmcsnow%252520001_thumb%25255B1%25255D.j
343000 miles and climbing. needs nothing.
I need to stop egr...but same old routines for my locale.
Welcome to the forum.
Welcome. Good looking truck.
thanks,
I waited and waited...had 5 speed in my favorite searches for quite some time.
I just happen to find a dealers ad on craigslist, and found a previous owner kept after everything.
Drove 190 miles one way just to know I already bought it in my mind, just by photos.
The odometer is comical, used for reference. The rest is repaired as a million mile bread truck. Looks very good indeed.
I am a welder by hobby, restored a ten geared tin can subaru, the truck is a real pleasure, even if a frame rail needed something. This one needs nothing. Straight as an arrow.
it is in great shape, I only found little things, under bed stuff, tire hanger.. make it pretty where no one sees.
My first ride in the snow, wind sideways, very confident. Confident as a modern kenworth.
I feel welcome, been out of the normal sized loop for a long time. this is my fourth 305, and had several other v8s in past machines.
Great truck. I'd only get another one.
Edited by barry G
most recent. need to get my camera on my phone fixed so I dont have to keep stealing my dad's phone lol
FA8AE67A-51D6-4523-80F4-D7BC1C4DF9A4_zps
oh and for giggles. This is 3,250 lbs of Salt, windshield washer fluid, and other supplies. Had to drive it a quarter mile down the road to my place of work. Couldn't push the salt pallet any further up due to the boxes of washer fluid. Poor truck. I had the rear leaves completely flat.
42347D9A-3F70-4FBD-A1CE-CE9E09C87B2B_zps
2004 Chevrolet Silverado CCSB Z-71 4wd - 22,965 miles as of 2-8-2015 - Bought new off the lot in 9-2004, and yes I am proud of my truck!! LOL!!
CCWs2004ChevroletSilveradoZ-714wdCCSB229
2487e62b-49bb-46db-a467-8147984c562e_zps
  • Like 4
Not even 23k miles in 10.5 years? Holy crap! My 14 has 6k miles and it's 11 weeks old tomorrow [emoji23] [emoji23]
The slow Sierra. The gone as of a week ago Duramax. I need to get some recent pics of the 6.2.
    • 87 down as low as $5.14 here... winning!
    • Progress... sort of.   Intake is disassembled, spider is out, fuel lines removed. Used a torch on the stripped screw with the lower intake off, much easier when I've got the intake sitting on my workbench, I made it talk. Walked right out with a pair of vice grips once it was nice and toasty hot.   New parts are piling up on my service cart waiting to be installed. Distributor, temperature sensor, new gaskets, fuel line kit, themostat, water neck.   My new pickle is I don't want to spend $600 on a replacement spider. I'm not sure IT is bad. I'm probably splitting hairs. Or it's $300 to send mine away and another 3 weeks of the truck just sitting. I have half a mind to assemble everything with the old spider to see if I can get away with just replacing the fuel pressure regulator to be safe. The obvious issue was the gushing high pressure fuel line which will be replaced. Getting to the spider really isn't that hard, and now I know what I'm doing , swapping it would be a breeze should it absolutely need one. Stupid, or smart?   The part that gives me pause is replacing the distributor. Well, it's already out. And I didn't mark it, whoopsie! Engine was at TDC when I removed it, I know that, so upon correct reinstall the metal tip on the rotor should point to the TDC mark on the distributor because that's where it was pointing on the old distributor. Worst case I'm a tooth off and have to re-stab it.   But then, what? I assume the truck will start. It doesn't appear the timing can be set. Here's the problem: These distributors can't be rotated but a degree or two, by design. What I read is Cam ****** needs to be -2 to +2 degrees, ideally at 0 (and checked/set above 1000 rpm). There should be enough wiggle to get that properly set, but checking the reported value is another potential issue. My Actron 9185 scanner says it supports enhanced GM PIDs and Cam ****** is one of them but it's unclear that I'll be able to correctly see it over OBD 1.5. I can see why people end up junking these things with life left in them. They're an absolute nightmare with tweener-year diagnostics/electronics and unobtanium parts.   Fingers crossed it starts and idles nicely. There can be hope, right? I'ma buy a lottery ticket the same day just in case.   Next steps..DO IT. I have not installed an intake before so I've been reading and watching a lot. Some say NO RTV except on china walls, some say DO RTV on water ports but not fuel/air intake. 1/4 or 3/8 bead on China walls? I think my strategy will be, obviously, RTV china walls with overlap on the gasket corners. Chapstick-style RTV the water ports. Leave intake ports dry. The only set of intake gaskets I could find locally are Edelbrock performance gaskets (uh...for an asthmatic 190hp V6? LOL) so we'll see how they do.   #NoToolLeftBehind. It took an hour, but my recovery mission for my deep 10mm socket was successful. It had rolled down the bellhousing and wedged itself between what I think are the fuel lines? I couldn't see it at all, but with a junk antenna I had laying around, I blindly went poking/sweeping for it, heard it clink, raised the truck, and caught a sliver glimpse of chrome with a flashlight way up there in Narnia. I had pushed it farther along the lines holding it captive, but within access of severely improvised tools, poking and cursing at it to finally knock it free to where I could get a fingertip on it to bring it home.    Not much to see.
    • Thats crazy considering im right next door (Indiana)
    • For a limited time, retail and commercial accounts receive an AMSOIL Vinyl Tool Tray with their order of $500 or more when they use code TRAY726 at checkout. The promotion runs through July 21, 2026.   Order at https://syntheticadvantage.com   Want to use AMSOIL in your business or sell at your store, apply here.  https://www.amsoil.com/business-opportunities/?zo=521390
