Adding Homelink
I currently do not have an overhead console in my '06. I would like to add one with Homelink. I've added one before on the '01 I used to have without homelink. I just ran power and ground wires for the map lights. Does anyone know what else is involved in wiring it up for the homelink?
No one has installed a overhead console with Homelink in their truck?
I did on my 09 but that is a different body style. Bought the consol off ebay and it went right in - had power and everything. I eventually actually replace the factory "homelink" module (made by Lear which is z-wave) with a true homelink (which is x-10 compatible). There was a recent thread on this. I did it to control the lights of my house but other do it becuase it seems it has better compatability with garage door openers.
Sorry I cant help more..
Ernie
    • probably won't get a response from that user, as they haven't returned to the site since making that one post.  users don't (at least I don't, and I haven't seen any setting which would notify me via say, email) get any notification other than going to this site, and checking if they got a response on their thread...
