I have the newest truck out of alot of my friends so I can't figure out why they need to say the things they do..
Sent from the toilet
Jealousy. Oh and don't forget to wipe
Almost lost my truck to a salt truck driving like an ass and put my best friend of 11 years down today...
Been there before Sarah, it's gut wrenching. Similar situation. 11 year old German Shepherd, Tessa. I'm sorry for your loss.
Sorry for your loss Sarah. My lab was 12 when he passed away almost 5 years ago and I still tell stories about him all the time.
Sorry to hear Sarah. Ive had a crappy yet kinda good day. My wife called me this morning to let me know that her Envoy had been hit and two flat tires, so off I went to get her and see the damage... From taillight to headlight had been hit. To make it worst the guy is from Russia (here for oil stuff) and he leaves for Russia tomorrow. :M16: I swear people lose their mind when there is snow on the ground. On the bright side I got my truck back today! So out to the garage I was tonight to check out the damage some more, put my intake on and install my BB tune oh and to consume some beer in the process.
Trying to put pics up but for some reason its not working...
Edited by dgrinnell
Ive been there too. Been a year and a half since we put down my 12 year old German Shephard and like Zach I still talk about her and think about her every once in a while. Hard to lose a best friend like that
Sorry to hear about that Sarah
Thanks it blows my last German shepherd was around the first half of my life and he was around for the second half of my life as of now. They are so loyal and he always protected me. Idk what I'm going to do now..
But on the bright side my check is big enough so I'm picking up my project trans Sunday.
Sorry for you loss.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
