Black beauty!! What are the specs?
The ride height is perfect right there although I don't know if its because of the weight in the bed.
Edited by white1500
Got that cali lean because of the weight
I don't know what the weight is of each bundle of boxes. The truck sure did ride nice.
This is what my rear tires last look like since getting them in December 2011. I'll have to check the mileage but for some reason I expected for them to wear better. Although I don't have any complaints so far, even in heavy rain they are great.
I forgot to take pics of the front but they look better. The front left is the same age as the rear's but the front right was put on in march 2013.
Latitude tours in 265/70/17
Edited by white1500
Those mileage figures are usually based off wear with regular rotations. But most people with Michelins seem to get tons of miles out of them.
Michelin tires FTW. My dad has the ltx m/s 2 tire and they wear awesome, ride great and handle amazingly well too. Like he has always told me it's worth it to spend a bit extra on nice tires. You're gonna have them for oh so many miles
Sent while in 'Murica...
I'm rotating about every 5-6k miles as suggested. And I do have bad ball joints so that might contribute to the wear.
Cleaned my tires and rims but not sure the exterior b/c rain was forecasted. Instead I gave the interior a good cleaning before the cold hits. And put in my weathertech winter mats...
sent from the bed of my truck
Yeah it could. Today I noticed there are finally some "bites" out of my tires. 16k but they are perfect other than that. And they've seen some abuse.
    Frank V
    Frank V
  • Who's Online   5 Members, 0 Anonymous, 1,209 Guests (See full list)
