Sweet 2016^^.
Ive searched all over. Has anyone tried or test fit a set of mtz 36x15.50r20s? On a 7.5 rcx or a mcgaughys 7-9"??
this im sure has been addressed but
2014 Silverado LTZ Z71 2inch level.
can I run 20x9 -12 with 305/50/20's?
I currently have 20x9+19 with 305/50/20's and no issues at all but I want a wider stance.
I am thinking of going with the Zone 6.5 too. Did you install the add a leaf in the rear? What are your front and rear fender measurements now?
Sent from my SM-T710 using Tapatalk
Measured today all fenders are 45"
Sent from my E6853 using Tapatalk
Thanks man! Just order my Zone 6.5 today. Hopefully, I'll have it installed next week.
I'm trying to do some research on what I want to do to my truck. I originally thought about just leveling out the front, but would it be best if I plan to get a small lift to just do that instead of even worrying about leveling? The most I'd really want is about 3 or 4 inches. So would I just get a lift kit and put 4 inches on the front and 2 on the back to level it out? Also, would a 4 inch lift make the vehicle too tall to clear a 7ft parking garage?
The 4" kit from BDS would be right up your ally. Several trucks on this site are running that. Also the rear lifts with the front but comes out close to level. IMO they look very nice and way better than my truck did when I only had a Rough Country 2.5" level.
Here is my contribution. 2016 GMC 1500 Denali with 6.2L Fabtech 6" Lift, Moto Metal MO970 20x10 -24 wheels.
That looks sweet!
Sharp!
Just ordered the Rough Country 3.5 kit.
Any issues with 20x9 -12 with 305/50/20's?
Yes I had to trim some. They catch in reverse it's tight but not unmanageable. Most trimming was done on the wheel well plastic.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
    • Just don't turn the steering wheel as much?
