Yes much better. I thought the Ranchos up front and the zone shocks where good until i put the Bilsteins on. Way better. Truck feels smother and more panted to the ground.
Nice. I find the ranchos rough. Hitting bumps seem very harsh and the truck almost seems like it's hopping lol. I just want the bilstein struts in the front I don't mind the zone shocks in the rear
Sent from my E6853 using Tapatalk
So I don't have a all terrain. I have the SLT and I seem to have that problem. Do you know how much better the rear zone shocks perform compared to the stock rear shocks?
Sent from my SAMSUNG-SM-G930A using Tapatalk
Its hard to say cause it rides so rough cause of the struts that it's hard to tell how the rear is performing lol
So you wouldn't recommend the Zone lift? It really ride that rough?
Apparently I don't know what the struts are lol.
Do you have Bilsteins in the back as well?
Yes I do.. At first I just changed the front... I was so taken aback on how much better the front felt compared to the rear shocks that a week later I changed them also to Bilsteins.
The rear zone shocks are needed because the length..also they seem the same to me as the ranchos. But the Bilsteins trump them all. I have had all three on my truck with in a months time so thats a pretty good and close comparison window of time.
Thanks for the input man. Yeah my suspension seems super stiff which sucks cause I feel it is taking a toll on my truck. But I don't want to do the lift and tires till my tires are worn down. Not broke but not wealthy enough to do it like that.
2016 6.2L All/Terrain 4x4
8" total lift. Zone 6.5 plus Bilstein shocks set at 1.5" and a 1.5" AAL.
35.5" tires Goodyear Duratracs.
Man what a good looking truck. That blue is sweet man
Do you happen to have part numbers for the Bilsteins..I have the 7.5" RC not sure if it differs much on rear shocks
Sure man. I had to call Zone to get all the specs on the shock that came with the lift kit. Then contacted Bilstien. This is the one I went with for the rear with my 8" of lift.
BSN-33-230382
Do any of you that run the 5-7.5in loft have any troubles getting into parking garages. I'll be living in an apartment that has indoor garage parking soon and don't want to do too tall of a lift and not fit. They told me that the entry height would be normal of that of most parking garages.
My truck won't fit in my garage, 6 inch lift with 35s.
I don't believe you'll have an issue as a normal parking garage height is 10'-12' tall. My truck with a 6" lift and 35" tires is almost 7' tall. I can almost get into my residential home garage.
BSN-33-230382
What about the front part number
    • same here , i have a 2020 first gen and the cost to repair these engines far excedes replacement
    • But Grumpy I did show several subdivisions that had homes starting in the 170K range. If you bought a Townhouse or Condo you could go cheaper. Same with a car 3000 dollars in the 70s translates to around 20K today. There are several models at that price. You actually get more for the money. In the 70s I drove a 3000$ car bought a 28K home and made 4.50 per hour. Thank goodness for overtime. Today I could buy a 170K house drive a 20K car and make 25 dollars an hour operating the same machine today. The difference the house, car, machine would be better and have AC. And I wouldn’t be taxed on overtime. And statistically your wife works too. Easing the burden. I thought we agreed to disagree. I brought receipts earlier, showing examples. I think you’re more stubborn than me. I was done with this debate.
