Sent from my SAMSUNG-SM-G935A using Tapatalk[/
Nice truck!! I think my next truck will be a Duramax on 37s in a few years time. How tall is your truck when measured to the XM antenna?
Some random pics from my phone
Sent from my E6853 using Tapatalk
Hey man what's your specs. Lift and wheels and tire size? Thanks
Yup. 37x12.5r20. 7-9 inch mcgaughys set at 9 with rear add a leaf.
Hey bud. How's the ride. Taken it Offroad any? Any runs or scrubs ? What's the wheel specs?
Zone 6.5 inch with 35x12.5r20 nitto trail grapplers on 20x9 fuels
Sent from my SM-G903W using Tapatalk
Edited by zoomiejr2
Ride is better than stock. Haven't got a chance to get her dirty yet. So far no rubs. Took off the air dam even though it wasn't needed. And took off the rear tire mud flap thing for more space there.
Tires are hostile havoc 20x9r20
0 offset. Will be getting 1.5" spacer probably to push out rear tire to match front width.
It's 84" to the shark fin. Still fits in the garage..... cause I built the house with taller than normal garage height.
Quick hypothetical and sorry if its been answered. I have been looking at the Fabtech and McGauphy's 4" Kit and the RC 3.5" Kit (I know people hate it). All 3 of these are essentially a spacer with diff drop and new control arms....
My question: Would it be legit to leave my bottom RC Spacer in and take out the top (sitting at 2" level up front). Add bilstein 5100 at the mid setting (1.25") for a total of 3.25" of lift up front. Add uni-ball UCAs with diff drop and have a legit 3.25" lift and actually have equal or better angles than my current 2.5" level? You could also set the Bilsteins at 1.8" to give you 3.8" of lift and that would still be within the 4" realm that McGauphy's is offering. Or does that just sound ghetto as hell? Makes sense in theory and honestly think it would ride better than just a 3.5" or 4" spacer kit, just wondering opinions...
Alright gents, looking for some advice! Here is my ride and all the mods thus far:
2016 Silverado 1500 Z71 Doublecab
6.5 Zone Lift with Nitro shocks
20in Fuel Wheels wrapped in 35X12.5X20 Toyo R/T tires
Hypertech 2.0 Tune
Westin nerf bars
tinted windows
Front black bowtie
Shaved emblems
This is my daily driver and im on the highway 95% of my day. Looking for advice on additional mods keeping in mind my commute. Thanks!
Hypertech 2.0 Tune
Westin nerf bars
tinted windows
Front black bowtie
Shaved emblems
ditch the hypercrap for EFI Live. Will make a huge difference
Sent from your sister's house
Is it a flash tune or a piggyback?
canned tune. Really picked it up to calibrate the speedo and didnt want to spend the money on BB or EFI Live just yet.
what do your fenders measure at?
    Randy Ginoza
    Randy Ginoza
  • Who's Online   4 Members, 0 Anonymous, 2,066 Guests (See full list)
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
