On 3/11/2019 at 6:45 PM, Greytrout15 said:
No one here has a rough country 5” knuckle kit?
I don’t have RC lift but I hear the bracket kit is much better than the knuckle kit.
I have the Mcgaughys 7-9 and I have it set at 8 inches
Nice ride man!
Sent from my LG-G710 using Tapatalk
I have a 2018 Sierra SLT and have listed on Autotrader so I can buy a few years older Silverado. I had an older hunting truck and sold it earlier this year. So now I've got an SLT with 36k miles on it that I hate to take onto our hunting property. It's black, so every limb slap will show up and my wife would knock me upside my damn head every time I got mud inside it. Would rather have something I can use as a daily driver and hunting truck, but dang some of these GMCs on here are making it harder for me to sell.
Edited by RecurveBow
So I just want a 2.5" lift/level  for my truck. I was considering the rough country 2.5" leveling (2.5" front, 1" rear). What would be the cheapest suspension lift to achieve a 2.5" lift/level  that I can compare it to?
Install costs where would these two stack up against eachother?
There aren't many lifts (that aren't actually just levels) at that height. You probably won't find anything comparable in cost either.
Next step, at that height you want, would probably be to compare the leveling blocks to a set of decent coil overs and replace rear shocks. The only real difference between either of those level type kits and a "lift" is going to be geometry correction for uca, CV, and mayhaps a diff drop. That said, 2.5" in most cases doesn't require those so it's rarely done.
I would for a good set of coilovers and get the 2.5 out of it. Don’t really even need blocks. Back of truck will be about a inch or so lower.
Hey all this is the rough country 3.5" knuckle lift kit with the n2o shocks front and rear so no need for the strut spacer up front, tires falken wild peak m/t's 305/55/20 wheels are 20x12 -44 truck does pretty well out on some trails and yes i beat the side steps on some rocks. Im looking for some rock sliders but if i dont find anything good I might just make my own.
  • Like 4
Looks good. Also interested in rock sliders, let me know if you find any. I know addictive dirt designs makes something but it's pricey.
Where are these pics taken at?
How much trimming did you have to do to run 20x12's?
My 2018 Sierra 1500 SLT with BDS 4 inch lift and Fox coilover’s 2.5 DSC. BDS rear leaf springs in the back. Rides like a dream. Angles are good. Wheels are 18x9 and tires 275/70/18 (33’s).
I will let you and everyone else know since im sure ill post up here. I had taken these pics on our last trip to bowman lake
    • There are probably a few threads talking about fuel mileage but this one seemed to fit the stats I have seen based on my typical local driven route but with different outcomes based on different seasons/temperatures. I have a few hundred pounds of items that consistently ride on the truck at all times such as a bak flip cover, rubber bed mat, tools and extra fuel so I would be something over 8100 lb without me in the truck. All these examples are based on a 100 mile round trip to a town plus running around town so maybe 110 to 120 miles in total for a trip. Using regular fuel and I assume it always has some ethanol in it but don't know the percentage they blend in. Also speed wise I am going at 62 mph and non aggressive driving although less speed yet if its crappy winter condition roads. I am going by an initial reset of the computer generated fuel use numbers averaged over a couple of thousand miles or so for each weather/season so they may be more optimistic then actual hand calculated numbers. Basically this is painting a picture of doing the same drive but seasonal conditions and temperature being the major variable to the end result. Oh and although I am in Alberta Canada, I am converting it to miles per US gallon so there is no confusion.    So winter time it gets cold here, no real surprise there and the roads can be clear at times but also often have packed rough snow or are are driving through loose snow ( they do a poor job of plowing the highways ) and yes this includes the extra idle engine time due to trying not to freeze ones butt off. 12.7 mpg is what I was getting during the winter months on average.    Then during the spring when it was around the freezing point and the highways are clear of snow, I was getting around 14.25 mpg.   Summer time, I have been getting around 15.15 on average but certainly some of the trips showed quite a bit better fuel mileage, so much depended on how much or little I had driven around town and number of engine restarts after sitting for a while at each location. But stating a best fuel mileage trip to town pretending that is what the truck gets on average is fooling ones self for sure !.      As I said in a different post, I had driven a 645 mile trip over a couple of days stint to a different destination then these other daily to town examples above, and was done during the summer with nice weather and not bucking a head wind, also keeping at 62 mph and its a rolling landscape type highway drive ( this isn't southern Alberta or Saskatchewan flat lands ) Hand calculated fuel mileage in this case though and it came out to 17.65
    • 2024 Chevrolet 2500 HD Custom 6.6 Gas Canadian built Truck  I tried to search for my previous thread on this topic but cant find it so my apoligies  for starting another one    #1   Since we have owned our truck purchased new it has this strange noise after using the remote start function  you press the remote start and you hear it start but right at the end of it starting it almost seems like it wants to start again after the truck is running .   There is no gap in time it is right at the end of the start . Almost sounds like when you have started a car/truck and its running and then you try and start it again and you get that grinding noise ,sort of     #2  You can only hear this if you are standing outside of the truck and near the truck  you cant hear it when you start the truck from inside  the cab . So it may very well be happening when starting the truck that way as in normally    #3   This only happens when it is started after sitting . For how long I don't know but it happens after sitting overnight for sure and it wont do it if you stop the engine after starting and then start it again  I have had it in to the Dealership before concerning this but they did not have the truck  when it was cold to hear it . Now its back in the Dealership left it overnight so they could possibly hear the problem . They said they tried and nothing happened . Well they did not know what they were listening for . I started the truck remotely and BINGO it makes the noise . Oh that sounds weird they say . We need to look into it ! I have left for this week at the Dealership    Does your 2024 2500 HD gas do this ?  Any of you fellas care to take the time and trouble to film this operation from a cold start  so I can hear what your sound like  Really  would like to know if this is anormal sound  Thank You Fellas !!
