New to the fullsize game here. I personally drive a Tacoma but my dad picked up '14 Denali and I am trying to piece together a quality lift for him. It really will only be seeing street use but needs to be reliable and comfortable if the going gets tough. He is deadset on running 35's and wants as little lift as possible to clear them. I like the BDS 4" kit but want to upgrade the coilovers and rears for something like Fox, King, or Icon. I know on Tacomas Icon makes custom coilovers to fit with a drop bracket lift, do any of the reputable companies provide an option like this that would work with the BDS 4" kit? Are there any other companies I should look at that I dont know of? Thanks in advance.
if you order a Bds 6in with fox coilovers they are adjustable from 4-7inches of lift. I just got my kit and it's getting installed this weekend I will be adjusting it down to 4-5in with stock 20in wheels and 35s
Can you elaborate on that? I assume you're talking about the adjustability of the CO but if it's a 6" drop bracket then how are you able to go under 6" of lift? Wouldn't it be good for 6-9"?
Just got off the phone with him and the off road shop talked him into a Fabtech 6" kit with Fox 2.5" Coilover and rear Fox 2.0". I'm okay with the Fox parts as I know they are good quality but I am unfamiliar with the Fabtech kit. Any input on this kit?
I'm running a 6" Fabtech with 35's, no rubbing and no trimming. The kit is well made and the components are high quality. The only negative is the design of the drop spindles. Just a heads up, you will lose some turning radius due to the spindle design. I've gotten used to avoiding u-turns and tight parking lot maneuvers can be a little challenging. Just something to keep in mind when making your decision.
Edited by bkdR1
The BDS 4 and 6in kits are the same except for the struts length and rear block size. With the Fox CO upgrade they come preset at 6in. The drop bracket is 4inches. So with 6inches of lift the cv's will have a slight angle. Set at 4 inches the CV will be at the stock angels.
Why would you wanna sell the truck!?
I drive a lot. April made 1 year I've owned the truck and I have 34K miles on her and to be honest I don't use the truck as a truck as much as I use to or would for the past 3 years. Mainly a people carrier and snow wheeler and occasional fishing/ trail off roader
6" bds with leaf spring and fox shocks. Still waiting on my 20x9 hostile exile wheels.
Did you need spacer to fit the tires on stock wheels?
I have the 7.5" rcx kit on my 2wd silverado but it still has front rake on the truck.. Has anyone added a leveling kit to a lifted truck before? I like the height in the back so I dont want to drop it down
IMG 0814
IMG 0812
IMG 0813
6inch BDS Fox coil over lift with replacement leaf springs stock 20x9 and Mickey Thompson ATZ p3 tires 35x12.5
Edited by Payton34
  • Like 4
Installed Pro Comp 4" Lift. Chose this lift because there wasn't modifications to the suspension and would not void the new truck warranty. I've put 3000 miles on this lift and have never had a problem and truck's ride is still great. 4 Wheel Parts installed this lift and said I can go up to 35" tires without any problems.
http://s300.photobucket.com/user/philwhall/library/Fender%20Flares%20and%20Side%20window%20deflectors
Okay I'm having a real hard time choosing a lift here...
I was set on the Zone 4.5" because they are a sister company to BDS, people talk highly of them and it seems like a quality kit. I've always thought Rough Country is garbage because people just don't have good things to say about them. I just don't understand how Zone and Rough Country are the same price when apparently one is so much better than the other?
I don't want a 6" lift, because they are so overdone on trucks they don't even stand out anymore to me. I also think 6" is the size trucks start to look ridiculous.
So... I'm looking at 4", 4.5", and 5" lifts. I don't want anything higher than 5". I don't want to spend $2000 for a lift, that's absolutely insane. Right now I'm looking at the Zone and Rough Country... can anyone give me any tips, or if anyone has these lifts, give me their experience?
Edited by Habs
So this may have been already answered, I looked through the thread but 84 pages is alot.. Is the RC 3.5 lift still not good? And if I do that would I have to get new tires or is it safe to keep the stock ones? I am looking to just get a better approach angle, but not spend alot of money. Thanks!
I'm was running the zone 5" kit on my 15 Sierra HD. High quality kit for the price with nice welds. Zone is a sister company of bds and some of my parts do have bds engraved on them. But let me warm you, and I'm sure many others will agree, go big the first time. I had my zone kit installed for about 2 months running 35s, then wanted 37s but couldn't clear them without major bumper trimming. So then I ordered cst 8-10" lift. About $6400 on lift alone when all said n done. And like you, I didn't want to go bigger than a 5" kit, I thought I'd be good with just leveling it.....
82c3e7f6055cb3396805de2690d50f9e.jpg zone 5" on 35s
  • Like 3
    Frank V
    Frank V
  • Who's Online   4 Members, 0 Anonymous, 1,193 Guests (See full list)
    • Folks, Have a great new 2026 WT  (std cab, 2.7/4WD) w/base 40/20/40 mech adj bench "fake buckets"  (with lower and upper center console) heavy vinyl seats.  Overall the seats are very comfortable and the vinyl is heavy and appears less likely to 'split out'. Am very tall (6'5")  + a bad back/osteporosis/former hyperparathyroidism so ease/range of movement is a bit restricted.  The truck rides a bit high and I use a nerf step bar w/my left foot to step in, then I put right foot/leg in, drag my butt in  & get seated.  Worked fine in my 2018 RAM quadCab. But I end up dragging my butt over the left raised sidecushsion area of vinyl seat, and due to texture there's fair amount of traction on slide inward.  (ArmorAll didn't improve.) If the seat were even ~1/2" - 3/4" lower it'd be helpful, but base seats just have the forward/backward underseat bail and the side lever for tilt which really doesn't affect seat height.   I really don't want to 'de-puff' the left side sidecushion forming the  fake 'bucket'. I know one company sells 'seat elevator blocks':  but is there a simple way of lowering the height of the driver seat instead?   Thanks Bill W San Jose
    • I have a basic 2026 1500 WT  (2.7L/4WD reg cab shorttbed). Comfy, generally happy with electronics/radio - but is there a way I can add switches to steering wheel right-side position (curr. empty) so I can adjust volume, push phone button to voice dial, etc? Bill W San Jose
    • The curb weight on a 1 ton crew cab long bed is around 7k lbs.  Now, I don't know where you went to school but 9k is not more than 2x 7k lbs. More than 2x 7k lbs would be 14k+.   With that said, obviously yes you're going to feel a 9k lb trailer when slowing down.  I already said, when accelerating.  When changing lanes?  No.  But if you look at the context of what was quoted, the original person said, "after a mile or two..." which means that would be after the accelerating portion and you're driving a generally steady pace.  Please do learn to read and comprehend.
