Did the BDS kit increase your track width? And if so did you install wheel spacers to correct it. I've been looking at the photos of your track and can not tell.
Yes it increases the front the tires stick out 1- 1.5" the rear are flush with the body I didn't want to use spacers
BDS 6inch coil over system
20x10 DPR tech-9 wheels -24 offset
35inch Cooper STT
Tires are rubbing the black plastic fender linings pretty bad any suggestions ? I don't really want to remove them because I like the look.
Same exact setup as me except I have 13.5" wide tires. You'll have to do a lot of trimming. I ended up trimming the front bumper, trimming the front of the wheel liner, removing the valance, trimming the metal in the rear of the wheel liner, trimming the rear plastic guard and pinning the rear section of the wheel liner back. It was a lot of work but when done right it looks stock and great! This week I'm also adjusting my coilovers another inch may go two inches and then add a 2" block in the back to replace the stock 1".
Sent from my SM-G900P using Tapatalk
Got rid of the leveling kit
Nice truck! What tire/lift combo are u running? Also like the color matched bumpers.
Thanks. Zone 4.5 and still running the same 295/55/20 toyo at2s and xd hoss 20x9 +18 offset I had with the leveling kit. The lift pushed the tires out about 2 inches for a nice stance.
2014 Sierra 6.2
6" BDS Fox coil over and BDS rear leaf springs
Mickey Thompson ATZ p3 35x12.5r20 stock wheels
Bro I have the same truck and love ur setup especially with stock wheels how did u make that happen spacers do u rubb? How's the ride
no rubbing no spacers there is plenty of clearance with the stock wheels, ride is little firmer but due to the tires. I drove 30miles after the lift was put on with stock tires and ride was much much smoother especially on rough roads. Once the 35s went on the ride got firmer and rougher on bumpy roads but all 35s are E rated. I would rather have a D rated tire for smoother ride. The BDS rear springs are firmer than stock but they are continuing to soften up a little.
I have 18x9 wheels with +18 offset/ 5.75" backspacing. Can anyone confirm whether or not I can use these wheels with Zones 4.5"/6" lift?
I contacted BDS and was told that offset would work with BDS's kit as long as I didn't go with 12.5 wide tires.
Nice good to hear does ur lift fit for 2wd and if not does bds make for 2wd??
With all the upgrades and suspension geometry changes you guys have done, has anyone upgraded the tie-rods? The stock ones seem wimpy enough for a stock half-ton let alone a lifted truck with 33's or 35's. I've been searching for a good hour now and the few HD tie-rods I've found for GM half-tons say they aren't compatible with our electric steering for some reason.
Edited by HondaHawkGT
So I recently put the Mcgaughys 7-9" kit set at 8" on my truck and so far I love it, nothing bad to say about it yet. When I received the lift everything was great quality and also in great packaging along with color instructions. I was wondering for all the people running large lifts 7" plus what are you doing about shocks and struts? I am looking to upgrade the rear shocks and maybe install front coilovers but am having trouble finding shocks that are for 7"+ of lift. If anyone has any companies or links to find them that would be great. Thank you
Sent from my XT1080 using Tapatalk
Nothing much out there.
http://www.gm-trucks.com/forums/topic/170502-tie-rod-upgrade/?do=findComment&comment=1590558
Edited by 14x4
Icon vehicle dynamics can custom build their shocks for whatever length you need. I had a custom set of coil overs built for my truck with a 4.5 inch lift. Pm if you want some details
    • Jumped up 15 cents yesterday. $4.15
    • I have never seen GM instructions for the other trucks as per the HD with the 6 speed or the half tons but had got the impression that the HD trucks with the 6 speed were not having the same problem that the 10 speed and pan presented. Also video that I have seen of the HD 10 speed with the gas engine starting in 2024 model year showed that it was a real struggle to even make it work when pulling down hard on the exhaust after undoing the exhaust hanger bracket on the side of the transmission as after all there is little room for the pipe to even go down behind the Y joint as it soon would hit a frame cross member. Also that they had tried just like I did with the gasket off and no way was that pan coming out any way they tried to manipulate the pan. From that as well as the local transmission shop talking about the pain in the rear issue, I was not expecting my pan to come out because GM shows it was not even intended to come out without dealing with the exhaust piping.    It would be nice to claim, here's what you do and its easy to remove the pan guaranteed on any HD truck with the gas 10 speed but dollars to donuts the next guy trying what I did would not have the same luck as the exhaust was just manufactured slightly different and be pissed off at my claim that the pan comes out with no issue. Its more of a try and see if your particular truck might work like mine did .... or not !.
    • Sorry I didn't see this until now, but it works on both the 6 speed and 10 speeds, as well as all the half tons too.
    • Hello, I have a 2018 GMC Sierra 1500 that I recently changed both motor mounts on due to the driver's side being blown out. After replacement I seem to have a steady vibration that I can feel in the pedals and the back of the seat. At this point I'm convinced that the aftermarket "Anchor" branded mounts I used are not performing as well as OE, the only real reason I ended up using the mounts in question was because my local dealers were out a few months to get a Driver's side mount. I've tried "Neutralizing" the mounts according to the motor mount TSB published for these truck to no avail. My trans mount is also in great shape and seems to be absorbing vibrations swimmingly. As far as I can tell there is no issues idling, my idle RPM is steady and I've recently put GM plugs and wires on, however, I have not cleaned the throttle body or intake valves. Any one else have a similar experience with aftermarket mounts? Patience certainly is a virtue that I wish I exercised here. Thank you!
    • I still saw people out for runs, on their bikes/motorcylces, jeeps with the doors off driving around here the past 2 days. I guess we are just used to it here haha.   Tasted like a bonfire the last 2 days.
