ive been testing 93 octane in my 6.2 however i'm seeing terrible mpg. i do all city driving, and its around 13.9 and has brought my lifetime down to like 14 or 15.
are you the first one to take off from a red light? If so that's why the mileage is so bad.
Sent from my iPhone using Tapatalk -
You can't just blame driving style. I had a 5.3 with 3.08 gears and my lifetime over 9000 miles was 14mpg. I would drive with the full intention of getting the best fuel economy possible, but it just wouldn't do it. It did have some good moments here and there, but when I went to a diesel 2500 I broke all my mpg records from that 1500.
It's a shitty problem to have because the dealers won't help out because it's easy to blame driving style.
Sent from my SGH-I337M using Tapatalk
I drive on the hard side and don't speed, don't need to in Texas speed limits are high. Im most often first to leave the light, my lifetime average on E85 and some 93 is 16 MPH. Most would be in town.
Edited by KARNUT
I hope you're in the slow lane
On the freeway its the Texas speed limit, go with the flow or get out the way.
Not sure how yours was so low. Did you keep the tires properly inflated and all the other jazz that they say is necessary for good mileage? My 5.3 3.42 4x4 CCSB has had great mileage. My lifetime is 16 mpg. With about 85% of that being city and 15% highway. And about 20% of my overall has been with a lead foot cause it's nice to hear the exhaust!
Tires were fine and I was 70 percent hwy. I towed a 6x12 enclosed trailer once for 100 miles and got 6mpg.
MPG* The speed limit is over 16 in Texas.
Thanks, I know C~, MPG MPG MPG MPG MPG , Got it. Teacher can I go home now? MPG MPG MPG
Man I don't know what some of you are doing to get such low numbers.
DIC shows almost 20mpg, 25 mile average shows 26mpg, 50 mile average shows 22mpg, 400 mile average shows almost 20mpg. My hand calculated mileage shows anywhere from 18.75-20.5mpg on my weekly commute.
That's about spot on what I am seeing with my 6.2. It has settled into 18-19 on my normal weekly driving and if I can get out on the freeway for any amount of time it puts me at 20-21mpg.
What milage are you guys getting with the 5.3 ? I have a 2014 Sierra 1500 All terrain 20" wheels 5.3 4x4 Stickers epa said 16 - 22 I get 16 city and MAX 19 Hwy.....that 22 must be on a dyno at 40 mph.....
Sent from my SPH-L720 using Tapatalk
EPA sticker on mine said 21 hwy. but I've seen 22-23 cruising between 70-75MPH (not drafting btw, but when I do I get 25MPG). City I can get 16MPG if I play it easy.
I've got right around 4600 miles on the truck. CCSB 4x4 with factory wrangler street tires. 275/55/20 5.3L with 3.42 gears.
Mine used to get around 18-19 mpg hwy. when I bought the truck I got 15-17 on the hwy drive home. But mileage seems to be getting better with more miles.
    • 87 down as low as $5.14 here... winning!
    • Progress... sort of.   Intake is disassembled, spider is out, fuel lines removed. Used a torch on the stripped screw with the lower intake off, much easier when I've got the intake sitting on my workbench, I made it talk. Walked right out with a pair of vice grips once it was nice and toasty hot.   New parts are piling up on my service cart waiting to be installed. Distributor, temperature sensor, new gaskets, fuel line kit, themostat, water neck.   My new pickle is I don't want to spend $600 on a replacement spider. I'm not sure IT is bad. I'm probably splitting hairs. Or it's $300 to send mine away and another 3 weeks of the truck just sitting. I have half a mind to assemble everything with the old spider to see if I can get away with just replacing the fuel pressure regulator to be safe. The obvious issue was the gushing high pressure fuel line which will be replaced. Getting to the spider really isn't that hard, and now I know what I'm doing , swapping it would be a breeze should it absolutely need one. Stupid, or smart?   The part that gives me pause is replacing the distributor. Well, it's already out. And I didn't mark it, whoopsie! Engine was at TDC when I removed it, I know that, so upon correct reinstall the metal tip on the rotor should point to the TDC mark on the distributor because that's where it was pointing on the old distributor. Worst case I'm a tooth off and have to re-stab it.   But then, what? I assume the truck will start. It doesn't appear the timing can be set. Here's the problem: These distributors can't be rotated but a degree or two, by design. What I read is Cam ****** needs to be -2 to +2 degrees, ideally at 0 (and checked/set above 1000 rpm). There should be enough wiggle to get that properly set, but checking the reported value is another potential issue. My Actron 9185 scanner says it supports enhanced GM PIDs and Cam ****** is one of them but it's unclear that I'll be able to correctly see it over OBD 1.5. I can see why people end up junking these things with life left in them. They're an absolute nightmare with tweener-year diagnostics/electronics and unobtanium parts.   Fingers crossed it starts and idles nicely. There can be hope, right? I'ma buy a lottery ticket the same day just in case.   Next steps..DO IT. I have not installed an intake before so I've been reading and watching a lot. Some say NO RTV except on china walls, some say DO RTV on water ports but not fuel/air intake. 1/4 or 3/8 bead on China walls? I think my strategy will be, obviously, RTV china walls with overlap on the gasket corners. Chapstick-style RTV the water ports. Leave intake ports dry. The only set of intake gaskets I could find locally are Edelbrock performance gaskets (uh...for an asthmatic 190hp V6? LOL) so we'll see how they do.   #NoToolLeftBehind. It took an hour, but my recovery mission for my deep 10mm socket was successful. It had rolled down the bellhousing and wedged itself between what I think are the fuel lines? I couldn't see it at all, but with a junk antenna I had laying around, I blindly went poking/sweeping for it, heard it clink, raised the truck, and caught a sliver glimpse of chrome with a flashlight way up there in Narnia. I had pushed it farther along the lines holding it captive, but within access of severely improvised tools, poking and cursing at it to finally knock it free to where I could get a fingertip on it to bring it home.    Not much to see.
    • Thats crazy considering im right next door (Indiana)
    • For a limited time, retail and commercial accounts receive an AMSOIL Vinyl Tool Tray with their order of $500 or more when they use code TRAY726 at checkout. The promotion runs through July 21, 2026.   Order at https://syntheticadvantage.com   Want to use AMSOIL in your business or sell at your store, apply here.  https://www.amsoil.com/business-opportunities/?zo=521390
    • It wouldn’t have happened if the government hadn’t mandated outrageous fuel mileage standards. It does very little for the consumer. It adds cost. Back during Covid there was a chip shortage. They gave a rebate for your truck if it didn’t have the chip to turn on cylinder deactivation. It was 50$ because at best you may see 1/2 a mile increase per gallon. Splitting hairs each fuel mileage trick wasn’t mandated. The government doesn’t do the engineering work and say use this until it’s already in use and they like it. The fuel mileage was mandated. And those add ons the results. There’s a mandate and they are the results.
