On 2/9/2020 at 3:22 PM, David Roark said:
Best does not count.  It is the average that counts.  And if it is like mine, I have lost about 5-6 MPG the last 2 years with this direct injection engine.  The more miles you put on, the carbon build up you will have and the worst milage you will get.
Not true. This is my 2015's trucks first 100,000 miles for each 10,000 miles driven. Hand calculated. Green bars were over winter months. Looks like she's still gaining to me.  I've done no intake cleaning. I have no catch can. I run some injector cleaner via the fuel tank once each 5,000 miles. I burn any E-10. (Red Line SI-1 two bottles in one 26 gallon tank). I'm almost done with the next 10 thousand miles and it has dropped a bit as I've decided to increase my average speeds about 7 mph. Mid 26 mpg range.
People keep telling me the Sky is Falling.  :) Maybe some day she will embarrass me but until she does...…..
I just finished installing the same airaid tube this weekend,  at first it was alright.... then i went back and popped the airbox out and removed the air intake restrictor panel, it pops out so easily,  now it really sounds impressive. my MPG probably dropped  by 2 points, but it was fun and feels much quicker now. I'm also using the OEM airfilter.
What restrictor panel?
its at the inlet side of the airbox. you need to pull the airbox to release it and remove
i should of installed my obd2 scanner and did a before and after on the CFM and MAP sensor just to see if i made any improved airflow, next time
Edited by flyingfool
Folks -
2014 GMC 1500 SLT
I have seen my mileage decrease - not sure if it is because I have switched tires from factory to Cooper SRX tires.
Is  there any safe additive I can add to my gas to clean the fuel injectors instead of having to have them provide that service at the dealer?
I used to get between 18-20 mph on the last 50 mile tracker - now it is hovering 16.
Thanks in advance for any info.
JJ
Edited by johnnymordoc
I cannot believe the mileage some of you are getting. I have a 2017 crew cab, 5.3, 4x4 with max trailering package and 3:73 gears. I was struggling to get 14-15 mpg on stock size tires. I just put LT275/70/R18’s on my truck, and I’m getting closer to 12-13 mpg. I’m driving like a grandpa! This mileage included was before I installed my new tires. This is one thirsty truck.
Edited by Joe Wayside
Yeah, that is what my MPG looks like.  The more miles I put on the worse it gets.  I blew $220.00 letting them put chemicals in manifold to get deposits off.  Did not work.  Waste of money.  Looking for someone to blast it with walnut shells.  Otherwise, I am trading it and going to a Ram port injection e-torque engine.
Just got home from taking the family on a trip to New Mexico for Spring Break. Got some impressive fuel economy during a flat low super stretch. 2018 Sierra Z71 6.2L crew cab 6.5’ bed with an eBay intake, muffler delete, & cheap bed cover as the only mods so far. I’ve been using the highest octane available at the pump which ranged from 93 locally to 90 out there.
Down the road you’ll regret that purchase. As with just about every engine, that engine has its own forums featuring its negative attributes. I’d repair what you’ve got and keep it and this time add an additive every couple tank full it’ll help avoid future issues. I swear by Lucas Fuel treatment, helped with my 16 Yukon with rough idling, my 18 6.2 with 33k miles and still purring like a kitten.
Sent from Above
What was your average speed? My trip from Texas to New Mexico/ Arizona I’m at 80+ [emoji6]
Sent from Above
3 hours ago, TXGREEK said:
What was your average speed? My trip from Texas to New Mexico/ Arizona I’m at 80+ emoji6.png
Sent from Above
This was during a slow stretch on the way home.
Took my ‘16 5.3 crewcab 4x4 from NY to FL a few weeks ago. It was in the 30s when we left and 80s when we arrived. My mileage increased directly with temperature, from mid 18s up to 23 mpg. Mileage increased roughly 1 mpg for every 10*F in air temperature; temps stayed in the 40s until SC as did my low fuel mileage, which helps take “winter fuel” off the list of explanations, leaving stoich and air resistance as the main reasons. With no one on the road, the truck was stuck on cruise control at 72 mph the entire trip; I went a full 450 miles without touching the brakes, slowing down only for off ramps. Best highway trip I’ve ever taken, and perfect conditions. This was on 87 octane. Back in January, headed North from FL to Norfolk, we hit a best tank average of 26.5 mpg, with the cruise set to 67 mph and 89 octane. That same trip saw almost 24 mpg on 89 doing 72 mph from the Treasure Coast to Key Largo and back. Down here in FL right now I averaged 18.5 mpg around town on 87, the current tank has 89 to see if the juice is worth the squeeze. The truck currently has 87.5k miles and has never had a valve or upper engine cleaning, other than some MMO in the oil a couple times.
Edited by 16LT4
My 2020 AT4 5.3L is really impressing me.
Computer average over 400 miles.
Calculated with Fuelly at every fillup.
Both were taken today when I filled up. Obviously the DIC is a little generous. But I was pretty stoked to hit 21.4 as it has been steadily rising with the warmer temps.
On 2/27/2020 at 8:22 AM, johnnymordoc said:
Folks -
2014 GMC 1500 SLT
JJ
Yeah. Chevron Techron fuel system cleaner is the safest bet.
Techron is one of a handful of injector cleaners using the PEA additive and it does work at a high enough dosing rate.
Red Line S1 is another as is Gumout Regane. Red Line has a white paper on their site worth a read. I believe it has some instruction on dosing for motors that have never had the injectors cleaned.
    • Google converting 98 4.3 spider injection to carburetor if all else fails.
    • That computer lies!
    • The truck is a 1995 Chevrolet S10 Blazer, 4.3 VIN "W" engine. :cracks knuckles:   On a whim - because I needed a headache - this truck was for sale so I stopped to take a look. Doesn't run. Well, it does, but barely. Long crank, choppy idle, bad misfire(s), it REEKS of fuel. I can DO this..I'm thinking. Diamond in the rough. One owner until last year. A young guy is selling it, he bought it 6 months ago. It stranded him more than once, he's got a newborn. It was in the shop 10 days ago and he "thinks" they said it needs a new fuel injection system. He can't put any more money into it, needs it gone. I was thinking of upgrading my Macbook, which is a total want, not a need. For less than the price of a new laptop I can have fun for months tinkering on this truck and enjoying it. I'm taking this truck home. The guy was beyond thrilled, his wife was there, she thanked me profusely, I could tell they were hurting. They seemed like good people in a bind.   Some parts, a wash, maybe a set of tires, and I can have a few months of fun and then turn it for beer money (or the next project).   Sure enough, there's a work order from a shop last week in the INCHES of paperwork on this truck dating back to when the first owner bought it. They put a new distributor in it, fuel injection work describes basically opening the plenum and putting it back together. He said he couldn't afford any more work so he had them button it up and that's when he put it up for sale.   I'm not well versed in 4.3. I did discover 1995 uses the 1992-1995 SCPI "Spider" injector which is riddled with issues from splitting lines, clogged or cracked poppet valves and plastic spider legs that crumble over time. Cool. I'll just order me a ne---. Oh, the auto parts store doesn't have it? Rock Auto doesn't have it. eBay? $$$$$$ for used. These are UNAVAILABLE period end of story unless you know "a guy" who's still got one in a box somewhere.   Can't upgrade to the '96-'04 injector, it's a different plenum, wiring/pinout and sensor config.   There are a few kinda "know a guy" -guy rebuild services for these injectors out there for about $350. Okay, Okay... I'd like to know if anyone has used them? Anyone got a lead on these crappy 92-95 spiders?   I also don't want to send MY spider to Narnia and back without knowing if that's truly the problem. I guess I'll need to pull apart the plenum and do some digging.   I was also thrown for a loop. This 1995 model year truck has an OBD-II connector. The interface is decidedly not OBD-II. I can read and reset trouble codes and view live data, but there's not a lot of data. Like misfire count and on what cylinder, that's not there. It's OBD-1.5.   Nothing is ever easy. Now it makes sense why this guy wanted to disappear this thing for cheap. I'm guessing the shop told him the injector is toast, the part is unobtainable and they're not going to sort sending the thing to a rando offering rebuild service on craigslist, and the kid likely can't be without a working car for 3 weeks even if they'd facilitate that.   Experience with these early SCPI's? Stories? Things to check? Sympathy? (..Nah...)   This can sit until I sort it. But I haven't had a problem with a vehicle I couldn't easily solve in a long time.
    • I have four that read by the dash 8 to 10% better than miles/pump calculations and I have one that is spot on.
