New to level kits but need some advice. By reading most of the forums I would like to level with at least a 2 inch in the front of my 2014 Sierra.
So if the dealership or GM service will not install these, Who should I look for to do this in my area?
It's extremely simple to install. If you don't have a socket set find a buddy who does and ask him for a hand. It will only take an hour or so. Maybe 2-3 if you are very inexperienced.
http://www.roughcountry.com/leveling-lift-kits/chevrolet-leveling-lift-kits.html?vehicle_year=61
I have seen several mentions of leveling kits. Never having one, I had a few questions:
What purpose do they serve?
Do they affect handling/trailering?
Does it change the front to rear axle weight ratio?
Does it affect fuel consumption?
the main purpose is aesthetics. Since the rear end is raised a couple inches to accommodate sag when towing, we raise the front to level the truck out and even the spacing between the tires and the fenders.
It also helps if you are looking to put larger tires on without rubbing. If you have no intentions of larger tires, I wouldn't do it. Some guys just like the more even appearance. Its all personal preference though.
as far as purpose what ^^^^ he said. weight ratio no it does not affect it. handling not really that I have noticed but I only had mine for about a day. fuel mileage. you prob will see a drop but mainly when your driving on the open highway. your MPG's might drop about 1 mpg give or take.
EDIT: also as far as purpose you get a little more ground clearance. so if you ever do have to go off road or hell even just going over some curbs, you have that much more room.
Edited by thewhitestallion
With yall that have a level. How tall is it suppose to be? And what does the block actually measure out to be? For an example i habe a 2" truxx fromt level but the block is only 1"... Is that normal?
yeah it's normal. The ratio is somewhere around 2 to 1 for the front spacers.
Do you guys know if a 33x12.50 tire can be run on the Silverado with just a leveling kit?
Yes depending on rim width and offset. Stock wheels then yes.
well it would be a 20in. wheel
As LTZ2014 said; your offset is going to be what effects a 33" tire. If your 12.5 wide you will be fine if you stick to an offset that's close to stock
2014 Sierra with 2.5" rough country leveling kit on 20x10 wheels and 295/55/20 nitto trail grapplers. It had a lot of rub at full wheel lock which I fixed by hammering in inner fender where plastic fender trim bolts into inner fender wheel well. Lots of people cut inner wheel well and grind off inner sheet metal to clear tires when turning. Hammer worked for me and cleared the tires. You can't even tell anything was modified. Looks completely stock unlike others who have trimmed there wheel wells on previous model to fit tires. If anyone is looking to do a 20x10 wheel go with 5" backspacing. I went with the 4.75" backspacing since thats the only backspacing they had available in the Fuel Maverick 2-Piece wheels which I like a lot more than there 1 piece wheels. The 2piece wheel comes in a nice gloss black finish while the one piece wheels come in flat black and looks more like an undercoating finish which i didn't like.
A 295/55/20 might work on a 20x10 wheel with 5" backspacing with slight modifications with a hammer like i did. If none/or very slight modifications want to be done to clear the 20x10 wheel with a 5" backspacing go with a 285/55/20 tire. Just my suggestion to anyone wanting to do 20x10.
I will post more pics of where I hammered to clear tires and do a video to post on youtube.
Edited by alexgg2
I've got a 2014 Denali.
I've got the 20x9 KMC D2's and Toyo 285/55r20 sittin gat the shop ready to go.
I ran the same combo on a 2012 Avalanche with very little "reverse-over-a-bump-rubbing-at-full-lock" rub
Do you guys think I'll need a level? Hope not.
Getting ready to have a 2.25" level installed by the dealer and am going to look into have some tires thrown on as well. Trying to decide on the exact size of the tire, currently I'm thinking the toyo open country a/t II 275/65/20... but was looking to see what else you guys have installed and how they look. Thanks!
    • I am not techy at all but wondered if you have the truck running but sitting still in park as some functions gray out as soon as the truck is moving. I believe in the settings for updates you can choose for it NOT to update and I wonder by chance if maybe that was chosen before and now it won't allow you to chose to press update, I think that is back in the settings menu where it has all the items one wants on or off etc. Also I assume you have a wifi connection and checked that it has some signal strength, not that it would have anything to do with the grayed out updates choice in that case. What I am thinking out loud of here may be be of no value but thought I would suggest it, sometimes it can be the simplest thing that resolves an issue.
    • The so called rare failure that some certainly liked to tout ( die hard Ford fan boys ) as per the lifter failing and wiping out the cam. Back when it started happening the blame was being pointed to the lifters and honestly I never did hear anything myself conclusively one way or the other on that. Ford themselves in I believe 2024 had a technical bulletin I will call it that came out and for some engine platforms they were reprograming the engines idle speed but also they had a software update for the oil pump which then some time later was said what that software update did as to be increasing the oil pressure at idle. It is a good question if that issue was completely solved as one Ford specialist mechanic youtuber said he saw failures after that time period. Like anything there would be the variables, what oil is being used and the OCI and how much idle time gets put on an engine. I've seen some comments to claim that the L8T isn't so happy with high idle time either but I also know that companies that require their vehicle to idle a lot on the job don't tend to get the oil changed often enough for all those hours of idle time and go off of the odometer.
    • My 2026 Silv. 1500 WT (reg cab/short bed/4wd) has the 40/20/40 with storage in lower middle seat as well as the fold-down center bolster/armrest.   With the dual glove boxes this is about as much storage as possible in a std cab IMHO. Bill
    • I have a 2026 base 1500 "WT" regular cab with basic Chevy "Infotainment 3" 7-inch screen/radio. How many speakers do I have If I want to upgrade? Is the audio amp separate from the radio/display unit]? [I listen to classical and it gets a bit raspy at slightly higher volumes. Don't need a sub etc.] Do I have two or 1 speakers in the doors? etc. Thanks Bill  San Jose
    • probably won't get a response from that user, as they haven't returned to the site since making that one post.  users don't (at least I don't, and I haven't seen any setting which would notify me via say, email) get any notification other than going to this site, and checking if they got a response on their thread...
