I just bought my 2014 GMC Sierra All Terrain Edition. I was to use my stock 20" wheels and add 33"x12.50R20 toyo rt tires. What lift would you guys recommend and why? Trying to avoid any rubbing or clearance issues and looking to install level kit myself. Thanks
Rough Country 2.5" on my High Country has zero rubbing with 33x12.50R20 tires
Did you change the rear block? Any pictures? I want it to sit level no incline back or front. Thanks a lot
Hi fellas first post here. I installed the rough country 2.5 about 3 months ago and I'm having some weird squeaks and popping on occasion over bumps and backing up. I think I read a wile back someone was having this issue too. Seems like they just re-tourqued everything and it was solved.
Don't grill me for not wanting to read the entire thread to find it again.
I guess my question is is there something wrong or do I just need to re torque everything?
Anyone in edmonton or knows who does leveling in edmonton for Sierra 1500? I am looking for 2.25, but dealership wants $875 CAD + tax for labour and kit!
Anyone has clear warranty coverage on leveled truck in Canada? What is the law on mods in Canada anyway?
It's gonna cost about that much everywhere, because the 2.25" kit requires taking the strut out. Get a 2" kit and it can be done for under $300 (depending on which kit you get). And really what's a quarter inch going to get you? As for mods in Canada, they are pretty standard laws and can be found on the ministry of transportations web site…
I'm from Saskatchewan and I believe the Modifications laws are posted on the Sask government website. I can't see that a levelling kit would be illegal anywhere. The Sask. modifications law reads that your headlights and bumper need to be a certain distance from the ground. Which I'm sure if half the lifted rig rockets meet standards, your half ton sierra with a levelling kit will too.
I beg to differ. My dealer (Knapp in Blissfield MI)installed my RC 2 1/2 level lift for $258, which was $180 labor and $59.95 to re-align the front end.
Not all dealer are honest and will rip you off when they can.
Edited by No Tyme
I am referring to any law preventing dealers to refuse to repair if I mod the truck. like MAGNUSON-MOSS
Well, I am sure i am not breaking any law :) I have a buddy that did 6" lift without any issues. but I want to know if I will be denied for warranty as I modded my level
WHAT DEALER!? In the states I am sure.... Canada... so expansive :( or they treat me like a dummy and rip me off :S
Not the case in Canada most places, if not all, charge a flat rate. Every dealer I approached about the 2.25" kit I put in my 2012 wanted an average of $600 (I already had the kit)… Best I found was a Mufflerman that would do it for $450… But my 2" kit was $280 including the kit at a dealer…
Labor must have been cheaper than $180 cause the 2 1/2" kit on rc's website is $149. In Ontario i was quoted $500 + tax for the 2 1/2" kit including labor and $109 for an alignment.
I just had our guys install the pro Comp 2.5" levelling kit in my 2014 1500 double cab 4x4. prior to install the front measured 36.5" and the rear was dead on 39". Installed measures 39" on all four corners with stock 18" wheels and tires. The kit I purchased on Amazon for $165.00(187.00 to my door), labour to install and align was 2.0 hrs. @ $130.00/hr. flat rate. The truck rides great, a little tighter in the front end, no unwanted noises, headlights will need to be adjusted. Tire sizing is next up.
    • Sad thing is that this doesn't have to be the case. LSPI can be solved without a reduction in TBN. Swap Ca for Mg.  Cats are not a issue if the OEM can get a ring and valve guide seal even at SN levels of SAPS. Dizzy is purring like a kitten with a bowl of warm milk. 200K of Full SAPS oil and zero detonation issues and nice a clean inside and out. This shouldn't be an issue. It isn't 1920.    Tell ya what AMSOIL SS is excellent at, internal cleanliness. The new formula is even a step up from their already outstanding cleanliness levels. Can't say the OEM offering is quite that clean. There marketing suggest the SS is cleaner.     That is the only defense with at shelf oil. Nothing wrong with them if you ignore the marketing and OEM 'recommended' OCI and use a thimble full of common sense. 😉 You go sir.
    • I started with a folding cover by BAK PAC on my 2500. It went bad after close to 5 years. Bent and vinyl coming loose. Contacted BAK and they gave me a very good discount on a Revolver. Had it a number of years. Mostly outdoor storage. Some garage storage. Vinyl started to come loose. Still under warranty so they replaced to cover. Sold the 2500, bought the 1500 and got another revolver for it. Had it a couple years now and no issues. I store it indoors. Got a bit of discount when buying it as well. If you are seeing problems, contact BAK or real truck and let them know. Customer service was pretty good. But I think they changed their warranty.
    • Its possible you never had the joy of the crappy boat launches we tend to have around here or really some of them are just grades down to the river if its a river scenario and the conditions change all the time with the river levels and silt deposits. Some of the lakes we went to years ago, there was no such thing as a cement pad that went down into the water that the trailer stayed on, it was gravel maybe up to the water line and then duck crap much beyond that so sinking the boat tires into mud. Of course some of the more established lakes had a cement bar type boat ramp but sometimes it was covered in green slime closer and certainly within the water and a two wheel drive had all sorts of fun if one had to touch that slime with the rear tires.    A neighbor of mine had made a comment years back with his chev truck that was probably about the same year as yours but a half ton extended cab 4x4 and he a a fiberglass boat with an inboard so it wasn't a feather weight and he had gone out to one of the large popular lakes in the area and don't ask me how this happened but he was in two wheel drive as he figured he didn't require four wheel drive for that boat ramp and somehow upon pulling the boat out he twisted one of his drive axles. I suspect it must have spun and then grabbed on the cement ramp and shocked it to the degree of twisting it. He would have had the standard 8.5 or whatever it was axle housing as the 9.5 ring gear like my truck has also has larger drive axles as far as I know. Anyway he was feeling a vibration driving home and had it checked out and a shop found that the tire/hub was wobbling because of the axle had twisted so in went a new drive axle. After that bad experience he said he made sure to put it into four wheel drive to lower the stress on the rear axle. Of course that is where an HD truck can handle a lot more stress and no doubt these newer half tons with their larger ring gears probably have larger drive axles as well to match vs back in the day.
    • Desirable - as in does someone WANT one, aspire to have one. Could reasonably buy any car they want and CHOOSE these instead.    I didn't watch the video, why did they win?
