Your truck looks great. Did you have any rubbing issues with the +1 offset?
Over the last month I have been "building" my truck. I read EVERY post on this thread. Thanks folks! RCX 2.5" front level only, 20" fuel Mavericks +1 off set, Toyo Open country ATII
Hey everyone, new here. Figured I'd contribute after spending about a week reading through this thread. End up going with the rough country 2.5 front only. I think it sits awesome now. I just installed yesterday, here's the after pic
The 305/65/18's that were posted look really great. I'd say that's probably about the max size, without doing any trimming. Some other popular sizes to consider with a level kit are 275/70/18, 305/60/18, 285/65/18, and 33x12.50x18.
Thanks for the info.
Well my Ready Lift 1.5 inch leveling kit turned into new tires then the new Hypertech 2.0 tuner to fix my speedo error. I love the look now.
Tires-General Grabber AT2 LT275-70-18 with Zero rubbing.
Edited by themiltonkid
  • Like 5
I installed a 2 inch leveling kit a few weeks ago and I notice when I turn sometimes I feel like a clunky noise it is very slight though and it's on sometimes. I went under and looked at everything it all looked tight the steering feels the same as before and there's no vibration. Am I just be to picky here or is it something else?
Fox 2.0 Coilovers set at 2.25", Fox 2.0 rear, and RC 2" rear block. Truck rides great!
Installed 2" RC level yesterday. My steering wheel is off center to the left about 45 degrees now when driving straight down the road. Still rides nice other than that. Scheduled for new tires and alignment this week. Will that fix the steering wheel issue?
Thanks
Edited by cato
Thanks
Yes an alignment will fix your steering wheel being off centered.. Anytime you change your front suspension
Finally added a 2" RC level front and 2.25" Ready Lift blocks in back yesterday. Tires and wheels are still stock 18" Z71. Gotta say it still rides same as stock before the level. New BFG KO2's are scheduled to be put on Friday. This set will be my winter swap set. In Spring I'm planning a 5" RCX lift with new 20" rims and tires for the nice weather months. Curious to see how stiff the ride is when the new tires are put on the end of the week. I'll post some pics before and after next weekend.
Oh yeah. It was 'loud' but I noticed that since I've put about 2k on the tires. It has gone down dramatically. To be honest it was only in reverse
I'm thinking about these exact tires for my winter set. Do they rub the sway bar at full lock in either direction?
No. There is only a slight rub at full lock on the rear side of the fender liner, which I zip-tied back to fix it.
Could be a Sway bar .
Edited by TheFactor
Same lift size, tires and valence trim idea I will eventually do to mine.
How much did you trim on that lower valence and what method did you use (jig saw, sheet metal sheers, cut off wheel, something else)? Did your method workout well or would you go another route?
Awesome set up, extended cabs are still my favorite look!
Tyler
Edited by amxguy1970
Tyler[/quote
Hey thanks!
I used a jig saw at first then a dremel tool and eventually a block planer to even everything out.
New Cooper Stt pro, 2" level 295/55
nice ride!! any shots down the side? I'm wanting to run a 20x9 0 offset with STT pro 295/60/20. 2.5" leveling kit. these will be 1" taller and stick out 1/2" more.
Thanks.
    ncleg
    ncleg
  • Who's Online   4 Members, 0 Anonymous, 803 Guests (See full list)
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
    • Yes your absolutely right, I been looking at the 4 inch BDS one and it acutely states you can use the stock 20’s just not the 17’s or 18’s, I also didn’t realize that with my 275/60r20 stock wheels I’m already running 33 inch diameter wheel setup lol so I can just run my stock wheels and tires atleast to start.
    • I would expect that to be lift-kit dependent.  If the kit has interference issues w stock wheels, then the kit/manufacturer should indicate that somewhere.
