Just picked up my 2016 GMC Sierra from the shop today. 2 in RC level and 285 55 20 Hankook Dynapro's 10 plys. I'm going to be posting more pics under the thread I started as well as any changes I've noticed and MPG changes after I run a couple tanks of fuel through it. 20% tint on just front windows. More info in bottom link. I will try to get up more pics in the thread below asap!
http://www.gm-trucks.com/forums/topic/181879-my-new-2016-gmc-sierra-ccsb-z71-slt/
Here's a before
And after.. More pics to come
Yes, it changes quite a bit actually. Any time you do suspension mods, even just strut replacement an alignment is recommended.
This is very true. Just remember that the upper and lower control arms are different lengths, so as they move up and down together, the camber is changing continuously. If you change the static ride height, you are also changing the static camber setting, which you want to be pretty much zero or close to it. Otherwise, you'll be continuously wearing the inside or outside edge of your tires as you roll down the road.
I had an issue with 4 Wheel Parts. I ordered TA KO2 on 12/30, got told I'd see them end of next month, today.
I called Discount Tire who had 4 in stock, they matched my price and I picked them up tonight. I hope to install level soon and the tires.
LT275/70R18
Sounds like you'll have a good looking setup! I think mine is very similar to what you're looking to do. I have the same tires and a 2" level on mine. Black truck too.
2.5" Level kit with 1.5" body lift. 305/55/20 Nittos
Edited by rhino2020
Looks great... did you need BL to fit the 305/55 ?
I don't think it was a have to have but I like the look. I don't have any rubbing issues. If I didn't have the body lift, I would've had to pull the liners back a little.
There is no actual harm installing my level kit and then getting tires installed and alignment done week later, right? I'd be driving around on the stock tires which I don't care if they wear differently. Just trying to work my schedule and it looks like I will only be able to do lift install one day and tires a week later.
Honesty it depends on the wheels. I have a 2" level on 305/55 on the stock silverado 20s and it rubs just a touch at full lock
I have +18mm offset wheels.
You should be good for a week. My pulled bad to the left after the level kit was installed.
Agreed. Shouldnt be too bad. I was lucky and was able to get mine in within a day or two for an alignment.
Some (somewhat) cleaned up pics with my 2.25" readylift level and 2" rear block.
Sold the dropstars and 33s and will be buying a new winter setup. These 22's will be my summer wheels.
20160115 135415 1 1
20160115 141120 1
20160115 141137 1
Edited by buckeye6
And this is the solid chevy grill I am talking about ae0c4354422e358005fa1035b68f019c.jpg
Who's 16' serria and what set up is that? That's exactly what set up I want. Sweet truck
bcbz71, on 13 Jan 2016 - 3:37 PM, said:
I put the 2.5" Rancho ReadyLift on my F150. It was a horrible ride just like you are talking about. I put the 2.5 Level on my '14 Sierra and it's much better than my Ford with the ReadyLift. I would just suck it up and get rid of that lift and go to a leveling kit. Lift is too short to ride in a truck like that.
First of all, yes, your dealer can align it; they are choosing not to. Having a crooked steering wheel would drive me nuts.
Wheel alignment is a crap shoot. I went to one of our better known 4x4 places after I put my level on and they brought it into "green" specs. Only the Toe was out. But it was wearing the LF tire bad, so I took it back and they said it was a degree off. Still noticed wear on LF, so at 15K service at dealer today, I had FE alignment done. Their print out said the LF was fine but the RF was off. ?? That makes no sense to me as the RF was not wearing. I had an X rotation done, so I'll monitor treadwear and see what happens. At this rate, there is no way I'm get 65K out of my Nittos.
Thanks for the help. Yah its pretty crappy. I will probably be going that route sooner then later as I just cant stand it. I also got back from the dealer yesterday and they said they would align for me. and fix the steering wheel but nope. what is it they need to adjust to fix that? driving on the hwy with a slightly crooked steering wheel does drive you nuts. I cant believe they said they fixed it but thats what you get.I paid them to do it last time so im not expecting a hand out to a suspension mod either just to try and get it back to normal. Its just a "level" kit I didn't expect this many issues with it. makes you regret it that's for sure.
can any one recommend a better option upfront?
also, I currently don't have stock coils as when I swapped them out I had them in the back of my truck and they actually went missing if you can believe that. so I would have to grab new ones :(
Take out the ReadyLift struts (and sell them) and put your original struts back in. Get a RC 2.5 level kit with rear blocks and install it. Maintains close to your factory ride with just a little loss in suspension travel. Get a FE alignment and you are ready to roll. Any shop that does your FE alignment can fix your steering wheel....it's part of an alignment package and I wouldn't leave or pay until the wheel is perfectly straight.
    • No doubt... But, as someone who doesn't pay for his services, but who has provided a few views/clicks on his Youtube platform, the data around the Mobil oil testing I think does have some value including to "freeloaders" like me.   A lot of what he's doing is likely showing the OE's work in their oil selection, something that many of us had kind of assumed was true all along, a good balance of both excellent protection and efficiency.
    • Lake Speed is drumming up business for his company just by being in the spot-light so he has a vested interest in stoking the 0W-20 fire.  IMO
    • I knew when I bought my truck that it had off road hill decent or craw control or whatever they call it and rolled my eyes at that but it gets throw on with other options my truck has, I just never had a heads up if the highway speed regular cruise setting had anything to do with the brakes and that took me by surprise. If you've ever been to the top of Pikes Peak and watched those ahead of you on the way down with their brake lights on constantly, one can guess they are probably not gearing down or not enough anyway if their vehicle will allow and a good reason their is a brake check spot part way down where they use an infra red heat gun to check how hot ones brakes are front and rear.    Your right that once one gets out of the front range by Denver and I've not been on that stretch of 285 between Denver and Fairplay myself but I know its high and Fairplay at 10000 feet, Buena Vista at 8000, it drops a bit from there but then your going back up and over the 11000 pass and Durango is at 6500 . So yes your definitely right that 6500 and a lot higher is the theme of going anywhere out in that direction from Denver but hey, the down hill sections give fantastic fuel mileage !.    I don't even look at the fuel pumps for what premium costs here, since I live on a farm and up to this point get fuel delivered I am rarely in front of a fuel pump and when I am, I am often using card lock bulk fuel stations so it tells me what the price is AFTER I buy the fuel. Looking up on gas buddy and converting to US gallons but in Canadian dollars, regular on average of the prices listed was around 5.95 and premium is around 7.00 . That was one reason I did not go for the 6.2 half ton aside from its lack of carrying/towing if one was going by the rule of using premium fuel and until recently one could only buy regular farm gas if playing the few cents off game for farm dyed fuel for a "farm licensed pickup". But yes I hear you on the fuel price difference and like the diesel theme with it often being more expensive then gas it doesn't have quite the charm to it either as it once did although right now here for some reason the price of diesel has come down more so its now inline with the price of regular gas.
    • I agree with this assessment. As you know I’m testing longevity with vehicles for the first time. I have a few vehicles I passed to kids and grandkids. We’re all past 100K miles some approaching 170K. I’m the only one doing 5k oil changes. The rest whatever the minder says. I’m the only one doing frequent transmission service. My odyssey the trip vehicle at 200K will be finished as a trip vehicle. I recently changed to high mileage oil, Valvoline. I can’t get past the fact that all manufacturers want to claim long service life. I just don’t make sense that they would go with low weight oil for mileage. While sacrificing longevity.
    • There's absolutely a mountain of profit in catering to the "I do my own research" crowd, people who are certain they know better. And I don't mean there isn't data to support that 0w40 produces less wear product than 0w20 in an engine like the 3.0 Duramax, that only feeds them the assurance they need. Again, my whole thing with oil selection is, sure, 0w40 or 0w30 produces less wear product. Are we talking the difference between the engine lasting only 100k versus 200k? Or are we talking more like, if the engine will already go 350k on a good 0w20 regimen recommended by the OE, is using 0w40 going to get us to 355k, assuming we can even get the rest of the truck to last that long, meanwhile sacrificing the first 5y, 100k in powertrain warranty. The answer isn't easy, there are tradeoffs.   I willfully use 0w20 Dexos D for this reason, knowing that a 0w40 will produce slightly less wear. I don't believe the delta in wear product is meaningful over the lifetime of the engine, and I place much more importance on driving style and overall feeding and care of the engine as a whole. It's the mentality that someone can abstain from alcohol their whole life which is an amazing boost to health by itself, theoretically. But if they're sedentary, that lifestyle choice will most likely kill them young despite their other, concerted efforts. Maybe someone doesn't drink AND they are the perfect picture of health and activity AND they use 0w40 AND they treat their engine perfectly. If living until 130 years is the goal, sure, do that. But it's going to be a really old truck falling apart around a good engine for that last 30 years, without a doubt.   I watched Demonworks' other video on the 100k+ 3.0 Duramax that had dealer 0w20 changes on what appears to be OLM-prescribed intervals (8-10k).   The QR codes are still present and readable on the main bearings. That's how little wear it has.   That's not proof that anyone else should stick to 0w20, but it's confirmation, for me, that 0w20 is perfectly acceptable to use in these engines.
