What was your height measurement before the level install? I was looking at the same kit from ReadyLift and they have a note on there that says it won't work for Z71 models because they only have about 1" difference between the front and rear? I haven't measured mine yet because I just found that on their website and I'm currently at work.
I just measured my Z71 without level.
Front is 36-1/4"
Rear is 38-13/16"
I ordered a 2" Motofab block for front.
Edited by geswek
Front is 36-1/4"
Rear is 38-13/16"
I ordered a 1" Motofab block for front. I do hope it levels it out.
Hmmm... I wonder why they had that note on there? I guess there might be a variance in ride height amongst stock trucks and maybe they posted it as a precaution? I'll have to check mine when I get home to make sure. Thanks for the reply.
I posted pics of my 2015 Midnight Edition at post #2631 on page 176. Everything was 39" after the RL 2.25" on the front only.
Bottom is the before and top is the after. I did not put any blocks in the rear, left it stock for now. So just the 2.25" Ready Lift Leveling Kit up front. 66-3085attachicon.gifOptimized-2016-01-09 15.50.15.jpg
Looks great. I bought the rear block but might hold off with installing it. Does anybody know if I hold off with installing the additional rear block until later on after I have the alignment done. If I would have to have the alignment done again?
I didn't measure the front before, but it's now at 38.5 and that back is at 39.5. Tires have 32#'s in them now which is the factory recomindation (had 38#s when purchased from the dealer).
No you won't. Rear block will not affect your front end geometry at all
Definitely not true. My All Terrain has the Z71 suspension and after a 2" front level the rear is still 3/4" higher. 1" block lifted the front exactly 2".
hey guys, i just picked up a 2" RC level. How much are shops charging to install them and then align the truck? just curious, i figured it should take an hour and a half -2 hours of labor.
Here in Houston just to put the RC 2.5 level in the front and align it was 300 something bucks. Not including rear block. Definitely gonna do it myself when I get the chance.
Sent from my SAMSUNG-SM-N910A using Tapatalk
I am planning on installing my own once it is delivered. But I Called shops in my area (central wi) (non GM dealerships) and they both were at $60 + tax for the alignment.
For the guys that are contemplating having a shop install the level, it is very simple to install. If you know how to use a wrench, a ratchet and a hammer, you can do it yourself. Minus the alignment of course. Some people say you need a spring compressor to get the strut back on, but I've done both of my trucks myself in my garage and didn't ever need one. There are many how-to videos online to do it and you will save yourself probably $300. Now if you live somewhere where it's really cold and snowing/icy and don't have a garage or warm space to do it, then I completely understand why you'd pay to have it done.
Just throwing it out there. I can't stand paying someone do to something I can do myself. Plus for a lot of people, it's a great way to learn!
Kerrs, I'm the same way. I probably saved over 10k in labor costs over 11 years doing everything to my srt4 myself.
Only thing I'm worried about is having issues with warranty crap at beck n masten when I take it in for service.
Here in Louisiana I was quoted about $250 for install and alignment. I am going this route just because I do not have a garage at the moment -- living in an apartment.
I am looking forward to installing mods myself though in the near future.
I had my tire shop install my level.... Its just a 2" front spacer.... They install it for free and i got half off the alignment for buyimg the tires there.... Plus i get my drag radials and tires for my colorado and my 31s for my 81 Toyota as well....
Yes, if you are going to put a rear block on, put it on before the alignment. Part of your alignment is checking that your rear wheels are tracking directly behind your front tires. If the rear axle U-bolts are tightened with the new blocks without checking "square", you will get rear tire wear. Measurement from center wheel front and back should be the same on both sides of the truck.
    • Conditions for Meeting a Cold Start   The ignition voltage is between 10 and 15 V. The barometric pressure (BARO) is more than 75 kPa. The engine coolant temperature (ECT) at start-up is less than 42°C (108°F). The intake air temperature (IAT) is between 2–32°C (36–90°F). The engine is OFF for greater than 6 hours or the following conditions must be met: The start-up IAT minus start-up ECT are within 12°C (22°F). The start-up ECT minus start-up IAT are within 50°C (90°F). Fuel level is between 25 and 75 %.   Circuit/System Verification Verify that all I/M System Status indicators report YES, and that no I/M Test DTCs are present.If any I/M Test DTCs are set Refer to Diagnostic Trouble Code (DTC) List - Vehicle. If no I/M Test DTCs are set All OK. Inspection/Maintenance (I/M) System Set Procedure   Warning: Refer to Road Test Warning. Note: Do NOT touch the accelerator pedal until told to do so. A change in TP Sensor angle or an increase in engine speed may invalidate this portion of the test.   Note: An I/M Test DTC will not be stored or erased from the ECU except at the end of trip processing, which occurs 5 s after ignition OFF.   Ensure that the vehicle meets the conditions for a cold start listed above. If the EVAP I/M System Status indicator displays NO, perform the EVAP Service bay test if applicable. Turn OFF all of the accessories; HVAC system, other electrical loads, including aftermarket/add-on equipment, etc., and open the hood.   Set the vehicle parking brake and ensure the vehicle is in park for automatic transmission or neutral for manual transmission.   Start and idle the engine for 2 min.   Close the hood, release the parking brake and Accelerate at part throttle to 72–80 km/h (45–50 mph) with this speed maintained until the engine reaches operating temperature, 8–10 min.   Continue operation under these conditions for an additional 6 min.   Accelerate at part throttle to 90 km/h (55 mph) with this speed maintained for 2 min.   Release the accelerator pedal for at least 10 s. This will allow the vehicle to enter the decel fuel cut off.   Safely stop the vehicle, with the engine in drive for automatic or neutral with the clutch pedal depressed and parking brake applied for manual. Allow the vehicle to idle for 2 min.   Shift the vehicle to park for automatic and neutral for manual. Turn OFF the ignition and exit the vehicle. Do NOT disturb the vehicle for 45 min.   Observe the Inspection/Maintenance (I/M) System Status with a scan tool. All of the I/M System Status indicators should display YES.   If the EVAP I/M System Status indicator displays NO, turn OFF the ignition, ensure that the vehicle meets the conditions for a cold start, and repeat steps 6-11 three more times, or until the EVAP I/M System Status indicator transitions to YES. If the indicator continues to display NO, refer to the Inspection/Maintenance (I/M) System DTC Table to identify the DTCs that did not run.   If any of the I/M System Status indicators display NO, refer to the Inspection/Maintenance (I/M) System DTC Table for the indicator which did not display YES. The I/M System DTC Table identifies the DTCs associated with each I/M System Status Indicator.   Observe the I/M Test DTC information with a scan tool. Verify there are no I/M Test DTCs present. If an I/M Test DTC is set, diagnose the DTC using the Diagnostic Trouble Code (DTC) List - Vehicle and refer to Inspection/Maintenance System Check.   Observe the engine DTC information with a scan tool. Verify no DTCs are present. If a DTC is set, diagnose using the Diagnostic Trouble Code (DTC) List - Vehicle. After repairs, perform the Inspection/Maintenance Complete System Set Procedure to verify no further DTCs are set.       Looks like one procedure to me.  Repeated as necessary.
    • My 2020 AT4 6.2 has had the valve spring issue addressed at ~200 miles, front cover/pump replaced at 18k, water pump at 34k and idler pully at 65k.  I would agree with ditching by 100k unless you elect to go with upgraded hardware...say built 10l80 and an lt4 or l8p swap.
    • I also need one of your modules for my 1993 chevy c2500 7.4 Thanks! My email is [email protected]
    • Chevy needs to do a black regular cab short box SS model with the new 6.6L.  400SS.
    • You might find the drive cycle you need somewhere on charm.li (website), otherwise I suggest a subscription to alldata.com to get them for your truck.
