2014 Silverado Z71
20x9 Fuel Maverick +01
Nitto Terra Grapplers G2 305/55R20
Bilstien 5100s all around
How much did your setup raise the truck? Looks sharp!
Edited by rhino2020
2014 Silverado Z71
I dig that black z71 logo on your grill. Might have to do that to mine!
I'm burned out on reading up on the leveling kits so hopefully someone can chime in an answer...I want to raise the front and still have a slight rake, so Ive narrowed my options to the 2 inch RC level that looks like it ( might ) make it nose high or the bilstein 5100's. How many of you had to install a rear block due to being nose high with the 2 inch level ?
I have the Bilstein 5100's on the highest setting with stock blocks in the back and still have 3/4" of rake.
I just ordered the RC 2 inch and will be ordering bilstein's if I don't like the RC level stance. I will give them to a buddy of mine with a 14 Sierra and put on the 5100's .
I got my Motofab 2" level kit today and I'm stoked!
Just wish my dang tires would come in from 4 wheel parts!
After reading most of these posts this is what I went with on my 2014 Silverado High Country.
2.25 Ready Lift Level
20x9 Fuel Nutz Rims +20 offset
33x12.50x20 Toyo MT tires
How do you torque wrench the bolt at 3:14 in this video? It's the nut on the upper control arm with the allen key head. I know you put allen key in and then twist the nut with adjustable wrench--but can you torque that without an allen key in or will it spin?
I'm pretty saavy but I've never touched upper control arms on Chevy.
Soon as my tires come in I am going to install my Motofab 2" level blocks myself since the place I called wanted $200 bucks to do it.
Edited by geswek
If it spins put jack under the lower control arm put some pressure up and use a pry bar to keep pressure down on the ball joint it shouldnt spin once its tight enough but if you are putting in lower spacers like that video you should be able to put them in with just taking the sway bar loose leaving upper ball joint alone and prying up on the shock bottom to slide spacer in good luck!
Edit: the allen key is just holding the ball joint from spinning also you would torque just the nut he is tightening with the adjustable when your done but it's not likely you will be able to get torque wrench in there so just tighten very tight when done
Edited by z71 chevy
I will try that instead -- I thought I read you could do it without messing with the upper ball joint.
I did buy Motofab blocks like those--very excited. Just wish 4 Wheel Parts would hurry up with the damn tires.
I also got email from BFG; 45psi for the new tires versus 35 on old P tires.
he original equipment tire size of your Silverado Z71 is P265/65R18 with a recommended inflation of 35 psi cold which supports 2,469 pounds per tire. When you changed the tire size to LT275/70R18, the new inflation will be 45 psi cold which supports 2,470 per tire.
Edited by geswek
I know I'll catch hell for this but oh well.
I had paid the dealer to install a 2.5" level on my new (11/15)truck and am trying to figure out if it is a 2" , 2.25" or 2.5" as ordered. I see the lower front end block and it measures 1" and can't see anything on the upper or I don't know what I'm looking for to give me the 2+".
The other thing that has me thinking it's under 2.5" is my truck still has the original rear block and the truck has a 3/4" -1" rake ,which tells me that the original rake before level was around 3.5"...................that seems like a lot of rake . Dumby me never measured before and after. I'm not liking the stance and want the rear up another 1" atleast. The rear just looks low. Sorry no pictures except on my sig.
Any advice or suggestions are welcome.
my 2016 Sierra Double Cab Z71 had 3.5in rake from the factory. I installed a Motofab block (under strut) that was just over 1in thick. That got me about 1.625in higher in the front. I now have almost 2 in of rake....which is exactly what I wanted.
It's not a 1 to 1 ratio with the under strut blocks..
What size tires are you running? I heard people are running 275/70R18 on 2" level. I bought those tires and Motofab 2" kit. Now I'm wondering if I should hold and get 65s instead of 70s.
usually 1 to 2. Interesting yours didn't give you that. I've heard others say its 1-2 and then I've heard others say "every truck is different". On my 2015 4X4 Sierra All Terrain crew cab short box my 1" thick spacer gave exactly 2" of lift.
    • How did all that extra get added? AI bot!
    • This is interesting. My quote tagged here is different from my original quote. After I’m driving them longer. That isn’t me. I don’t talk that way. I definitely wouldn’t express myself that way. Interesting.
    • I have the same running boards on my truck and I do agree they are bulky. I also find myself stepping over them when getting in and out of the truck. Besides providing protection to the rocker panels, they aren't very useful.  I will be replacing them soon with the Amp Powersteps.
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
