Good Lord, and don't put any weight in the bed either, it may change the geometry of the suspension.
The described her tires as large and could potentially be harmful to her drivetrain as well.
But....275/60/20s are only slightly larger then stock. Lol and she has a level not a lift kit.
Sent from my Note 4 on Tapashit
Speak for yourself
This is the crap i have to deal with right now. As soon as they saw the level they called my girl to pick up her trucl because thats what caused her leafsprings to squeek like crazy.
I remember years ago when my cable provider wouldn't service my modem because I had a wireless router. The same provider now supplies wireless routers. I think your dealer is out of date in meeting customer needs. Dealerships in my area have progressed from bad mouthing level kits to supplying and installing. "Lead, follow or get out of the way!" You should take your service elsewhere. Maybe it will help promote change!
It helps to know what you are taking about as well. They take advantage of my girl cause she isn't truck savvy as i am. Wait till i get home!!! Haha
And i know man i had to deal with that yesterday with my ISP. I finally got fed up over the phone amd said "look lady i have 2 college degrees in computer hardware and networking.... The problem is on your end!!!" finally sent out a tech and turns out it was something they changed om the modem (that i couldn't get into... Port blocking) my router is worth x3 what their modem is lol
Edited by Txjose
Wow, this definitely changes things lol.
The dealer I've been talking to is not the one I purchased the truck through. I bought my truck 4 hours from here but they were very easy to deal with, I guess I'll maybe be making the 4 hour drive.
Looks great! I believe a 1.5 to 2 inch level is a perfect stance for these trucks. The wheels look great as well, however I think the size would be too much of a power drain on my 4.3!
Who all is running a 1.5"? I think that's what I've decided to go with and still have about 1/2"-3/4" of rake.
I plan on installing a 1.5 but I was figuring on being left with an inch of rake.
After measuring mine 2" would be about perfectly level. That's why I'm leaning towards the 1.5"
    • 2026 3500HD.  Mostly empty. Grocery getter. What tire pressure are you running for 37x12.50x20. I have 37x12.50R20 Toyo Open  Country RT pro and been running around 55 lbs front and rear and it's too much. Tires are wearing more in the middle. Toyo says 45 front and 50 rear. Chalk test and it's still too much. I lowered it to 40 front 44 rear see what happens.
    • Enjoy the new truck, it’s a beauty. I’m glad you’re keeping the OBS, I love those old trucks.
    • With large equipment or deep mud it is more of a use the higher gear to avoid spinning tires, getting stuck because of spinning tires and doing damage to your machine. The idea is if you run out of torque before you spin tires you can still downshift for more torque. If you are just spinning your tires in the lowest available gear you are stuck and things break.   Automatic transmissions, traction control and electronic transfer cases change the calculation a little as you the driver have less control over each piece.
