I went from stock rims to a -12 offset little rub full lock. 305-65-18
Any updates?
post-163079-0-36155000-1478044361_thumb.jpgpost-163079-0-05962400-1478044374_thumb.jpgpost-163079-0-57867700-1478044385_thumb.jpg
Edited by Olmickeyt
From +24 stockers to -12 is a big jump especially with a 2" level.
You're one of the few running 305/65r18, so any info on the stockers before you got new rims would help a lot of us. Any reason you went away from them?
Just for looks pretty much. No issues with stock ones at all. No rubbing or anything. Ya the -12 was a big jump almost to much cause now I have rubbing on the little black plastic peice on rear of wheel well in the front. Maybe a 2 1/2" level will give me enough room to clear. It's only pulling into parking spots or backing out.
Every time I see your truck I think, "That's it". No matter what part I'm looking at. Was looking at the RC 2.5" level with wheels and tires and I think you have the set up I am looking for. Now I just need to photoshop them onto my truck.
Thank you! I get compliments on it all the time. My favorite part is it just looks "right." Its black but its not at the same time. I'm really happy the way it looks.
I have a set of rancho quick lift level kit up for grabs. Brand new, never installed. PM me if you are interested! And by the way I love them on my truck.
I'm going to be putting the Rough country 2-1/2" level kit with Gear Alloy Big Block 20x10 with a -19 offset wheels and 285/55/20 tires. Just curious if anyone has a similar set up, I don't think it will rub
Ok so have finally got my rubbing issue fixed. After installing 295/55r20 Toyo open contry AT tires had rubbing on the a frame, So I installed 20 x9 XD Rockstar II with 18 offset. The tires now rubbing on Sway bar. So when back and replaced tires with 285/55r20 BFG AT K02's and all is well in the world. NO rubbing!... Satyed with just front lifted with ready lift 2.25" level kit, stock rear blocks.... Ground to fender edge in front 38 3/4" rears at 39 1/2 so only have a 3/4" rake... Here are some pics.....
Catman lets see some more pics of your rig. Can you get a few showing how the tires poke in the wheel well and some up close of your wheels, and also the angles of your ball joints and C/v axles as well as your sway bar. I like your rig a lot, my 16 has cast steel arms rough country said I should be able to run 295/55r20 no problem on +18 or 0 offset but I want to see how different those stamped steel arms look leveled compared to cast steel
Hello. I am looking to put a leveling kit on my 2015 Silverado 1500 crew. I am still under all factory warranties and don't want to do anything that will for sure void them. I am getting Wrangler Duratrac 295/65/18. I am debating on doing the RC 2" level in just the front or doing the motofab 3' front 2" back. Any advice or suggestions would be greatly appreciated. I live in Colorado so off-roading will happen occasionally. Thanks in advance.
whichever way you go, post up pics of those 295s once you get them on your rig!
Obviously it's ultimately your call, but I would highly recommend against a 3" level. 2.5" is the max that most people agree is the most you should do. I play it safe with a 2". 3" will put terrible angles on your suspension and will wear things out prematurely, and will for sure not be covered under warranty. That's not even taking into consideration having almost no travel.
I think at some point, we just let the ignorant weed themselves out. Can someone sticky an "I Told You So" Thread? It will be filled with How do I fix my 3" leveling kit and budget "Lift" kit questions.
2" Suspension Max Level kit on my 2017 6.2 Denali attachicon.gif2017 Denali 5.jpg
This is a sick color combo. Very unique!
Sent from my Nexus 6 using Tapatalk
This comment is kinda ignorant in itself, no offense. There could definitely be a sticky on "lessons learned" but you don't just buy a truck one day and have the knowledge. For every post that explains why you shouldn't do a 3" level there's 10 posts with guys who do it "successfully".
Just sayin'
    • I have a 2024 Chevy Silverado 2500 with the 6.2 liter engine, Vin: 2GC4YME79R1273849, with 27,437 miles. Recently we took a trip from Candor, NY to Townsend, TN pulling our fifth wheel, when I got close to the Townsend, TN area The truck gave me a message of low oil. I checked the dip stick and found it was 2 quarts low. Today, August 27, 2026, I had the oil changed and the technician Found the truck was very low on oil.  Is there a Recall for this? What is my recourse for this issue? Do I call the dealer where I bought it or any chevy dealer?   Robert Strickland 292 Owego Road Candor, NY 13743 352-502-6588 [email protected]
    • We understand the importance of understanding how your Sierra performs, @SoCal Angler. Our team would like to gather the proper details to assist you with your inquiry about your truck's automatic braking. When you have a moment, please visit: https://s.chevy.com/support-request and fill out the request form with pertinent details. This will ensure your request is routed correctly so we may take a further look. We will keep an eye out for your outreach.
    • That is the funnel kit I bought and for being here in Canada I did get a better deal than what other sources were charging through a certain supplier in town that sources more directly and they ordered it for me. There are other items now on the market which would be perfect as well but this has worked well which was the hope when I bought it. I mentioned the Amsoil quart bottles as they have that squarish shape up top and it props nicely on the rim of the opening without falling into the funnel so I can leave them sit and drip a bit. You may have already figured out that to get the cap off the valve cover unless one is 7 + feet tall its not going to be reached without standing on a step of some sort and so when I do that I put the right adapter in and just leave the elbow on the funnel all the time anyway and open the lid and then if using quart containers for sure I can stand beside the truck and leisurely add the oil, and I can leave that funnel on when starting the engine to let it idle to fill the filter and then add the rest of the oil to top it up before removing the funnel and putting the factory cap back on. I put the cap back on the top and slide the bottom cap on as it fits onto the elbow adapter also and then store the funnel in a clean household plastic garbage bag along with the adapter so I have no reason to be washing out the inside of the funnel as I keep it completely clean between uses.    Draining the oil as per the under the truck portion, yes indeed that is slick as someone was thinking on GM's part there and admittedly I don't drop the oil screaming hot in this truck due to the exhaust being there and makes it safer as far as the oil temp if its just warmed up some instead as I don't have the truck on any ramps etc as I do it as the tires sit on the garage floor. The filter is not boiling hot then either and can drop it off into another pail after pulling the drain plug and just leave it drip out. Go back under a few hours later with new filter in hand and clean off the filter base and put the new filter on and install the drain plug. The filter is a little cramped in there as per wrapping ones hand around the filter and I am so used to using the band style filter removal tool that its no big deal and same for snugging it up. My filter wrench is many years old now but I think this is the current version and sounds like the right size, just in case my explanation was not great ( those nylon strap wrenches that one tool fits all filters are not my favorite tool to use, I much prefer this style personally )     57020 Swivel Gripper - No Slip Filter Wrench - Small | Lisle Corporation   And again about the oil draining and filter setup under these GM trucks, I've watched Ford videos of them struggling with oil flying sideways out of the oil pan on the gas 7.3 due to the sideways drain plug onto other components or cross members and guys trying to make shields out of carboard etc and other Ford pickups that Ford insisted they have sideways drain plugs. One win for GM there anyway with this engine.
    • Kind of off topic, wife drives a 2023 Yukon Denali with the 3.0, been a great rig so far, incredible fuel economy for a truck that big and heavy. Coming up on 50000 trouble free miles.
    • I`m gonna try some of this in my 2000 LM7 that has had the famous piston slap since 17,000 miles or so. I have used Mopar combustion chamber cleaner down the spark plug holes a few times in the past. Corrects the problem for a few months or so. Then returns. GM top engine cleaner has been used also. No good results from this.   This LM7 never used oil. Even running the piss out of it.   Course, I`m gonna use this in my 2025 L84 while it`s still clean. It`s got 13,000 miles. Used Chevron fuel system cleaner [2 bottles in tank] a tank or 2 ago.
