Just put on last weekend a Rough country 2” front level and some 20x9 0 275/55/20 e8b4473d7db557f33eb4c0b1256c16c0.heic3fcb23d27d7221ebb528d1500ad21db0.heic
Rough country 2.5 front only, Readylift UCA’s. Gotta measure on level ground but I think im only about 3/8” of rake now, may throw in the rear block
Edited by Arkangel
Your CV boots aren't contacting your lower control arm?
Im not sure, should I be concerned? Maybe the angle of the pic or maybe because its at a slope up the driveway? Ill recheck it tomorrow when its light out again
Edited by Arkangel
Yes they are, they’re after market UCA’s specifically designed for that lift.
Looks great, your UCA’s look great too compared to stock.
Another member mentioned that my CV boots appear to be contacting the LCA, should I be concerned?
Btw, get rid of those crappy Chinese rancho knock offs and put on some Bilstein 5100’s unless you off-road a lot instead Fox coil over Shocks.
You do not want that CV rubber boot to touch anything cause it spins while in use. Better get that checked out immediately!!
Damn! I just had this put on this afternoon! Shouldnt the shop have seen that?? 2.5” too high maybe? Just went out and took another couple shots with the flash its damn close
Edited by Arkangel
Are those pics with the truck jacked up in the air or sitting on the tires??
Parked the driveway at an incline, not flat
Edited by Arkangel
Sorry buddy, those rubber booties shouldn’t be touching anything but air. Looks like a spacer may be left out somewhere. What’s your Leveling setup?
Mine is a 2.25” level, two spacers up front, one top of strut and one sitting bottom of strut. I don’t see and spacers under your strut at all. Please take it in immediately making sure you do not use 4X4 until it’s raised OFF from the lower control arm
I have a spacer on the top of the strut and one under the strut, if you zoom in to the pic you can see the black Rough Country spacer under the strut, 2.5” kit
Edited by Arkangel
Ok, your last pics don’t show it really touching. Close but not touching. Those rubber booties turn as you’re using 4X4 so you do not want them touching. The pics may be an illusion, if you can put your finger between the two then you should be good just do not want them touching.
    • I'm tangentially aware of what Harley used to be, back in my riding days, although I was into Italian sport bikes. Ducati seems to have gone the other way; still very expensive, but they've made a large subset of their bikes a lot more reliable and accessible, and they've diversified their lineup to include other riding sports too. IMO, a good example of where greed and growth might have also been beneficial to the consumer.   Although GM is charging a relative premium for its most popular pickups, I find that there are some excellent value propositions in its lineup as well.   The Colorado still strikes me as the most attractive midsize on the market, and also the most reasonably priced given capability and features. There's a part of me that wishes I would have bought one instead of my Silverado.   The Equinox ...I must be getting old. The ICE equinox is a great design IMO. Probably because it reminds me visually of an actual SUV aka an S Blazer. Underneath it's nothing even remotely close, but it LOOKS good. It's got all the modern features plus some at a very reasonable price. If I had to run out and buy myself a daily commuter to do everything except tow, an Equinox would be on my list.   It does bug me that mid-tier 1500's reach into the 50-60k range, and Tahoes and Burbs are even more expensive. Less than 10 years ago, dealers were sitting on rows of Tahoe LS and LT's for low 40's. You could even still find Tahoes with a front bench, still!
    • Big oil is raking in billions from the Iran war. Can it avoid Trump’s fury?   Remember I said Big Oil is 'Vertically Integrated"?   Even as they no longer own the majority of the "Pump" they still own the "Well". Crude price upward pressure does not translate into that same pressure on production. Pumping cost remain unaffected and the gap is pure profit. Even after subtraction of a minor, comparatively, lower amount from supposed, but not always, realized refining volume. Consumers hate war, Big Oil, not so much.
    • We live in a world where the average person expects more. People say wages and our needs are farther apart. My first new home had 3 bedrooms and one bedroom. My first car and truck had what would be considered a stripped or work vehicle. In my neighborhood back then there were more homes like that and cars too. Middle managers and second home buyers worked their way up to the fancy houses and cars. Car loans were 3 years. GM had different models of cars for different income levels. The cars were pretty much the same size if you wanted a big vehicle. The nameplate designated the opulence. Chevy, Pontiac, Buick, Oldsmobile and Cadillac.  To be fair some of the cost is government mandated. We can’t blame them for giving us what people will pay for. Careful advertising steering people towards more profitable SUVs and trucks. As I learned recently a minivan is a cheaper more efficient form of transportation. Certainly easier to live with. Somebody realized the profit margin wasn’t as big and gave it a soccer mom label. So it lost its coolness. They’re making it the masses are buying it. You hit your hand with a hammer you can’t blame the hammer.
    • Hi All, I’m In need of advice regarding a scan result on my 2023 Silverado HD.  The Sensor Supply voltage relay states ON But…. the following 3 tests show Malfunction. Sensor supply voltage relay control circuit HIGH voltage Test status- Malfunction Sensor supply voltage relay control circuit LOW voltage Test status- Malfunction Sensor supply voltage relay control circuit OPEN test status - Malfunction. No DTC codes are stored. No DIC Lights. Remote Key Fob has been giving a few issues, namely Vehicle will not respond to an Open/Lock command from the key fob. New batteries installed to FOB made no difference, plus on one occasion recently the vehicle unlocked using the Fob, the vehicle started normally via the push button, then a random warning came up on the DIC stating the Remote Key was not found, all this while the key was located next to the central cup holders. Does anyone have any input or advice regarding this scenario? TIA
