No rubbing on normal driving as of yet (have not had any chance for articulation). Pleased with size of 285s
3e388b0a96fd7276f8057a19be214ca1.jpga7f80b6d8eda0c3eca96b8029e4afe2d.jpg528880f7c771920802d3faa77eadbff7.jpg
Very [emoji106][emoji2532]
Sent from above
You shouldnt rub ever. I have k02s in 285/65 as well on a 2.25 level with -12 offset wheels and i hardly ever rub.
Sent from my SM-G950W using Tapatalk
You’re not running stock wheels you’re running a -12 wheel and barely rubs, meaning it’s rubbing nonetheless. I think most rubbing is on 20”. My rubbing happened while locking on a full turn or while backing up.
Sent from above
Im thinking of going with the RL 2.5 up front and the Motofab 2in block in the rear. The RL comes with new UCA's.
Im planning on putting a 1.25" spacer on the stock AT wheels and then adding 33x12.50 tires.
Will I need a dif drop with a 2.5 in lift? Also Ive read about 75 pages from this thread and there seems to be no clear answer...do I need new UCA's with a 2.5 upfront? From what ive read some people say yes and you shouldnt do it without it and others say its not necessary.
On 11/4/2018 at 8:01 PM, StayInYourLayne said:
For those of you who have a 2017+ and installed 2.25" level without changing the UCAs, have you had any issues. Dealer is offering to install a ProComp kit without UCAs and keep my warranty in tact but I don't want to make the truck unsafe even if they keep the warranty. What good is a warranty if the truck is totaled?
I put 40,000 on a 2015 in 2014 before all this complaining about upper control arms. Never had any issues at all.
2014s, 2015s and early 2016s had different control arms than the late 2016s-2018s. I had a '14 leveled with spacers and no issues but the new control arms are said to have issues with levels
Installed Motofad 1.5” leveling kit today.  In my opinion this is how the truck should have shipped from the factory.  Ground to bottom of from fender before level, measured 36.5” after 38”.  Rear measures 39” so I have 1” of rake which is just right for the truck to sit level with a load in the bed.
I was able to install the spacer blocks by just removing the sway bar links, and loosening the nuts on the top of the strut.  I did not need to remove the tie rod or spindle from the upper control arms. Total project took just over an hour in the drive way all with hand tools.
I debated between going with 1”/1.5”/2” and I think the 1.5” was the right choice for the look that I was going for.
Before and after pics of truck and CV angles.
Edited by 2018Chevyz71
Correct except they started with the stamped steel in some cases early 2015 causing issues almost immediately once you level. I’ve got the 18, leveled with a 2.25” up front and added a 1” onto the rear, had to buy new wheels in order to run larger tires. In a few days it’s all coming out, going with CST 4.5” lift, absolutely amazing quality lift that doesn’t widen your track once lifted. Check them out
https://cstsuspension.com/content/10-media-articles
Sent from above
I have an 18 with 1.75" proryde lift up front. 275/60/20 Durateacs on stocks and it rubs at full lock.
Sent from my SAMSUNG-SM-G930A using Tapatalk
Exactly what happened to me, installed new wheels with a +1 offset, fixed that issue immediately. Nitto Ridge Grapplers 285/60/20’s
Sent from above
Agree it should come that way. I worked to find the best combo Of above factory while keeping factory ride. Accomplished both with 2” under strut only TGC level kit and 2.25” block in the rear. Love the slight height difference from stock.
It rubs very minor so I'm not extremely concerned about it
Unlike me, with my OCD, I can’t stand having any rubbing, just makes it feel cheap to me.
Sent from above
I was dead set on the readylift kit with new UCAs to level my 17, but now I'm starting to think that the Eibach Pro Truck kit might be a better option.  Anyone seen the two side by side?  Thinking that 275/65r20s or 285/60s.  Regardless, I think I'm settled on Ridge Grapplers.
    • Enjoy the new truck, it’s a beauty. I’m glad you’re keeping the OBS, I love those old trucks.
    • With large equipment or deep mud it is more of a use the higher gear to avoid spinning tires, getting stuck because of spinning tires and doing damage to your machine. The idea is if you run out of torque before you spin tires you can still downshift for more torque. If you are just spinning your tires in the lowest available gear you are stuck and things break.   Automatic transmissions, traction control and electronic transfer cases change the calculation a little as you the driver have less control over each piece.
