2016 4wd, added motofab 1.5". I have parts to add 1" in rear, gonna hold off on that for now. Will wait and see what it looks like when I start towing a little more often.
Will keep stock tires a little longer, then race with 275/60/20 Cooper all terrains.
Sent from my SM-G930T using Tapatalk
Has anyone ordered from mrtmotorsports on here. I ordered an eibach pro truck kit and havent heard anything from them. My order is there on the internet but cannot get a response from them.
I was quoted 400 bucks to level my truck. includes rough country 2 inch leveling kit, labor and alignment. Does that sound reasonable? I think i want the maxx suspension kit though.
Sent from my SM-G955U1 using Tapatalk
2 minutes ago, Jusaplaya said:
2015 Chevy Silverado 2.5 Motofab level and Toyo Mt 295/70R18 tires.  Got the truck back friday.
I got the motofab 3" motofab and got 285 75 18 (35")
On 12/30/2016 at 5:49 PM, CHowell1991 said:
I got my 2015 leveled yesterday with 285/75r18s on stock wheels. 2.25" readylift. e9fb32455eb6e7a1ab4290d687ba3600.jpg4f06d63c867457887ff070665de117df.jpg
Do u have any problems at full lock?  My upper control arm is hitting something I don't know what. I think I need some wheel spacers to take care of that problem. I think I have a +30 range offset...........thanx
I am only hitting the carpet on both sides at full lock.  I need to cut it.  That is what the guy who installed it said.  I don't think I have any problems with control arms hitting.  I only have about 150 miles on it and haven't scrubbed.  I haven't really needed to lock the wheels.  I had 63k on my factory tires.  They were shot.  These tires seem to ride really good.  I wish I would have did this sooner.
Just bought this 2018 and put 2" front Motofab lower spacer.
Tires are 275/60/R20 (33")
Love the new look.  Not sure on what to do with the air dam yet.
All I had to do is just zipped tie the liner at the bottom...i have borla 2" wheel spacers and it made it worse rubbing on the cab corner. But when the 285 75 on truck wears down im putting those wheel spacers on and then I be drooping to 33" tire
Take it off it will look soooooo much better. I took my off?
Might be a bit on the high side.  Figure the keys are roughly $100, add $75 for the alignment and an hour labor of $100 or so.
Did you get an alignment? What was the total cost?
Did the work myself, $30 for the kit, $80 for alignment.  Toe needs to be adjusted after lift for sure.  My castor and camber were still good.  Took me about 3-4 hours, most of that trying to get the upper ball joint to let go.
navyguy357
Yes u need an alignment ever time u do work to suspension when they did my it was like 60-70$ can't remember
navyguy357
what is better, 2" level or 5100 shocks?
I just have a motofab 3" strut spacer and then 2" rear block on my truck
    • Howdy folks,   Recently I pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain (part numbers coming soon - will have to disassemble), and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash for the heating element.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But I seemingly can’t turn it off AND still no backlights on any of the buttons.    Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • I'm about 1800 miles into my last oil change, and yesterday a message appeared saying oil life was at 77%. Not sure why it popped up but I think all of these electronics could be susceptible to solar flares or somesuch. I change my oil right at 3K each time, and that was the first time in 10870 miles that message came up. Strange thing is that it showed on the screen at all since I don't drive with that sort of info displayed on the DIC.
    • I’m praying that someone sees this and can help me out… pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain, and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But can’t turn it off AND still no backlights.   Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • Checked the pads today and there's plenty of meat on them. If the message keeps coming up, I'll just answer YES that the pads were replaced and wait for the squeal.
    • Welcome to the Forum! Always post the code definitions along with the codes. there are over 18000 possible codes, no one remembers them all and most will skip over your post rather than look them up
