This is pretty good info, thanks, so... of the two of you, one with 2" with still a little rake, and one with 2.5" and a little nose high, I'm pretty sure I should be good right in the middle with my 2.25" installed. Going to run 275/60R20 Toyo Open Country AT2's come next spring. Thanks for the feedback!
Yea I'd say that's fairly accurate. Should be very close to dead level. Is that what you're going for?
My Truck with a Rough Country 2" Level. I Still have 1" of rake, anyone on the fence that wants a true level I think you need to go with the 2.5" kit.
I was a little unhappy at first based on measurements, but I don't think it's that noticable and I think it looks pretty good. Hopefully once I get some new tires and rims it will beef it up a bit.
Edited by Robinson99
Yeah, I'm trying to get as close to level as possible. I'm one of those guys that doesn't need a truck really but bought one anyways because it was cheaper than the GM mid sized SUV's with a V6. I don't tow or haul anything heavy, ultimately I want to use it offroad more than anything so likely going to remove the lower valence to get a little better approach angle.
I'm kind of in the same boat as you really haha which is why i'm thinking about getting that 1/2" spacer to bring it up a tad more.
Yeah exactly. Right now I want to venture out to some trails but its so low on the front end I'm worried about hurting stuff which is kind of par for the course when offroading but still, might as well try to mitigate it. And I like the stance of a leveled truck.
Has anyone had problems with the RC 2" front level (lower) block? I went to a 4x4 shop and the salesman was telling "sorry about your luck". "Who installed it?" I told him I did and then he had the balls to recommend that he take look at it to make sure it's correct.
What's wrong with your level?
If you installed it correctly you shouldn't have any issues with it... At least I hope not.
I have the same one and haven't had any issues after 12k miles.
Nothing. The sales person just introduced some doubt into my mind. I was a little apprehensive about the plastic blocks under this heavy body. But I bolted it all back down looked up the torque specs and called it a day. But he made it sound like he has seen many failures. Which sounded to me like he was trying to sell his product. Then when he found out i did a diy. Then he was really an ass
Ahh gotcha. Well i've had two trucks that i have put this level on and have about 30-40k miles on them and havent had a single issue.
I haven't heard of anyone else having them either. But I havent look for the complaints. I bet if there were issues it would be pretty well known.
On Amazon and on various 4wheel drive parts websites I read the 1 and 2 star reviews. None of them said anything about failures or fitment. I feel more confident about my plastic spacers.
Just finished mine on my 2016 Z71.... Didn't even remove the wheels... Just dropped the lower shock mounts and the sway bar links. Used some pry bar action and was able to get everything installed. Had to cut the bolt underneath the CV joint tho. Was a little too long.... 2" RC kit.
Edited by Intrieri
Which is better installing a spacer under the strut or on top? Does it make a difference? I am sure under is easier to install but what about ride quality?
Here is mine - 2015 AT with Rough Country 2.5 just installed today stock 20" wheels and tires. I am going to be adding new shoes soon 275/65/20 either the Nitto MT or the new Ridge Grappler which isn't available yet but looks great.
That looks great iam thinking of getting the same RC 2.5 , how has ur ride change ? Any rougher , do u mind if I ask you where u ended up ordering ur kit ?
Ride change is very minimal if any - this is the second one of that kit that I have had and I love it. Ordered right from RC direct and it got to me in two days. I recently installed new tires went with KO2's in a 275/60/20 and did a Borla exhaust also. Loving this truck.
Awesome man glad to hear I hope to pick up a kit once I go back to work . Thanks for feedback again
Good god! I have no idea what to do now even though I read all this. I have a 2016 Silverado crew cab LT-Z71 and it came with the factory 22" wheels wrapped in P285/45r22. Here are my concerns: with adding a front only level kit.
-is there a 2.25-2.5" level kit I should stay away from due to my 2016 aluminum control arms?
-how do I know if I have aluminum control arms?
- will the above 2" level kit prematurely wear out components?
I would like to hear from someone who has the same model truck 4x4 with the 22" factory wheels and a 2.25 or 2.5" level kit front only.
Thanks in advance.
    Matt Parker
    Matt Parker
  • Who's Online   2 Members, 0 Anonymous, 819 Guests (See full list)
    • I have a 2000 Silverado 1500 LS, whenever I put it into reverse and also in drive it clunks, the truck also feels sluggish when driving. Any advice/ideas ?
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
