Edmonton represent!
What's with all the Edmonton fellas and their black trucks, lol!
I swore to never go back to black after owning a black Lexus...my last truck was silver and was super easy to maintain...but damn the new Sierra's look good in black!
Dangerdick, you've got a serious rig there man. I love what you've done to it!
I took my valence off for the winter to get a little better ground clearance. I'm seriously considering putting it back on if I level the truck. Right now it looks alright but any higher I think it would look funny without the valence.
Another one I snapped yesterday, using lightroom and I'm loving the way the pics turn out. I just need to invest in a DSLR now, the iPhone's not cutting it.2s19etl.jpg
& made this one in Photoshop just to see what it'd look like with all the chrome gone.
^Your truck makes me really want to clear my headlights.
Makes a pretty big difference, you should do it man :thumbs:
DSLR = whole new world of photography. Be sure to take it off auto.
Here is mine. 2 weeks old now. Tint, level, Line-x, 33s, some []Dlasti-dip here and there, DONE!
For those of you with the 2'' Rough Country level on your 2014/15 truck you can run a 33x12.50x20 Mud Terrain tire on a 20x9 wheel. I did it today. No problems. No cutting or trimming. If you need pictures or more info let me know. I searched and searched and could not find a soul running what I wanted to run on my leveling kit. So you guys running just the level it will work!!!
Truck looks great! I'm also in the Edmonton area. I recently pulled my lower air dam off, but I'm not really sold on it. I think I'm going to trim it down and see how it looks.
With valence:
Removed:
Well here's my first go at the trimmed air dam. This is just a mock up after making the cut, it's not actually bolted in place. Still have to file the edge smooth and take down any high spots but I think it looks good. I debated rounding the edges more and following the groove on the corners but was afraid it would be too much. Whatcha think?
  • Like 6
Gave her a fresh wash on my lunch break. Check out the 5K HID's, love the color and output vs stock!
How do you like the 5000k color HID's? I'm running 4500K in my truck and LED fog lights but the fogs seem to have a slight tinge of blue to them. Thinking about swapping bulbs to 5000k, but how do they compare to the stock LED strips color wise?
Looks good without boards too.. I've been debating pulling mine off since I got the truck.
Trimmed air dam's look so good on these trucks. I think they look weird without them but they are kinda just sticking out too. Perfect balance imo. Just gotta find time to do mine now.
Looks really good, might have to try that with mine this spring! I'm just wondering where you decided to make the cut line.
    • 87 down as low as $5.14 here... winning!
    • Progress... sort of.   Intake is disassembled, spider is out, fuel lines removed. Used a torch on the stripped screw with the lower intake off, much easier when I've got the intake sitting on my workbench, I made it talk. Walked right out with a pair of vice grips once it was nice and toasty hot.   New parts are piling up on my service cart waiting to be installed. Distributor, temperature sensor, new gaskets, fuel line kit, themostat, water neck.   My new pickle is I don't want to spend $600 on a replacement spider. I'm not sure IT is bad. I'm probably splitting hairs. Or it's $300 to send mine away and another 3 weeks of the truck just sitting. I have half a mind to assemble everything with the old spider to see if I can get away with just replacing the fuel pressure regulator to be safe. The obvious issue was the gushing high pressure fuel line which will be replaced. Getting to the spider really isn't that hard, and now I know what I'm doing , swapping it would be a breeze should it absolutely need one. Stupid, or smart?   The part that gives me pause is replacing the distributor. Well, it's already out. And I didn't mark it, whoopsie! Engine was at TDC when I removed it, I know that, so upon correct reinstall the metal tip on the rotor should point to the TDC mark on the distributor because that's where it was pointing on the old distributor. Worst case I'm a tooth off and have to re-stab it.   But then, what? I assume the truck will start. It doesn't appear the timing can be set. Here's the problem: These distributors can't be rotated but a degree or two, by design. What I read is Cam ****** needs to be -2 to +2 degrees, ideally at 0 (and checked/set above 1000 rpm). There should be enough wiggle to get that properly set, but checking the reported value is another potential issue. My Actron 9185 scanner says it supports enhanced GM PIDs and Cam ****** is one of them but it's unclear that I'll be able to correctly see it over OBD 1.5. I can see why people end up junking these things with life left in them. They're an absolute nightmare with tweener-year diagnostics/electronics and unobtanium parts.   Fingers crossed it starts and idles nicely. There can be hope, right? I'ma buy a lottery ticket the same day just in case.   Next steps..DO IT. I have not installed an intake before so I've been reading and watching a lot. Some say NO RTV except on china walls, some say DO RTV on water ports but not fuel/air intake. 1/4 or 3/8 bead on China walls? I think my strategy will be, obviously, RTV china walls with overlap on the gasket corners. Chapstick-style RTV the water ports. Leave intake ports dry. The only set of intake gaskets I could find locally are Edelbrock performance gaskets (uh...for an asthmatic 190hp V6? LOL) so we'll see how they do.   #NoToolLeftBehind. It took an hour, but my recovery mission for my deep 10mm socket was successful. It had rolled down the bellhousing and wedged itself between what I think are the fuel lines? I couldn't see it at all, but with a junk antenna I had laying around, I blindly went poking/sweeping for it, heard it clink, raised the truck, and caught a sliver glimpse of chrome with a flashlight way up there in Narnia. I had pushed it farther along the lines holding it captive, but within access of severely improvised tools, poking and cursing at it to finally knock it free to where I could get a fingertip on it to bring it home.    Not much to see.
    • Thats crazy considering im right next door (Indiana)
    • For a limited time, retail and commercial accounts receive an AMSOIL Vinyl Tool Tray with their order of $500 or more when they use code TRAY726 at checkout. The promotion runs through July 21, 2026.   Order at https://syntheticadvantage.com   Want to use AMSOIL in your business or sell at your store, apply here.  https://www.amsoil.com/business-opportunities/?zo=521390
    • It wouldn’t have happened if the government hadn’t mandated outrageous fuel mileage standards. It does very little for the consumer. It adds cost. Back during Covid there was a chip shortage. They gave a rebate for your truck if it didn’t have the chip to turn on cylinder deactivation. It was 50$ because at best you may see 1/2 a mile increase per gallon. Splitting hairs each fuel mileage trick wasn’t mandated. The government doesn’t do the engineering work and say use this until it’s already in use and they like it. The fuel mileage was mandated. And those add ons the results. There’s a mandate and they are the results.
