Looks like stealth gray but with enough light to make it look actually gray. My brothers stealth gray looks blue most of the time.
Hey guys , yes it's stealth. And also it's a 5 tip , direct from a 2015 dura max. Stuck in same place as hd's
Also no sensors. :) and yes it's slt
Here's my 6.2 :)
Dat exhaust tip though.....
Definitely makes it look like a Duramax!
Edited by Mike1220
Here's my 6.2 :)
I really like those wheels, They are one of my favorites. Kind of wish I would have got them the more I see them around town. Thought about waving a guy down the other day to see if he wanted to trade lol.
Here mines with my new grille among other stuff
ImageUploadedByTapatalk1427935323.445897.jpg ImageUploadedByTapatalk1427935336.897048.jpg ImageUploadedByTapatalk1427935346.546939.jpg
nice ride!
Your SLT did not come with front or rear senors ??
my SLT did not either which I thought was dumb...I have the camera with no sensors....I would have assumed buying a fully loaded truck it came with them, my 2012 chevy LT had the sensors...oh well, the camera is nice to hook up to my camper solo.
Hmm, looks like leveling with stock tires (P275s) on the stock 20s doesn't look too bad. Just ordered a 2015 SLT max tow yesterday. Nervous about leveling it as I won't be buying new meats for it right away, however I think it'll look pretty good leveled with stockers...
Also for the Parking Sensors, I think you needed to add the SLT Preferred package.
Edited by SkiDooNick700
Wow I'm extremely shock that your slt has no sensors that is just crazy
Level on stock wheels/tires
I like the blacked out trim - looks great!
I'm generally not a fan of the Silvy (vs. the GMC) but that... I would totally drive.
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
