Beautiful weather and time to kill, yea I think today will be a good one
843FBE18-1E40-4137-B0BF-08D17B1495EA_zps
- Mike
IG: @BlackPearl_Edition
  • Like 4
Now that's slammed! You can use the front air dam to sweep leaves off of the street..??
Edited by chuckl1218
Love these trucks in the snow!
:rollin: Your avatar just gave me a good chuckle thanks.
First post....my short bed crew in Brownstone, N-fab steps, 2.5 leveling kit with 4" rear blocks, 20" Fuel wheels, BFG Rugged Trail tires, MRPB exhaust.
Edited by AK_GONZO
Whenever you get ready to get rid of those wheels and tires man hit me up.
11898660_10207306401128985_2386679943427
Hey guys I'm new. I've lurked here for a while and finally decided to upload some pictures of my truck when I first purchased her, back in August 2015.
2015 Silverado LTZ CC. I love my truck and other than just a few things, I can't complain. First Chevy or new chevy I have ever owned. I have an 85 C10 Long bed that I use for all the work so this for now gets to sit on the sidelines. To date I have leveled it, de-badged all but the rear Chevy emblem, tinted my tail lights and third brake lights. Put in LED Reverse lights and license plate lights from Diode Dynamics, Cooped 275/60R20 Tires ( 55s from the factory look too small ), and other than some plastic dip here and there that's all so far. Wheels and better tires eventually are what I want, along with the chrome GONE... Hate chrome. Anyways thanks for looking and reading!. I'll get some pics of how she sits right now.
Bilstein 5100 fronts and rears, tint to come in near future and looking at some 305/50r20s open to suggestions on other things i should do too in no hurry love this truck!
Edited by Edelman13
I can see why you love the truck. It really looks sharp as it sits already.
Traded my 14' Sierra Z71 DC on this 16' Silverado Z71 CC and couldn't be happier!
I dig it! What is your wheel and tire setup?
Thank you! I'm running 20x10 Gear Big Blocks -19 offset with 33x12.5 Mickey Thompson Deegan 38's
Thanks. Hoping to have my 20x10's this week.
Quick pics I took at the beach yesterday [emoji106][emoji4]f93625660e2114f5b9f4996d8327b4a0.jpg18a17d3bc2e542787f395dc9bf3428a5.jpg36cfa803f9b40aba9d458a20a5fe552a.jpg972da5f3f54eef5ff53f982642574af8.jpg14f6f8194c9778a66ea0382977a8130a.jpg512538de09113d0db54801e662a5f147.jpg2b97561151e92b4a4ed731aa91c64f30.jpgfad5eaf5057b3b09963b820d87c10d83.jpg4cce3df91f6f73fa49f5c293ead1a422.jpg89ac32d161c68bcda95568aa16f7a08b.jpgaa7b613d020593ced6237cb9df776245.jpge724bc798b57120b42959225203a93de.jpgb63e42f075e5e3d72409e2581ec385fa.jpg
Did you raise it back up some? I thought it was much lower than that before
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
