Would love to see more pictures. I got 5k miles on my tires and I'm already thinking what my next set will be lol
Here's a few more pictures of the truck
Side View
Back Side
Front Wheels
Front Level
Front Side
Here's my 2017 E-Assist CCSB. Just got the Method NV 17x8.5, 0 offset wrapped in 285/70/17 KO2s today. Truck is raised 1.5" with Fox 2.0 coilovers in the front and 2.0 in the rear, stock rear block. No rubbing at all. Getting full Xpel on the hood and full front fenders tomorrow. Borla goes back on next week.
I'll be swapping out all the gold bolts on the wheels for stainless. 96 is gonna be a pain. Then onto color matching the front end.
Raceline Assault 20x9's with a zero offset. wrapped with Nitto Ridge Grapplers 295/55/20. no rubbing.
Looks awesome! What's your setup?
Just got My 2016 Silverado back a few days ago. Has BDS 4 inch lift with fox shocks in the back. Has anyone taken these trucks off road yet with this lift?
Your's looks a little nose high. Is it the pic angle or did you do something different in the rear? What size tires?
Truck looks great. What mud flaps are those? I'm in the market for something similar to put on my Sierra. Any drilling?
Noob here, but I wanted to gloat a little on my 2017 GMC Sierra :-)
This is date of purchase
Day of purchase
Adding the GM bed light option kit
GM Bed Lights 1/3
GM Bed Lights 2/3
GM Bed Lights 3/3
Adding AVS Ventshades
AVS Ventshades
Tyger Auto Steprails
Steps 1/2
Steps 2/2
Rails and ventshades in
Visors and Steps 1/2
Visors and Steps 2/2
AVS Bugflector
AVS Bugflector
Before installation of Motofab 2" level kit
Before Lift
After
Motofab 2" Level Lift 1/4
Motofab 2" Level Lift 2/4
Motofab 2" Level Lift 3/4
Motofab 2" Level Lift 4/4
Full Body Polish
Full Body Polish
New here, but I just finished(for now) my 2017 Chevy Silverado.
-3" Maxtrac Level
-Toyo Open Country 305/70R17
-Method Wheels
-Removed Silverado Badges
Looks killer
Looks good, been thinking of swapping mine to stainless too. MRW said dollar a bolt too, little salty...
Already on the wait list at TireRack. Just waiting for them to come in now lol. Same price
AVS Bugflector
After
Full Body Polish
Looks good. Looking to do same on my 17. Do you have a part number on the level kit you installed? Any issues with the lower control arms?
Thanks!!! Not that I have found so far. Only been a day. I opted for the CH-2LM from MotoFab over R.C., the R.C. parts looked like injection moulded plastic which made me uncomfortable. The MotoFab kits are billet aluminum and seemed a more sensible choice for placement in a suspension. Not knocking them (R.C.) or anything, and if they are steel that's fine, but they sure look like they had those lines all the way around like you see on moulded plastic parts.
Should also mention the directions stated to install the bolts 'head down', which to me means head at the bottom and threads pointed up. I couldn't get the nuts to fit, and after emailing the support team they sent me the below linked video and started to drop them in from the top. Once I did this, installation was a cinch. You'll need to raise the control arm and spindle up with a jack, and have a long prybar handy to hook in the spring and persuade the upper ball joint down into the spindle. Turn the nut on to the ball joint a turn or two, and torque down lower strut bolts, then the uppers. I used some blue Loctite on the nuts just to be sure they don't back off.
Edited by nmyron
AVS Bugflector
After
Full Body Polish
Man that looks great
Post up after, yet to see NVs with stainless.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
    • Just don't turn the steering wheel as much?
    • Rockauto bud. I pass local stores for parts.   Findya something online.
