9 hours ago, Ge0rge said:
Can you tell me what tire and size you have on that very clean rig?
Thanks for the compliment.
Those are 275/55/20 BFG AT K02 tires. Came on the truck when I bought it. Little stiff and heavy for my liking, but the traction is great, they look amazing,  and are wearing very nicely.
I had to get something from behind it. So I decided to let it soak up some sun.
Out at Marymoor Park in Redmond WA this foggy overcast morning. Wishing for the summer to come, which in the PNW is still a ways off.
  • Like 5
Looks great,   I really like the simplicity there is something to be said about a nice original truck, without all the extra mods which are cool but I love the Simplicity of this
Looks great,
On 1/26/2019 at 9:34 PM, tim5779 said:
What size tires did you go with? 285.55.20 or 275/60/20?
Edited by 426power
16 hours ago, Shakeydeal said:
Very good looking truck.
Shakey
Thanks!  In my opinion, black out is the only way to go with the Dark Slate Metallic paint.
275/60/20...No rub with the 2" level
Edited by tim5779
edit
thank you
Marymoor Park Number 2:  2018 GMC Denali with birch trees.  Not as white or vibrant as Ansel Adams Aspen's. I need to come back here in the summer when the sun bleaches these out more white.  Maybe a good subject for night light painting.
  • Like 4
Rough Country 2 inch front level block, American Outlaw 20 inch wheels, 305/55/20 Nitto Ridge Grapplers, Westin HDX step down bars.
  • Like 5
How do you like the Westins? Do the steps line up well for getting in and out? I like those. Nice truck!
    Randy Ginoza
    Randy Ginoza
  • Who's Online   4 Members, 0 Anonymous, 2,015 Guests (See full list)
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
    • Just don't turn the steering wheel as much?
