2 hours ago, Sean D said:
How about the steering wheel? What is the process for replacement?
The video above is good. I didnt need to change the clock spring because I was just swapping a worn steering wheel for new one. I will say this I was stumped for a bit trying to release the air bag clips. You really need to understand how they are held in to get them to release. The video above shows them better than the video I used. Overall it was a quick and painless procedure.
Yeah the airbag was my biggest problem took me about 30mins to figure out how to release them,I was use my phone the front face camera but I recommend using a mirror that made it way easier for me.
On 8/17/2019 at 2:58 PM, JimCost2014 said:
Looks great!
How "much work is involved" in changing the shift handle?
Something I have been thinking about doing.
On 8/17/2019 at 2:42 PM, Vulcan762 said:
After 112k miles the leather wrapped steering wheel and shifter handle in my 14 Sierra 1500 Denali were showing the wear and tear of the miles. So after a visit to EBay, $150 and 30 minutes later I have replaced them both with factory new OEM replacements. Came out great and was an easy way to take the miles back off my interior.
Looks beautiful!   And easy on the wallet..
On 8/17/2019 at 8:09 PM, Vulcan762 said:
Thanks for the screenshot but would you happen to have a link to the seller?
No link but neither seller have any more. Just widen your search terms on ebay and save the search so you get alerts when the item your seeking pops up for sale.
heres some pics of the 4' bds lift kit with moto metal 20x10s ridge grapplers 33x12.5
On 8/12/2019 at 9:56 AM, techsan15 said:
any rubbing?
yes. sway bar and UCA both sides only at very full lock. When you hold the wheel at full lock and let off a 1/2" inch it stops.
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
