1 hour ago, cheyenne383 said:
Pandemic day 5, we're stranded at home because dad detailed the vehicles and refuses to drive them in the snow. ?
For the conditions, those are two really clean trucks!
I admire your dedication!!!
Brand New vs Now. Spent a lot of time (56k miles) enjoying it stock, but those days are over...
  • Like 4
Looks great! Any other plans for it?
Thanks! Next is a 3/5 Drop and remove steps. After that I’m planning on a cam swap. It’s already got LT headers and true duals, with a CAI and dyno tune. I’d like to get to 500whp before I start working on my project truck.
Already posted some pics few weeks ago but it's always a pleasure to see and share ours trucks ...And as a 2014-2015 MY owner I need to compensate for all those 2016+ ??
Also a pic of the Rough country forged UCA I installed to relieve poor BJ angle (3" front lift from previous owner). Ride is way better (or much less worse ?) In next few days I'll install the 2.25 Readylift instead, to get a better ride with more downtravel, have better CV/Steering angles too & get some rake back. I wanted to go 2" but may be too low for the UCAs. And I can't make my mind for the future : stay lifted or go full stock with the best ride quality….Cause having 3.08 gears, big tires are not an option, I already made that mistake on my previous Tahoe and I didn't like it at all (33" vs 31.5").
Robin
Ill be taking more pictures tomorrow but on the new suspension with 6112’s and kryptonite UCA’s up front and 5160s out back. (I know a lot of people don’t like all black wheels but it’s what i wanted)
I went with that look as well.
Edited by BAUBOY
1 hour ago, BAUBOY said:
My 2017 - too much to list ?
What’s size wheels and tires do u have on your truck? I also like the black wheels with silver paint, I will keep this look even when I buy bigger wheels and tires for sure. Bro I just realized this is your truck i took a picture of while back next to mine on my lunch break. Definitely like your truck bro ???????? made mine feel small ? D78311A9-C0D6-4FF1-9B48-F7C20893D881.thumb.jpeg.100360c669955e0b4ac55db5bea5924c.jpegA45AC455-F148-47F3-BAEF-7DD947D98458.thumb.jpeg.45b8f1ea406c54cedfe580b8ba1c61f4.jpeg
Edited by Frankielozano214
Hi, how would you describe the ride with 6112 ? Is it firm ? Thks
That's crazy.  So I assume your N. TX? Those wheels are 22x12 -44 sitting on 35x12.50.
Yeah I’m in Pg area but I work over there in Coppell, Irving, and Lewisville area, I think that picture was couple months ago when I just installed my frontend, badass truck bro exactly what I wanna do to mine when I get the $$$. 22x12 actually look really nice man I was debating on what size I should go. How your gas mileage with the lift and the wheels?
It’s a firm ride but not jarring. Rides a bit firmer than my dads ram 1500 with the carli fox kit but it feels less rough than the stock rancho garbage. definitely rides a little softer than my 2006 Tundra with the TRD suspension did as well (all being compared on i-35 in austin)
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
