Mine came with the "Silverado" de-badged or never really installed at all. There were about 150 Silverado on the lot with out them. The dealership said that's how they were coming from the factory! byve8a5e.jpg
Go Army! GO ORDNANCE!!!
I wonder if this is with the Texas Editions. I have a Sierra Texas Edition with only the Texas Edition badge. But then today I saw a Silverado and a Sierra with Texas Edition and the Silverado/Sierra badge as well.
Yes, it is a Texas Edition Silverado. It came with the "Silverado" de-badged from the factory.
Another nice Arizona truck! And I like that neighborhood, are you in the north part of the valley?
Thanks! In the East valley.
Is that a cold air intake?
Yes sir, AFE Cold Air Intake. I believe I spoke with you regarding it on IG, may have been another individual. Let me know if you have any questions.
This is a running change that I posted when I saw it in Techlink a few months ago. Bacically for the Texas Edition, High Country and All Terrain Editions, GM eliminated the Silverado or Sierra badges on the door. Mine has both Texas Edition and Silverado, but I am thinking of removing the Silverado badge because I think it looks cleaner with just the Texas Edition badge. Here's the link if you are interested...
http://www.gm-trucks.com/forums/topic/161129-gm-is-eliminating-silverado-and-sierra-nameplate-badges-on-some-models/
Edited by chuckl1218
Have you noticed any improvements since installing? Any MPG increase?
High Country fully loaded.
Loaded and ready to roll with the bikes.
What wheels are those!? Looks great, I hate the looks of my hc wheels.
Those are 22" GM Accessory wheels. Good lookin'! (CK157/SEZ)
Very satisfied owner!
IMG_20140726_012624_zpsaakfp63v.jpg0726140917_zps1wnuxigs.jpgIMG_20140726_093029_zpsds60j4xf.jpg
A Simple beautiful truck. Are you running a lift or just level? What size wheels/tires, did you need to do any trimming?
Thanks
Jeff
Not quite two weeks and I love it. Tint and WeatherTechs so far. Tires, Wheels, RC 2.5", and Nfab bars to come.
What % tint is that, I like the look and want to do that to mine.
My new ride 2014 GMC Sierra All Terrain Black on Black.
  • Like 4
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
