Shifting hard at times
Hi everyone, I am just now starting to have an issue with the truck shifting hard from park to reverse to drive etc, at times it will just come right out of it and shift like a dream but most of the time it goes hard, anyone else ever have this problem? How did you fix it? How would you fix it? My truck is a 2011 Sierra with 5.3l 6spd, I have 93000 km and 3600 hours on it lots of shifting as I use this truck to read meters, so lots of stops.Thanks in advance.
Yes but would the warranty cover it if it was just the shifting cable??
its not the cable
Ok,what then, I was thinking it was likley the cable,have you had this problem or know someone who has,
I know I have warranty but you don't get it, my dealer is terrible so if there is any way they can stick me then they will, so I like to know before I go what is wrong which is why I posted the question to see if anyone else has any idea what it is or have ever had any experience with this, since I am getting no response I guess I am the first, I am not affraid to use my warranty but the dealer will do anything possible to avoid a claim.
that make sense after you are alittle upset why i cant poop out the root cause of a problem thats intermitant insde an automatic transmission and then you can take that to the &^% dealer and demand the repair ......
weeeeellll sooorrrrryyyyy
take it to *&&^%$ different dealer ...or ....if you have problems with your dealer you have avenues on how to deall with them,,,,,,
give me a break travis
why would a dealer WANT to refuse a claim ? ,,,,,,if its the lower $/hr rate of warranty they dont like then they have problems financialy and the regional service manager needs to be contacted if you have proof of this cuuuuzz its BS on the dealers part for sure ,,,,
there is to many things it can be to guess travis ,,,,,,
trannies and the interent dont go together ,,,at all
you may need a simple reprogram if ones available in the system
just dont be intimidated but keep your cool there hot head lol
Really man, I'm not upset with you except that you claim my idea of the shifting cable is wrong but have no idea why it's doing it and you demand I take it to the dealer, my post asked if anyone knows whats wrong or has anyone had any experience with it which clearly you do not , I posed a question, you don't have the answer, so give me a break Rob!!
Well as it turns out it wasen't the shift cables, or the transmission, the problem was in the column, I figured this out by accident the other day when I went to tilt my steering column(which I never do) and found that it woulden't lock into place afterwards, so I grabbed a can of rust check and lubricated the column in arround the tilt lever and hazzard switch and then everything is working perfect now, shifts like a dream, tilt works perfect, it even steers easier.Unfortunatly just before I did this I had ordered the new cables at the dealer, when they came in I just had to pay a restocking fee to get them to keep them, at any rate I am releived to have this fixed and glad I diden't just run to the dealer for diagnosis at $75/h as it would not have been a warranty thing.
    • Most say the oil temperature needs to above the boiling point of water to rid it of moisture and long enough to dry it. Many think that is about a hour at 212 F or more. Those people have never line dried cloths in a Midwest winter. Leave a pan of water sitting on the counter and eventually it all evaporates. So heat drives the time it takes. Water in oil under 175 F, the Nitration initiation temperature, is a minimum then for temperature and samples I've done that use Karl Fisher method say about a hour (in a healthy well tuned motor) over 175 F will dry it to under 800 ppm. Low enough to not be much of a factor. Motors with weak rings will take longer and the colder the air temperature the longer it takes.   On a cold motor there is also the condensation temperature. Blowby gases that contain moisture are subject to that cold cylinder wall, like sweat on a glass of ice tea. But also subject to the Law of Partial Pressures. Wear studies by GM and the DOD  indicate wear is a real issue below 85 F and a concern to 140 F but doesn't become a minimal factor until about 160 F. You know this intuitively when you see water vapor exit the exhaust pipe until the system gets above the dew point. It isn't magic, it's physics and it fascinates me. I know you didn't ask but....I over share sometimes. 😉    You keep the Camaro's high and tight.
    • Move further away.   Benefit of living out - none of our cars get short cycled, plenty of warm up time.   Curious how much time/temperature it takes to drive moisture/condensation out of the engine?
    • Switch a a 100% synthetic trans fluid, Amsoil works for me.
    • First of all sorry, I know there are a ton of transmission temperature threads...   My truck is a 2025 LZ0 High (10l89 10-speed) High Country with NHT max trailering package. The NHT package is supposed to have "enhanced cooling."   Normally the trans temp sits around 200. It seems like with any real stress it quickly jumps into the 220s (for example climbing a grade unloaded at lower speeds). I haven't towed much with this truck, but I'm concerned if it gets this hot unloaded.    I've tried a few different things to keep the temps down (tow/haul mode, sport mode, low range when that makes sense) and nothing seems to affect it.    I'm curious if others are the same behavior or if anyone has found techniques to keep the temps down. It seems like it just can't handle reduced airflow at lower speeds, even with relatively light loading.    Thanks!
    • I'm at 105,000 miles on my baby Duramax. No issues yet. I hit 31 mpg's traveling through hilly terrain to a project in Colorado. I will buy another 3.0. I'm not concerned.
