I know for a fact that the cameras on the traverses have higher resolutions than the garbage they outfitted in the full size trucks.
If there were a way to plug one of those cameras into the wiring of ours and see if the resolution improved...
Who supplies rear view cameras to auto manufacturers? There has to be a way to retrofit a better one into the tailgate handle...
The screen is not the problem. The resolution of the screen is very good.
Gringo
I hate to say this but the screen resolution will not be good, I already asked the engineer about it. Also even if you hook up a higher resolution camera, if the screen is not capable of handling that resolution then you wont have any video.
No different than cranking the resolution up on a monitor or TV, get outside of the rate it can handle and it will not show anything.
that engineer of yours fed you a line of bull.
the resolution of the screens is much better than the cameras. if it weren't, then why can video files be played that look decent on it?
from a 2013 press release of the 2014 mylink:
"One of the most noticeable additions to the new Silverado is the available high-resolution, full-color touch-screen display radio that is seamlessly integrated into the top of the central instrument panel. This vibrant LCD screen is standard on LTZ and available on LT, and it displays a home page resembling a smartphone screen or tablet, with just a few, large buttons and easily recognizable icons to execute commands."
  • 3 years later...
I would love to see the difference in quality of someone who swapped the factory radio for an aftermarket and retained the original backup cam.  Or added the optional 3rd brake lite camera.
I have a 2015 LTZ . would anyone know if there is a higher resolution camera for the newer trucks?
I have a Pioneer head unit with Maestro RR interface using factory back up camera and the picture is crap. Worse then the factory picture. Reason for this is the camera GM uses is crap.
Maybe someone can post a picture of the quality of a 2019 backup camera, or any other newer GM vehicle. Maybe you can make these fit, because as far as i looked, the camera works just with a 4-pin connection like any other backup camera.
Do you guys really back up that much?
My wife’s 19 camera is awesome but it’s 5 years newer than my 14 LTZ.  I’m only in reverse for 20 seconds at most so not a big deal to me.
I agree with the whole thread.  I have a Tahoe I put a pioneer screen (350) and a pioneer camera (100) in and the difference is outstanding.  Much better product than GM's
Firstly the screen can handle it, just play a properly formatted video using the media option and ou will see higher resolution.
Secondly the "bandwidth" should also not be an issue since this is traveling over a wire.
The biggest issue here would be drivers, and assuming that the open source OS software is used in all situations, the cameras would be selected for comparability so i doubt that would be an issue
Lastly, yes, some of us do back up that much especially when using the camera to hitch up. It would be nice to have a better resolution when hitching.
  • 4 months later...
Hi folks happy new years. I'd like to share to the thread that the 2019 Silverado LT camera that I have has very poor quality.  I have a loner Traverse and the quality is nearly HD like quality night or day. The Silverado camera is grainy and even flickers.
    • Enjoy the new truck, it’s a beauty. I’m glad you’re keeping the OBS, I love those old trucks.
    • With large equipment or deep mud it is more of a use the higher gear to avoid spinning tires, getting stuck because of spinning tires and doing damage to your machine. The idea is if you run out of torque before you spin tires you can still downshift for more torque. If you are just spinning your tires in the lowest available gear you are stuck and things break.   Automatic transmissions, traction control and electronic transfer cases change the calculation a little as you the driver have less control over each piece.
