Has anyone rotated their tires and successfully re-learned the tpms sensors to their corrent new loication? I changed the oil last night, but realized that there is a "calibration" tool to relearn the tmps sensors. I heard there was way to let the air out of the tire in the order of caliobration and that worked on the 11s.
And before you ask...I hate going to dealers so lets just leave that out of the conversation. Thanks for the help in advance.
The TPMS sensor matching process is outlined below:
1. Set the parking brake.
2. Turn the ignition switch to ON/RUN with the
engine off.
3. Press the Remote Keyless Entry (RKE)
transmitter's LOCK and UNLOCK buttons at the
same time for approximately five seconds. The
horn sounds twice to signal the receiver is in
relearn mode and TIRE LEARNING ACTIVE
message displays on the DIC screen.
If your vehicle does not have RKE, press the
Driver Information Center (DIC) vehicle information
button until the PRESS V TO RELEARN TIRE
POSITIONS message displays. The horn sounds
twice to signal the receiver is in relearn mode and
TIRE LEARNING ACTIVE message displays on
the DIC screen.
If your vehicle does not have RKE or DIC buttons,
press the trip odometer reset stem located on the
instrument panel cluster until the PRESS V TO
RELEARN TIRE POSITIONS message displays.
The horn sounds twice to signal the receiver is in
4. Start with the driver side front tire.
5. Remove the valve cap from the valve cap stem.
Activate the TPMS sensor by increasing or
decreasing the tire's air pressure for five seconds,
or until a horn chirp sounds. The horn chirp, which
may take up to 30 seconds to sound, confirms that
the sensor identification code has been matched to
this tire and wheel position.
6. Proceed to the passenger side front tire, and
repeat the procedure in Step 5.
7. Proceed to the passenger side rear tire, and repeat
8. Proceed to the driver side rear tire, and repeat the
procedure in Step 5. The horn sounds two times to
indicate the sensor identification code has been
matched to the driver side rear tire, and that the
TPMS sensor matching process is no longer
active. The TIRE LEARNING ACTIVE message on
the DIC display screen goes off.
9. Turn the ignition switch to LOCK/OFF.
10. Set all four tires to the recommended air pressure
level as indicated on the Tire and Loading
Information label.
11. Put the valve caps back on the valve stems.
Just had to do this myself.
  • Like 7
im curious as to what experience you had to make you say that last statement ,,,if ya dont want to tell us ,thats fine .
Great info...not so good with nitrogen fill.
How about adding a second set of tires with new a set of TPMS? I have an ATEQ that I've used on other vehicles to change from winter to summer tires. Or will the new pickup recognize the new sensors so you just identify the location?
You need a tool or dealer visit. The air down procedure no longer works. Hasn't since mid 2011.
I know the air down procedure doesnt work anymore and I dont believe the key fob method works either. The only way I believe is to go to the dealership and use their tool or order one. I was wondering more if someone ordered one or had any recommendations.
As far as never wanting to go to dealers, I have had too many reasons never to go back. Not really specific to one dealer, but multiple dealers over multiple various issues.
1. Had issues with the wrong weight oil installed in my wife's diesel along with the wrong fuel filter (therefore fuel was bypassing the filter). I realize accidents happen, but I am not ok with them happening at my expense (customer's expense).
2. Also had issues with door dent/chip from tech opening into a post lift
3. Have seen someone drive away from a dealership and almost have a wheel fall off due to the tech forgetting to retorque the lugs.
I work in an industry where we have to make everythign 100% retard proof becuase we cannot depend on the training of the supposidly trained/certified technicians. I have seen a lot of stupid things happen and just prefer to do the work myself so i know what oil is installed in my car, how the lugs were torqued etc....to each his own I guess.
I may just drive by the dealership now that the tires are rotated and ask them to let me use the tool or walk around it for a minute....literally a minute to do this procedure.
I used the same tool as SAMS819K2XX on my 2009 because air pressure never seemed to work and it worked great. Only took about a minute to do all four. Also works on wife's 2012 Terrain.
Just tried this procedure on my '11 Silverado and it worked great. I've read about it - but never tried it.
Always bringing my truck to the dealer once a year for oil change and tire rotation so they can take care of resetting the monitors.
Ironically, I just had it into the dealer on Friday and they must have screwed it up because the service tire monitor system warning light came on today.
I think I'll go back to changing my own oil and rotating tires. I don't have time to be running back to the dealer, especially when they are only open during regular office hours.
Edited by jst3
    • Enjoy the new truck, it’s a beauty. I’m glad you’re keeping the OBS, I love those old trucks.
    • With large equipment or deep mud it is more of a use the higher gear to avoid spinning tires, getting stuck because of spinning tires and doing damage to your machine. The idea is if you run out of torque before you spin tires you can still downshift for more torque. If you are just spinning your tires in the lowest available gear you are stuck and things break.   Automatic transmissions, traction control and electronic transfer cases change the calculation a little as you the driver have less control over each piece.
    • are there any codes? with lots of rust, perhaps disconnect/clean both sides of the connection/examine cable ends (the wires) for corrosion going into the sheath & replace if necessary/reconnect ALL the power AND ground cables between the battery, engine, frame, cab, fuse box and starter charm.li (website) has a no-start diagnostic procedure you can work through to get it working.
    • Its no wonder you've gravitated to the oil types and brands you have in later years after trying certain brands and one being a specialty oil or at least very hard to come by up here and the other would have been a commonly found oil of the era and the vastly different outcomes as a result to using the vehicles in question the same distance for an OCI . It shows what marketing hype can do without actually having the product to back up the claims and that is no different now with the insane claims that are written on the side of a bottle of oil from some of the off the shelf oils.    What has surprised me and I was already finding this out before I bought my truck with the GDI engine, that this newer fancy technology that seemingly would suggest better fuel economy/emissions with this high pressure spray of fuel is not in reality kind at all to the engine or at least the oils life. Yet they insist on claiming long OCI with this technology just like they did with the port or similar type fuel injection systems when in reality its a step back in oil life to have a GDI system.    I think the mistake your making Grumpy is that your not sending your samples to Blackstone and getting the feel good glowing report that you can run it another 1000 or more miles and then send another sample where they say run it yet another 1000 miles and on and on it goes until your sending in something that looks a lot like road tar and then they may suggest you change your oil within the next 1000 miles 😆
    • I am guessing that engines of that design back then had a better ability to be abused and survive longer than a new design engine with the long timing chain and the overhead cams and phasers etc. But I would never guess that an engine could go that far and not fail spectacularly or at least die a slow death.
